Question about Power Acoustik PTID8400 Car DVD Player
Is there a code to overide the brake setup - Power Acoustik PTID8400 Car DVD Player
Just wire the pink to the black ground wire to override it. problem solved
Posted on Sep 04, 2012
Where is the shift lock overide reease button on
should be able to shift when u press brake pedal, if not press pedal and see if brake lights work if brake light switch is bad this can effect the shift control. if this is not issue then the shifter is jamming and the stifting linkage is most likely worn or out of alignment and should be repaired
Oct 30, 2009 | 1998 GMC Savana
Video willnot play
there is a brake overide option in the serive menu that you can enable that will allow you to view videos while in motion. without having to connect the parking brake wire of the screen. just follow these directions
you will need the remote control2.gif to do so.
1.turn the radio on and select the setup menu.
2. while in the setup menu, use the remote and press 5-4-3-2-1-0, this should access another service menu.
3. from there, you will see a brake override option.
4. and your done.. hope this helps
Sep 13, 2009 | Jensen VM9510 Car DVD Player
My 2005 chrysler 300 limited is stuck in park and wont move. What's the problem ?
i have come across this in my shop already. a small piece in the shifter and a spring break loose. it is common. the entire shifter mechenism has to be changed
Aug 30, 2009 | 2005 Chrysler 300
I need the overide code for my ps2 that I brought used
Here is the procedure to reset the parental lock code:
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under GA_googleFillSlot("TL-IMU-Article"); custom setup.
  2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
  3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings
Nov 18, 2008 | Sony PlayStation 2 (PS2) Console
Shift overide button on 91 corolla...
you probably got no brake light in the back if no brake light that mean no power to brake switch that why you have to use the overide button check the fuses to make sure you put it at the right place or burn fuses also at the brake light switch broken wire hope this help fixya our post thanks pierre
Jul 12, 2008 | 1991 Toyota Corolla
How do i watch movie while driving
go to the radio press setup on your remote then press 543210, a secret screen will pop up press the hammer and skrewdriver,u will see brake overide put it on the on position,thenpress the X at the bottom of the screen,then your all set.
Jul 07, 2008 | Jensen's VM9312 Car DVD Player
Video monitor bypass
Mar 26, 2008 | Jensen VM9411 Car Video Player
Vm9312
Jan 13, 2008 | Jensen VM9510 Car DVD Player
How do i do to bypass my jensen vm9312
go to www.ecoustics.com then click on forum at top click car audio then multimidea. and read Teir are bypass codes for several models here.just have to look for them.
Dec 18, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9412 Video BYpass
The solution that was givin for vm9412.
going to SET UP
Then Language.
Then on your remote push 543210.
Press the Hammer & Screwdriver symbol.
Click on praking brake overide and turn it on.
Then hit the X at the bottom of the screen.
And say good bye to the pink wire bs & ground.
This solution was awsome it only took one try very easy!
I Give total props to FixYa.
TTTHHHAANNKK UUUUUUUUUUU !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 30, 2007 | Jensen VM9510 Car DVD Player
Power Acoustik PTID8400 Car DVD Player Logo
65 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
