Question about Belkin F5D8236-4 Router
No wireless my computer conected fine for a while then it stopped picking up the signal my computer if fine it picks up other networks so i think my router has stoped routing
    President:
  • 1,851 Answers
Reset the router - - there is a reset button - unplug the pc from it - so all you have is the box and the plug to the wall - make sure it is on - then - push the RESET button while the unit is on.
This will get you going again on that side - -if your pc side isn't working - remove the wifi program driver and reboot the machine it will self load again or you can use the driver - install disk again and this will get you fixed.
Please give me a vote UP if this helps at all - this helps me here.
Thanks
Posted on May 05, 2010
Testimonial: "thanks that was it"
Using a Acer Aspire Revo. Running with linux Unbuntu 10.4lts. I have a BTHomeHub trying to connect my NWD-270N Wireless N-lite USB Adapter however it picked up the Hub and established a connection...
Select from the computers default internet networks, Recent computers are wireless enabled as the prefered networking. Attempting to introduce another network would share the connection capacity to any availabe signals. decide on the network type required. Pick wireless and disable the remaining networks to achieve an express signal reception and transmition.
Jan 29, 2011 | Zyxel NWD270N Wireless N USB Adapter...
My dell inspiron e1505 tells me that it cannot pick up wireless networks. My computer was picking up wireless earlier today in front half of house. we extended the signal via ethernet cord and plugged in...
Depends apon the signal and how you have the computer settings some of the older computers have programs where differant places will not be picked up !
Did you check your internet options in your control panel?
1.Check your internet options and see if your lan settings have a check mark in the top box for lan atuomatic detect settings click ok then your internet should pick up ..... if you are still haveing prombelms please let me know ... Lala linda
has a check mark on the top box so there is a
Dec 24, 2009 | Dell Inspiron 1501 Notebook
Can't pick up Wifi signal
Check wheather its disabled.and then Scan for the wireless network again and try connecting.make sure thatyour typing correct password if its security enabled network.
May 05, 2009 | RIM BlackBerry 8820 Smartphone
Wireless router signal
evidently you computer is picking up a weak signal.
1. you may have a defective router.
2 the pickup on your computer may be weak or defective
3 I would try to reinstall the program for the router and dtv
Lou Margolis
Allied Electronics
alliedtv@verizon.net
or call me 513 490 0759
Aug 14, 2008 | NetGear WGT624 Wireless Router
Laptop not seeing my wireless router
Try to manually "Add device to network" by using the wireless setup wizard. Check to see if the Wireless Zero Configuration service is "Running" before trying to add device. Yuo may also want to disable IPv6 in vista tcp/ip properties page.
Jul 17, 2008 | Linksys Wireless-G Broadband Router
About my wireless card...
reset the network settings both on the computer and your router and start again. go to the website for your router and enter the ip or mac address for your wirless card and enable it on your network. to get your computer to recognise the network, turn off wireless, plug it in the local area connection first then for a few minnutes then enable the wireless and unplug the wire and it should recognise.
Jun 23, 2008 | Computers & Internet
My tom tom is not picking up gps signal
I just connected to my computer and ran updates that I got from tomtom.com... It works fine now. Try it with the new software.
Oct 16, 2007 | Tomtom ONE GPS Receiver
Please help I can't conect to Router MR814V2 with wireless card Encore ENPWI-G2
On Windows XP, the OS will prevent a connection to an unsecured wireless network such as what you have.
You can try:
Double click on the red WiFi icon, click on the "Change the order of preferred networks",  Click on "Add", type in the Network name (SSID) of your router (you can get this by using the connected PC and log in to the NetGear's Webbased Interface), set Network Authentication to "Open", set Data encryption to "Disabled",  OK, reboot your PC.
Alternately, you can set the PC where the Encore ENPWI-G2 card is connected to manual configured settings rather than Auto obtain. Follow what is in the connected PC's settings except that the  last number of the IP add be different (ex. connected PC > 192.168.0.100, set the unconnected PC to 192.168.0.101, all the rest subnet, default dns be the same. Of course the 101 must not be in use, if double IP add, change to 102).
In some instances, you may need to use the Encore WiFi configuration utility (normally comes with the drivers in the installer CD) rather than the Windows buil-in WiFi Config utility,
Hope this be of some help/idea. Post back how things turns up or should you need additional information.
Good luck and kind regards.
Oct 10, 2007 | NetGear MR814 Wireless Router
Connection failure after period of time
If it's possible try moving the router to another telephone point that is nearer to the problem reciever. Unfortunately all sorts of objects can divert the wireless signal, something as simple as a door. If your wireless adapter picks up a signal of 57% it may also be very low on the 'bps' transfer and may only show as limited or no connectivity. The signal to the router may be average but it still has to transfer data to enable a network and internet connection.
Mar 03, 2007 | X-Micro Technology XWL-11GUZX (XWL11GUZX)...
Belkin F5D8236-4 Router Logo
588 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
