Question about GE Profile Harmony DPGT750EC Electric Dryer
Blower motor not blowing - GE Profile Harmony DPGT750EC Electric Dryer
  • 20 Answers
The fan could be stripped on the shaft or perhaps a thermostat or sensor
Posted on May 07, 2010
Why has my a/c stopped blowing
Could be a blown fuse or a problem with the blower motor or resistor/controller, but on the AZC (automatic zone control) system, many times the problem is a melted connector on the blower motor controller. Look up in the passengers footwell area, there you will find the blower motor (fastened with three screws) and next to it the blower motor controller..
Jun 17, 2014 | 2000 Jeep Grand Cherokee
Heater won 39 t blow on 5
haw i fix my rpm meter problem
Sep 28, 2013 | Cars & Trucks
Is there a blower motor relay or fuse on a 1995 Mazda Protege lx?
That fuse sounds like it powers the ac compressor.
The blower motor usually takes a 30 amp fuse.
Does the blower motor work if you hook it to direct voltage ?
Jul 04, 2012 | Cars & Trucks
Blowing fuses on blower motor 2006 e250 econoline
Both are possible.But it can be blower motor issue mostly.Its taking too load and that's blowing the fuse.How to Test and Replace Blower motor on car? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-and-replace-blower-motor-on.html--------- How to Replace Blower Motor Wheel? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-blower-motor-wheel.html
Also more help solutions recommended. Click the link below :---
Blower motor replacing for all vehicles? http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
----------Blower motor Resistor shorting problem? http://schematicsdiagram.blogspot.com/2011/12/blower-motor-resistor-shorting-problem.html
--------This will help.Thanks.
Jan 25, 2012 | 2006 Ford E-250
2001 nissan maxima heater blower isnt blowing
Check the fuse for the blower motor. If its okay, check for power at the heater motor. If you have power, and no blow, the blower motor will need to be replaced.
Dec 19, 2011 | Cars & Trucks
My 94 Sundance heater/AC blower motor has quit. I've bought a new resister, but cannot find where it's located. Any help?
The blower motor resistor is located in the same duct that the blower motor blows through. If you see the blower motor, within a foot of it is the resistor. The blower motor actually blows over the resistor to keep it cool. The blower motor is usually only in 1 of 2 different locations. On passenger side, access under the hood or under dash access behind glovebox. In both cases the resitor will be in the duct that the blower motor blows through.
Jun 16, 2010 | 1994 Plymouth Sundance
2002 Jeep Liberty - Air conditioner not blowing. Replaced blower relay switch - Still not blowing. When car is in motion, you can feel cold air at the vent, but the blower is not blowing the air into the...
OK. So the blower notor isn't operating. Do you have power to the blower motor? The resistor is new from what I got. If you don't have power to the blower motor, then check the speed control switch and fuses. If you have power at the blower motor, replace the blower motor
Jun 16, 2010 | 2002 Jeep Liberty
Everytime i turn my heater on heater on works and blows fuse?
fuse blows. unplug heater blower motor turn ignition on, turn heater on, does fuse blow? if not need to replace heater blower motor
Feb 10, 2010 | 1995 GMC Jimmy
Blower motor doesn't blow anymore, This blows
If it blows only on high speed, it is the resister.
If it does not work at all, check fuses first. See owner manual for location.
Then check blower motor by jumping 12 volts from battery to blower motor. Make sure ground is jumped too.
If it works now, it's the control panel. If not, it is the motor.
Blower Motor —Front Removal and Installation
  1. Prepare the vehicle for blower motor (19805) removal.
    1. Disconnect the battery ground cable (14301). For additional information, refer to Section 414-01 .
    1. Remove the air cleaner assembly. For additional information, refer to Section 303-12 .
  1. Detach the speed control servo.
    1. Disconnect the electrical connector.
    1. Remove the bolt.
    1. Position the speed control servo aside.
  1. Position the coolant expansion tank/windshield washer reservoir aside.
    1. Remove the screws and the nuts.
  1. Remove the blower motor.
    1. Disconnect the vent hose.
    1. Remove the four screws.
Also,
Heater Blower Motor Switch Resistor(s)
The front heater blower motor switch resistor has the following features:
  • The assembly is located in the engine compartment on the evaporator housing (19850) next to the blower motor assembly (19805).
  • Three resistor elements are mounted on the resistor board to provide four blower motor speeds.
  • Depending on the heater blower motor switch position, series resistance is added or bypassed in the A/C blower motor circuit to decrease or increase A/C blower motor speed.
  • An overheating device (thermal limiter) will open the resistor coil circuit when the temperature reaches 121°C (250°F), interrupting the blower motor operation in all speeds except high.
  • The thermal limiter cannot be reset and is not serviceable.
Aug 10, 2009 | 2001 Ford Explorer Sport
My a/c will not blow out air. You can feel the
Sounds like a blower motor not turning the blower. Could be elecrical. Check fuses that control the blower motor or blower motor relay. If these seem to be okay, locate the blower motor relay and try replacing it with a known working relay of the same style. If the A/C begins to blow, then you need a new relay. If not, you'll be looking into the blower motor or fan. Make sure your cooling fans function while your A/C is engaged.
Jul 03, 2009 | 2002 Buick LeSabre
GE Profile Harmony DPGT750EC Electric Dryer Logo
81 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
