Question about IBM ThinkCentre M51 PC Desktop
I have an IBM ThinkCentre m51, no os installed and it has the wrong BIOS. It boots up but keyboard & mouse are dead so it seems like I cannot flash the bios, check it or install anything.
  • 1 more comment
  • troubles988 May 05, 2010
    This is a friend's computer, probably around 2005, and I undertook, with a mistaken impression, that I could "fix" it. I have no idea what the bios is but I downloaded a "flash bios" for a M51 IBM. However, I cannot even use the keyboard to designate the "1" for English, no it will not give me a keyboard or mouse or Floppy drive. I can install MS-DOS with the CD/R but still no keyboard or mouse.
    Now, when I take MS-DOS off & insert the WINXP home setup disk in, it tells me it is not a system disk.
    Also, I can use Acronis partition disk ... and the keyboard and mouse work. This is a ISO disk, So I tried a ISO of the BIOS ... no luck.
    Update: I unplugged the battery, left it out a while, computer booted up, I was able to get into BIOS.
    MODEL: 81432BU; Boot Block REV level: 2B42A; Bios Date: 04/05/05; Flash: 2BKT42AUS but that still does not tell BIOS unless it is the FLASH # ... and it tells me non-system disk when WINXP setup is in the CDR/RW drive.
  • chandrakanth reddy May 11, 2010
    which BIOS are you using and what is the BIOS version?
    Problem Solver:
  • 17 Answers
Try removing system battery on MB for about a minute and reinstall. Some units have a jumper pin for reset on MB also. If that does not help, your MB may be bad.
Posted on May 05, 2010
  • tom1wookie May 05, 2010
    Are you absolutely positive you have the mouse and keyboard plugged into the correct PS/2 ports. One is usually green & and other purple. Windows XP Home disk should boot up unless there is no CDRom showing in the boot bios setup. Normally you can get there by holding down the delete key on boot up.
    The only other thing I can think of since it sees your CD but says it is not bootable is that it's scratched or something or your optical drive may be bad. You would have to see if the CD boots in another computer to validate it.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 68 Answers
I think that try to change the keyboard or try USB keyboard if USB port are available.
Posted on May 07, 2010
I enabled Legacy free on bios and that disabled PS/2 Port mouse and keybord so that I Can't have access to my BIOS to reconfigure it.Please, help me.
you might try resetting the cmos
then you might try using a usb keyboard. I use a usb wireless keyboard with a touchpad and it does the job. Good luck. After you clear the cmos and then turn it back on it should start re-decting the hardware.
Feb 12, 2016 | IBM ThinkCentre M50 8187 Intel Desktop PC...
Tip
As some of you know.. Circuit City stores are closing for good all around the...
let the user login the computer.
goto cmd via run.
enter " net user"
the whole list will come out containing the administrator and guest.
then type " net user guestname or adminname"
then type " net user guestname or adminname * "
it will then ask you for new password type it and in this way it will work.
on Feb 26, 2009 | Gateway GT4022 PC Desktop
IBM ThinkCentre M51 does no boots
different pc has different bios beeps depends on the bios manufacturer, but in your situation it is most likely you have problem with your video device. is it connected in video card or directly plug in the built in video port of the pc? if its connected in video card, remove video card temporarily then connect it to built in video ports, or vice versa, if your in built in video port you can try testing it with video card in pcie slot.
Feb 28, 2014 | IBM ThinkCentre M51 PC Desktop
IBM ThinkCentre 8183 (M51) does not boot
I think it is more than likely your hard drive is the problem, you get the splash screen and everything is working up to that point which tells me the motherboard is fine.
Jul 07, 2012 | IBM ThinkCentre M51 PC Desktop
I am trying to load Ubuntu 11.04 on my ibm thinkcentre M51. When I do ...Ubuntu will load.....the computer will shut down and reboot every time...Please Help...
CHECK WHETHER DUAL OS ARE RUNNING IF THE DUAL OS ARE RUNNING WE CANT GUARRENTEE THE EXECUTION OF UBUNTU.IT IS BETTER TO TRY FEDORA DESKTOP THIS PURPOSES SIMPLE TO INSTALL
Sep 03, 2011 | IBM ThinkCentre M51 PC Desktop
My ibm thinkcentre m51---8143 will not work with f9 or f10 save and exit settings
If you are talking about bios settings, is your cmos battery dead?
Aug 04, 2010 | IBM ThinkCentre M51 PC Desktop
ESata drive not recognised by Windows XP
need to go in CMOS an
set non raid use sata mode for eSTAT ports in bios
Apr 17, 2009 | IBM ThinkCentre M51 PC Desktop
Bios upgrade
Go to this link:
http://www.ibm.com/Search/?q=ThinkCentre+M51+PC+Desktop&v=16&en=utf&lang=en&cc=in&Search=Search & search for your update which u will get access to after a simle registration where all u got give is Your Product NO, Model & Sr. No. & carry on safely from there. However my suggestion is not to update BIOS unless u are facing any problems and have been asked on some error message...............sodeep
Mar 28, 2009 | IBM ThinkCentre M51 PC Desktop
IBM M51 ThinkCentre doesn t recognize 4gig installed memory
You can confirm this in the BIOS and i'm sure it will show 4GIG. Your Operating system maybe a 32 BIT OS, hence it will only show about 3... GIG. It's a limitation for a 32 BIT OS.
Mar 06, 2009 | Computers & Internet
IBM ThinkCentre M51 PC Desktop Logo
833 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
