Black pages when printing
I have a Xerox model 5305 copier and the copy pages come out all black. I've cleaned the copy drum and replaced the toner cartridge but that doesn't solve the problem. I don't want to replace the copy cartridge unless I know that that will solve the problem.
    President:
  • 2,072 Answers
Are the lamps comming on, and on brightly? They may need replaced.
You may also have a bad ground contact to your drum cartridge.
Remove the cartridge and clean the contacts. The ground contact may also be worn out.
Those are the 2 most common problem with black copies on that machine
Posted on Mar 26, 2008
I have a Xerox XC820. I am getting dark copies with residual images from previous copies. Toner appears to be adhering to the drum cartridge. Do I need a new drum cartridge?
I have a Xerox xc820. The drum kit needed to be replaced, which I did as well as put in a new toner cartridge. The pages are now coming out very dark. Prior to putting in the new drum kit and new toner cartridge, the machine ran fine. I have tried all I know how to do and to no avail. Have cleaned the "wire", all the parts I can get to and cleaned the plate. Any help would be appreciated.
Apr 21, 2012 | Xerox Office Equipment & Supplies
Xerox 5305 does not feed paper
Those old babies just keep going! You need some serious TLC. And, a feed tire no doubt.
Jan 29, 2011 | Xerox 5305 Copier
Just purchased a Zerox XC1255 Copier at an Auction. Replaced the toner cartridge because the light was on. The copies seem to have excessive toner in the background of the copies. I am wondering if I...
Could be a bad drum unit. Is the new toner cartridge a refilled? Remanufactured? or Brand New Xerox brand toner? If it is refilled or remanufactured I would run some copies and give it a chance to clear. Sometimes they end up with too much toner in the Developer mix and can be overtoned which causes a general background over the whole page. They should clear up as you run copies, say within 100 pages. Also try manually lightening the copy with the exposure control on the operation panel. If lightening the copy clears all of the background then you need to have the optics cleaned. There are 4 mirrors under the large original glass that need to be cleaned. If all this fails then you are looking at either drum unit or a defective or out of balance toner/developer cartridge.
Good Luck and Thank You for using Fixya.
Aug 18, 2010 | Xerox Office Equipment & Supplies
Black streaks in copy. i have cleaned the drum and replaced the toner cartridge. anything else to try for this older xe80/xe82
You cleaning blade for the drum may be needing replacement, mite have some harden toner on the cleaning blade alowing toner to run around the bad/hard toner leaving streaks
Jul 23, 2009 | Xerox Office Equipment & Supplies
My xerox 5201 copier is making black copies. I
Xerox Copy Drum Cartridge 13R83 / 6R737 (20000 Page Yield)
Xerox brand - works in Xerox XC 355 XC 356 5201 5203 5205 5210 5220 5222 5305 5306 PRice is 135.00.. Post response if you want link to site. This will cure your grounding problem. You Cannot fix it, It is a consumable item and has no serviceable parts
Apr 03, 2009 | Xerox Office Equipment & Supplies
Copies of xerox copier model 5201 almost black
USUALLY Black copies are a Drum grounding problem. I have not seen "black" copies due to old, bad, or otherwise inferior toner... Although, It is a Xerox, LOL
Apr 03, 2009 | Office Equipment & Supplies
Xerox XC1020 White Bands running across copied page 4" apart
The metering blades in those cartridges go bad and do not allow the ink to get to the page. Look at the front of the toner cartridge, is should be a solid consistent black all the way across, if its streaky, not consistent all the way across replace the toner.
The other problem could be a dirty laser. If replacing the toner doesnt work let me know, I will tell you how to remove and clean the laser.
Jan 16, 2009 | Xerox CopyCentre C20 Black and White...
Xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Feb 27, 2008 | Xerox 5305 Copier
Streaks on copied paper
You have a failed drum cleaning blade that lives in the drum cartridge. The blade is replaceable as a seperate item.
Jan 31, 2008 | Xerox 5305 Copier
177 people viewed this question
jasbo
jasbo
