Question about Sub-Zero 15.3 cu. ft. / 433 liter Upright Freezer 700TF
Just Bought used Sub Zero 501 F Freezer
Condensor fan starts and the compressot trys to start but acts like it is timimg out. I did move it horizontally but have had it vertical for 3 hours plus to allow for the oil to settle.
I did give it a good bath so there may be some lingering moisture still hanging around.
  • 523 Answers
Got to a parts store and get either an over load or a three in one for it then try it
Posted on May 05, 2010
My freezer drawers are very warm All food defrosted smells horrible even after cleaning. Should I clean condensor, temp is not cooling?
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jan 01, 2013 | Sub-Zero 700 Refrigerator Freezer...
Sub zero freezer - 501 f
It is likely the condenser fan is not functioning. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jun 19, 2012 | Sub-Zero Freezers
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
May 04, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Our sub zero refrigerator compressor kicks on for about 30 seconds then kicks off. The freezer is not working properly
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 06, 2011 | Sub-Zero Freezers
I have a Sub-Zero 501 F upright freezer. I have never hooked up the ice-cube maker. There is a problem with ice build up in the drain tray and it overflows into the ice-maker. I had a tech in and he put...
sounds like the mullion heater (drain tube heater is open). take back off (after removing all shelves, including the glass tray (remove 4 screws). Pull back out, careful not to pull wires off T'stat. Run the new wires on heater behind evaperator, placing heater down in drain hole. Good Luck
Joe
Aug 09, 2010 | Sub-Zero Freezers
Sub zero freezer door no longer vacuum seals when the door closes. There is nothing obstructing the door.
Make certain that the freezer fan motor is operable. Otherwise, contact an appliance service company.
Feb 20, 2010 | Freezers
Temperature goes up
do you hear any fans running?  by the temp staying cold on the drawers whih are in the lower area of the freezer it indiates to me that the fans are inoperable. to test open freezer door then push in light switch by hand and listen for the fans to come on. if it turns out you have bad motor you most likely will have to call a sub zero dealer to have repaired. messge me back with any questions peyton
Jan 28, 2009 | Sub-Zero Freezers
Freezer always on
If the display reads -20 even though the freezer is set for 00, shut the unit off. If you can still hear the freezer compressor running, the board has a stuck relay for the freezer compressor. You will need a new board.
Jan 20, 2008 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Sub-Zero 15.3 cu. ft. / 433 liter Upright Freezer 700TF Logo
154 people viewed this question
Top Sub-Zero Freezers Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Roderick Scott
Roderick Scott
Are you a Sub-Zero Freezer Expert? Answer questions, earn points and help others
