Question about Ovens
We have a Frigidaire slide in ceramic stove model CPES389CC1 and I just heard a loud pop and then the power went off. It tripped the circuit breaker for the stove and the main circuit breaker for the whole house as well. the elements work but the display only reads only half of the PF for power failure and half of the clock and it keeps blinking and none of the controls work.
  • 523 Answers
Replace control
Posted on May 06, 2010
While preheating my electric frigidaire smooth top oven, we heard a loud pop and saw a flash. The breaker had tripped. After resetting it, the clock and digital features still work, and so does the st
I appreciate your inquiry, Stephanie Givan!
From what you are describing it sounds like a possible short with your breaker box or issue with your terminal block within your Frigidaire range. I would recommend reaching out to a professional technician for a proper diagnosis to be completed. The technician will have the correct tools to check for any electrical issues within the range to make sure the correct component is being replaced. This will help avoid any unnecessary part purchases. -Matt
Nov 12, 2014 | Frigidaire Ovens
Oven stopped working
If you are saying that the breaker in the breaker box has been tripped, then there is a problem with the circuit or in the stove. The circuit may be checked with a volt meter. If the problem is in the wiring circuit, the breaker will trip with the stove unplugged. The problem is most likely in the stove, and the stove's wiring needs to checked. If you are unfamiliar with 230V wiring and how to safely test the wiring, have an appliance technician service the stove.
Apr 15, 2014 | Ovens
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
When I had two of the stove top burners on and I heard a loud pop. Now nothing works. The oven or stove. What should I do?
sounds like a wire may have shorted. This will trip the breaker or fuse, which ever you have. It will possibly burn the wire in 2. Need to check for separated/ burnt wire.
Jan 19, 2010 | Ovens
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven will not heat
Although I am not familiar with this oven, living in the u/k, I would say that without any doubt the oven element(s) have failed, more so if the fan is working, so I would have hesitation that you replace the suspect element (s)..
Plz let me know how you get on.Thanks.
Jan 03, 2009 | GE JKP15 Electric Single Oven
FEFL78CQA FRIGIDAIR ELECRIC STOVE
Unplug your power cord from the socket outlet.
remove the back cover where the power cord connection is housed. visually check the connection, expose wire harness might touches the cover somehow. or the cover was dent that causes the bare wire to touched the cover. correct the dent if any, or tighen loose wire.assemble back cover. Reset your circuit breaker to your Stove because the pop sound might trip off your breaker. That should solve the problem.
Jun 28, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
311 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
