Question about HP W1707 LCD Monitor
No sound from speakers. CAN hear on plugged in headphones.
    Scholar:
  • 64 Answers
Hi, for this u need to follow the following steps.. click Start -- under Start Search -- search for "Sound" and hit enter.. and there u shall be able to see the device u have for Audio for ur computer.. check which device has the Green Check enabled.. whtever device has the Green Check enabled thats ur Default Speaker connection.. select other device and then select Default below.. for detailed information.. go to the link below http://tinyurl.com/2fvjh7l
left me know if this was helpful to u .. regards, guru
Posted on May 05, 2010
No sound in speakers, do i need new speakers or is it something i can fix?
Try a pair of headphones. If you can't hear any sound it's not the speakers. If you can hear sound, it still might not be the speakers. As sometimes headphone sockets which cut the speakers off when headphones are plugged in, can go faulty. To test any loudspeaker connect a 1.5 volt battery accross it's terminals for a few seconds. It should POP.
Feb 27, 2013 | Audio Players & Recorders
I can hear sound through headphone but not through speakers. The volume of the speaers are turned up
The most common issue with speakers. I hope you have not plugged in the headphones while trying to hear sound from speakers. However, go to control panel - sounds & audio devives - and select the correct sound device installed for your computer.
Chio,
Anirban Mazumdar
Dec 04, 2010 | Toshiba (P000230850) Computer Speakers
Dell studio xps no sound will come out of the speakers
I assume you mean the internal speakers.
First thing I would try is hooking up a set of headphones. If you can hear sounds thru the headphones then there could be an issue with the headphone jack. (the jack acts like a switch, switching OFF the speakers when you have a plug inside, and switching them back ON when you remove the plug).
If you dont hear sounds thru the headset or speakers, check your device manager, and remove/reinstall your audio driver. You can download the driver at the dell website Support.Dell.com.
Oct 26, 2009 | Dell A525 Computer Speakers
Dell speakers wont produce sound
Check your system if you are able to hear sound using any headphone..if you are able to hear sound from headphone then the problem is with your dell speakers,else you need to update sound drivers for your system...Thanks..
Aug 08, 2009 | Dell A215 Computer Speakers
Speakers not working-- can only hear using headphones w/computer
unplug your headphones, and plug the speaker cord into that jack. its possible that the speakers you are using require power either by a cord or batteries and without them, it wont play sound. also, possible, your speakers are bad.
Apr 15, 2009 | Audio Players & Recorders
Compaq CQ50 Laptop
If the sound works on you headphones the either your built-in  speaker(s)  is/are  bad or more likely the headphone jack itself is broken and not making contact in the speaker position which is fairly common.
Feb 28, 2009 | Compaq Audio card Sound Card
Cannot hear sounds through headphones
if you are able to hear normally from the speakers and not from the headphones possible reasons could be:
the audio is muted or very low
there is a mute switch on the headphone that is turned on
the headphone is not firmly plugged in or is in the wrong site eg microphone
hope it helps
please inform if it helps..
Nov 01, 2008 | Acer Aspire 3680 Laptop
Toshiba satellite laptop
I think the problem is in your Headphone jack.
Hope this helps.
Apr 10, 2008 | HP Pavilion dv6000z Notebook
No sound from headphones connected to speaker
I may be too simple of an answer but that would happen if the headphones weren't plugged all the way in. If there is a bend in the connector and it's hitting the speaker they may not be plugged in all the way.
Jan 31, 2007 | Altec Lansing VS2221 Computer Speakers
HP W1707 LCD Monitor Logo
126 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
