Question about Brother MFC-685cw InkJet Printer
Printer filter pipeline host stopped working
Cannot print and the message says "Printer Filter Pipeline Host has stopped working" Brother MFC685-CW
What can I do?
2 Suggested Answers
Jimsta01
  • 405 Answers
SOURCE: The pop up "Print Filter pipeline Host stopped
Try the following:
1. First, try printing a different PDF file - if it works proceed to number 2 below.
2. Now, rename the resume file and then open and print the file - see if it now prints.
3. If the above does not work, perform the procedure at the link below.
http://social.technet.microsoft.com/Forums/en-US/itprovistahardware/thread/9a0d9f62-b3b4-4a61-861d-8857af1dc6d9/
Posted on Jun 16, 2010
The pop up "Print Filter pipeline Host stopped working and was closed" stops me printing when I want to print photos from a picture file? The printer is a Brother MFC 680CN
Try the following:
Jun 15, 2010 | Brother MFC-685cw InkJet Printer
Cannot detlete corrupted printer software
That is correct, it was not installed correctly. Try running setup and choosing FULL and if you get a note that says "Has already been installed" then look for an option to 'reinstall anyway' If that should fail, contact Dell.
Aug 28, 2009 | Microsoft WINDOWS XP PROFESSIONAL SP3...
Toshiba e studio166 shared printing problem
try adding printer and browsing network for printer, it should see the host and printer and add using correct network path, if you don't see host computer "print server" then you aren't on correct network path
Jun 24, 2009 | Toshiba e-STUDIO166 Printer
Every time I want to print I get an error message about the pipline filter. This is so aggrevating I want to throw it through a window. I have homework to do and now can't! . Can anyone tell me how to get...
I did some research and is sounds like the Print Filter Pipeline Host error message has to do with the Non-English Version of .net framework. Download and install the files below. Try to download and install these files in lowest to highest order. All versions are needed to make everything work correctly. Make sure you also have the latest Java.
Jun 10, 2009 | Dell 968 All-In-One Printer
Dell 968 printer not responding message please help
try unplugging the printer and plugging it back in, also do you have the printer set as the default printer
Apr 26, 2009 | Microsoft Office Professional 2007 Full...
Samsung ML 2010 under mac os X 10.5
I found a solution that worked for me by prowling around various Apple discussion forums. The two keys to the solution for me were numbers 3 and 5 below.
1. Opened print/fax preferences
2. Opened Add printer by clicking the +
3. For protocol, select HP jetdirect-socket (not IPP or LDP)
4. Determined the IP address for my Belkin wired print server and typed this into the Address line of printer setup
5. Manually selected the printer driver as ML-2010. It is in the list of drivers but is in the M's, not under the Samsung drivers.
6. This worked for me. I've seen reports from people who had to power cycle their print server and/or printer as well.
Jun 22, 2008 | Samsung ML 2010 Laser Printer
Laserjet 1000 & DI-524UP
The HP LaserJet 1000 is a Host Based printer and so is not compatible with your router's USB print server.
You cannot use this printer with this print server, it needs to be connected directly to a computer that can run the HP drivers/software.
From D-Links tech specs for your router:-
** Host-based printers are not supported. Please check with the printer manufacturer if your printer model is host-based (GDI).
Feb 06, 2008 | HP LaserJet 1000 Printer
Brother MFC-685cw InkJet Printer Logo
281 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
