Question about HP Compaq Presario CQ60Z Notebook
Shut down issues with windows vista
When trying to shut down windows vista, my compaq computer hangs on the "shutting down" screen and I have to push and hold the power button to turn it off. How can i fix this?
  • 808 Answers
Use reginout regcleaner it will automatically fix ur problem
Posted on Aug 19, 2010
    President:
  • 2,666 Answers
Install XP
Posted on May 05, 2010
4 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Incomplete Boot-up of Compaq Evo N800c running Windows XP Professional.
Your problem is not a capacitor problem, that is so remote of a possibility it is it's a one in a million!
I Have read all the info here and find Darklord has already posed the correct solution (with explaination) 3 days ago,
Have you since verified hard drive and I'm just missing that fact?
Posted on Jan 10, 2008
askmenow
  • 22 Answers
SOURCE: Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
Posted on May 19, 2008
  • 156 Answers
SOURCE: Compaq C500- Will not turn on
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
   and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Posted on Oct 23, 2009
I am having a problem with shut down the computer.After shut down command it displays windows will shutting down and hangs but will not shut down i need to press the power button to shut down(My computer...
Something is not closing on exit. Try running in safe mode, then shut down. If it shuts down then something is loading and present in the taskbar which isnt closing down.
Dec 19, 2010 | Computers & Internet
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
Safe mode
Get windows 7, or downgrade to xp. lol kidding. During the start up, i beleve its either f11 or f12 press them it should bring you to a boot screen. follow option. or you can use the compaqs built in recovery system. reinstall your system. vista has a option to save its old files for transfer.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
I just bought a sony VIAIO today and dont knoiw hoiw to shut it down
1. Normal shutdown: select Start - Shut Down - Shut Down
2. System hangs: select Alt-Ctrl-Del and then Shutdown
3. If #2 doesn't work - hold the power button until the screen is dark
Hope this helps.
Aug 17, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
But notify me when critical errors occur
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
May 05, 2009 | Acer Computers & Internet
Computer hangs up on shutting down screen
Ok.....
1. Make sure ALL user accounts are logged off!!!
2. UPDATE ALL DRIVERS
3. Check to see how many Programs are running while attempting to Shutdown the PC..(the more programs it tries to close, the longer it can take...(ESPECIALLY WITH LOW AMOUNT OF RAM/SLOWER RAM)
Mar 22, 2009 | Toshiba Satellite Laptop with AMD Athlon...
Presario desktop windows vista, shuts down unexpectedly
Windows Vista will not install on old computers. If this is your case try installing Windows XP, If this does not work you might want to try Linux (Ubuntu). which will run on almost any old computer with full capabilities.
It is free and you can download it from
http://www.ubuntu.com/
Feb 26, 2009 | Computers & Internet
Shutting down
Look...maybe the processor cooler is dusted.If the processor get to varm hes shut down.
Nov 22, 2008 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
HP Compaq Presario CQ60Z Notebook Logo
74 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
