Question about GE Refrigerators
My inside light is not working or my ice and water on my profile bottom freezer side by side
  • bcs2720 May 05, 2010
    my lights at the control pannel are on as is the little blue light at the produce drawer. the fridge seems to be cold enough. the ice and water dispensor is inoperable like the fridge thinks the door is open. i also know if the door is left open for a longer than normal time the light inside is suposed to go out but my doors are comletely closed. one other clue is that the freezer light was working when i opend the freezer but now it stopped also.
    my control pannel is still on but now i realize the fridge is not running and it is getting warm inside it. is it time to call for someone to come look at it. my gues is its the computor that operates the fridge is malfunctioing
  • 5,081 Answers
Does the unit RUN? or only light is the problem?
CONDITION 1:Unit does not run. No light in refrigerator.
CAUSES:
  • No power at AC distribution panel of house
  • Defective AC outlet.
  • Open circuit to AC outlet.
  • Defective service cord plug.
  • Open service cord or open machine compartment wiring harness.
  • Two simultaneous problems light bulb out and open AC circuit to compressor.
CONDITION 2: Unit does not run, light inrefrigerator works.
CAUSES:
Temperature control.
-- Defective or adjustedincorrectly.
-- AC circuit open to control.
• Defrost timer.
-- Defective (contacts completing compressor circuit are open).
-- AC circuits open to timer(motor winding or contacts).
-- May be defrosting.
• Overload protector.
-- AC circuit open to overload.
-- Defective overload.
• Starting relay.
-- AC circuit open to coil (overload does not click).
-- Defective relay.
• Compressor motor.
-- AC circuit open to compressor.
-- Defective compressor (overloadmay or may not click depending upon what is wrong with compressor).
• Low line voltage (overload will click on and off as unit tries to start).
Posted on May 05, 2010
  • INDIRA KUMAR
    INDIRA KUMAR May 05, 2010
    There has been an short circuit oon the control board..This has to be identified using a continuity tester/ohm meter.
    Just check the continuity in the circuit board using them if you have electrical working experience...
  • INDIRA KUMAR
    So only i asked you to check the control board . It has all the controlling components in the fridge.If satisfied please accept my answer and rate me good.
GE profile side by side refrigerator wont defrost
Inside the fridge behind bottom drawers there is a heat element that has stopped working.You will see it is covered with ice.you will need to replace it and totally defrost both and restart.
Oct 23, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
We have a ge profile refrigerator and there is water leaking on the left side under the freezer. The inside of the ice tray has tan colored gunk on the ice and the bottom shelf of the freezer has a 1/2 in...
manually derfrost fridge/freezer,clean with bicarb only...... dry as best you can.(important) clean drain hose fill freezer from top with any spare space filled with foam in plastic bag(s)looks awful but works a treat (cheap too)invest in a freezer thermometer minus 20C IS BEST.....
Feb 07, 2010 | GE Profile 20.7 cu. ft. CustomStyle...
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ge profile side by side
To change the main PCB is relevantly simple as it is situated on the back of the appliance under a metal cover held on by about 9 screws. I would double check that the light switch is working properly also as i have experience of poor connection on the light switch terminals causing issues with not dispensing.
Aug 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Front dispenser On GE stainless side by side
Could be the connector at the bottom of the freezer door corroded but it could also be the main PCB failing as the low voltage power supply may be dropping out . By the 'light inside' do you mean in the dispenser or inside the fridge ??
Aug 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
Dispenser on freezer door
Check the electrical connector at the bottom of the freezer door for corrosion and if it is not that then the main PCB is failing , when it fails the appliance will stop working altogether although the lights will still work inside.
Jul 17, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
