Question about Sub-Zero 690 Side by Side Refrigerator
The light on the refrigerator side of my Sub Zero does not work
The light on the refrigerator side of my Sub Zero 690 no longer turns on when the door is opened. The menu bar with the ice maker/temperature information does not light up either. Do you think it's a burnt out light bulb or possibly a wiring short?
  • brandonlande May 05, 2010
    What kind of cost is associated with repairing/replacing the main board? Is it an easy repair?
  • 175 Answers
The light switch at the top of the door frame is bad. it controls all the lighting including the display for the board. you will have to remove the grille up top, remove the cover over the 2 switches, and replace the switch that is all white. the one with a black back is for the fan and rarely goes bad. Just unplug the unit or at least turn it off before changing this switch, as it is live any time the unit is turned on.
Posted on Nov 15, 2013
    President:
  • 2,468 Answers
Your main board in the rear is faulty it has relays to control lights,temp read-out and other electronic controls in this unit
Posted on May 05, 2010
  • danny Hendrickson May 05, 2010
    the main board is easily replaced,you need a longer model number as i could not look up to see exactly where your board is located,but many are either inside a plastic panel on the back or inside the lower rear area on the unit,an appliance parts store can help you locate it with a full model number,then its just a matter of unplugging a harness or two and replacing this main board unit
  • Peter Allen Apr 10, 2013
    Great help. Thank-you
Why did sub zero 690 stop running ?
Are both sides not running? Are the lights still on? Did you try the on/off button?
Jul 29, 2014 | Sub-Zero 690 Side by Side Refrigerator
How do you install or change the water filter.
If you model Sub Zero 690 has a filtration system this is what to look for. Thanks John Tripp Appliance 911
Contact Me Here
Sub Zero 690 Service Manual
Sub Zero Installation User Manual
CONTACT INFORMATION Sub-Zero Customer Service:
800-222-7820
Website: subzero.com
E-mail Address: customerservice@subzero.com
Jul 07, 2014 | Sub-Zero 690 Side by Side Refrigerator
Side by side Sub Zero light switch works intermittently.
I had the same problem with my sub-zero and finally resolved it (much to my wife's delight) by just replacing it. R&R was a lot simpler than having to work on it every time my wife had a problem.
Dec 14, 2011 | Sub-Zero 690 Side by Side Refrigerator
Sub zero ref 690 s model with error code ec 50 what is that
EC code is on with a flashing service light . Is this a problem that I can fix on my own?
May 26, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Nov 25, 2009 | Sub-Zero 690 Side by Side Refrigerator
Fridge side light is off. fridge works
check if your bulb is busted, have it replace
Nov 14, 2009 | Sub-Zero 690 Side by Side Refrigerator
Light on refirgerator side doesn't come on unless I tap switch.
I had to take my switch apart and clean and lube it and it worked fine. Or just replace the switch. It may have gotten some sticky ketchup in it like mine did.
Sep 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
8 year old Sub-Zero model 690. Condensor coil leaking
When copper and aluminum are connected it cannot be welded, it has to be crimped. this is a problem that is not exclusive to sub zero, an all aluminum evaporator ( if it is in the refrigerator it's an evaporator) should resolve the problem nicely
Jun 17, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 the control lpanal light does not come on
If the refrigerator is working fine, you may have a bad door-switch. Open the refrigerator door, you will see two switches on top, the one on the left is for the lights; try to tweak it may just be stuck. If this does not work you have to replace it. You can double-check this by shining a flashlight behind the control panel and you can see the temp. and the other info. This means the panel is fine. You can also try to contact Sub Zero customer service, they may send you a new switch for free.
Good luck and I hope this help.
Byron12020
Jul 30, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
428 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
