Question about Samsung Televison & Video
Entire bottom half of tv screen is black - Samsung Televison & Video
  • 122 Answers
The vertical deflection circuit needs repair.capacitors first fuse resistors or the power ic.
Posted on May 05, 2010
I have the top half of a screen the Bottom half is black,how do I fix this?
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 21, 2012 | Sanyo DP50749 50 in. Plasma TV
Bottom half of screen black on plasma tv
Either there is bulging capacitors on the main power board,or the Y Board lower is faulty. If the entire screen was black I would lean toward the Y Main Board,or if the upper half was black then i would say the Y Buffer upper board is defective.
Oct 31, 2009 | LG 60PG60 60 in. Plasma HDTV
Screen was going red on the top half of the screen, then..
The Y buffers were going bad, sounds like they went , you should get the Y upper and Y lower also the Y main. be aware the screen may be bad but tou won't know till you try the Y boards,
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 23, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Black rectangle on bottom half of screen
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
Black Square in bottom half middle of screen
It sounds like your panel is going out and time for a new TV
Nov 30, 2017 | NEC PlasmaSync 50MP1 50 in. Television
Half a screen
The picture on your TV screen is driven from the center to the top and bottom of the screen by the vertical drive circuit. The fact that you can see the entire picture means you have a problem called foldover. This is caused by a failure in the vertical drive circuit where the vertical saw signal is altered by a component failure within the vertical drive circuit. You cannot solve this problem but any good repair shop should be able to correct the problem at a reasonable cost.
Jun 22, 2006 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
44 people viewed this question
Jerry Greenberg
Jerry Greenberg
