Question about Linksys Wireless-N WRT150N Router
Router is blocking a site
My router is blocking dwyco site i can't connect how do i by pass it
  • mbcountry Apr 21, 2008
    sorry but that didn't work
    Scholar:
  • 133 Answers
If you can then just reset your router to factory reset option on your router's backside
if you want to go manualy
1 connect any pc to your router
2 go to internet explorer
3 type 192.168.1.1 (which is default ip address for any linksys router)
4 once got access of your router
5 go to access restriction in router
here you can find blocked services / blocked sites and blocked urls find out your services and remove it from that list
and save setings and restart router
Posted on Mar 26, 2008
SOURCE:
How do block facebook port
Try using the parental control tools on your router to block it. As FB uses https:// the connection is encrypted, The router cannot see the URL accessed. Don't block https:// in general as you will not be able to access sites that uses a secure connection, ie Amazon, your bank, etc
Oct 25, 2013 | TP-LINK TL-WR941ND Wireless N Router -...
How to block websites from belkin54g f5d7634g wirless router
Login using username and password
This will take you into the router administration settings.
There should be a Category "Content Filtering" or "site management" on something along those lines
Click on it and click on the sub-category "Block sites". At this point you are usually prompted to type in your router password again.
Simply type in the domain name of the site you want block or type a keyword which blocks any site you try to access containg that keyword in its domain name.
This will cover any device eg laptop, phone, ipod, tablet connected to the network cannot access these webstites because they have been blocked through the administrator so are blocked on your network.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 03, 2013 | Computers & Internet
BLOCKING WEBSITE USING WIFI
You want to block website ??
login using username and password
Jan 03, 2013 | Belkin Wireless Play Max Router (F7D4301)
I am having difficulty connecting to Cisco VPN, could the router be interfering with this
The router could be blocking it. On your belkin router, check to make sure that ipsec vpn pass through is enabled.
Mar 18, 2011 | Belkin Basic Wireless Router
When I try to connect to a lot of site this sentence appear on the page: You have tried to access a site that has been blocked by the 3Com Router. Please contact your System Administrator to have this...
Seems as though whoever installed your router set it to block those sites. You will have to connect straight to router with data cable and set it up again. What model is it? Try going to web site looking up model and find setup download: http://search.3com.com/search/en_US/query.html?qt=Setup&col=supp
Feb 22, 2011 | 3Com Computers & Internet
Blocked facebook via router
You can't really get round this easily.
But to by-pass the problems you can
1) reset the router to factory defaults... you will need the username and password for this for the router which are (depending on your version)
Username: admin
Password: password
or
Username: admin
Password: admin
Then set yourself up as primary account holder - you will also need the ISPs log in details.
Alternatively, use a web proxy server to connect to facebook. I reccomend SSLUnblock but for others you can find a nice list of proxy servers here.
If this helped you then please help me and vote kindly, thank you.
Oct 15, 2009 | NetGear WGR614 Wireless Router
Can't connect with roomates wrt160n....
try renewing the IP lease by going to the command prompt and typing ipconfig /renew
Sep 01, 2009 | Linksys WRT160N Wireless Router
Vpn site to site
you need to create an IPSec tunnel between the router and windows server 2003 (run secpol.msc). From the dlink router, you need to set the IP address of the VoIP gateway as part of the LAN that is included on the VPN tunnel. Since it is the server 2003 that has a static IP, you need to initiate the connection from the Dlink router.
Jun 23, 2009 | D-Link Express EtherNetwork DI-LB604...
How do I configure site to site VPN on a Netgear Router?
Well the VPN connection would have to be setup on your PC at home or where ever you are... VPN will pass-through if your router allows that... Also the VPN connection would have to be accepted by the remote server or computer that you are trying to VPN into
Apr 02, 2009 | NetGear RangeMax WPN824 Wireless Router...
Router not blocking specified site.
There are a couple ways you can do this.
  1. Check the obvious and make sure that if you are blocking by DNS name that you have included wild cards to handle any virtual hosts running on that domain and that you are blocking all ports that could potentially generate the content, not just port 80.
  2. Make sure that you do not have spy ware locally on the LAN PC's that is connecting you to the site or broadcasting content. If you are initiating contact with the server from internal PC's then your inbound policies won't matter.
  3. If all else fails and you can trace the site to an IP, you can always block the IP on your router directly for all ports, set the etc/hosts file on each machine in your organization to redirect that IP to localhost, or set your DNS server to redirect that name/ip to a fake IP internally.
Jan 26, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless-N WRT150N Router Logo
103 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
