Question about Jackson Dk2m Dinky Electric Guitar
I change from emg hz to emg 81 & 85. i have problem wiring the 3 way switch. i need a diagram. Some body can help me please? Thanks.....
  • Jackson Master
  • 5,603 Answers
Original Floyd rose, emg 81, black with yellow, new condition,
We will needthwe make, model, and country of manufacture to help you. Remember Fixya does notlink your questions, so restate the info in this question when you post your follow up.
Jan 05, 2016 | EMG Music
How do i wiring an active pickup and a passive pickup in same guitar
Not hard - just wire up one pickup and leave the other one alone. The active pickup will have wires that say "output + and - " - just use those to connect to the same place you would attach a passive pickup. Also, an active pickup will need space for a battery (9v). I weould consult EMG pickup installation for diagrams. You will also probably need to replace the guitar jack with a TRS, where the ring is a "killswitch" for the battery when the guitar is disconnected.
Try this diagram set: http://www.emgpickups.com/skin/frontend/emg-2013/default/pdfs/2-tw-2v-1t-only.pdf
Feb 14, 2015 | Music
My EMG 85' sounds great - but not on the first E string = virtually nil output !!!
Probably the iron core is out of place try laying the e string deeper if the sound gets louder de core is out of place maybe you can get in from the bottom part
Nov 21, 2014 | EMG 81-85 New Limited Edition Camouflage...
Guitar pickup at bridge (EMG 81) is not working
several things....First I would check your battery. second, check wiring to your switch to make sure the wiring hasnt come apart from the solder joints. From there I would test your switch itself to make sure it is still good.I have had switches go bad and only have one pickup work before.
Aug 21, 2013 | Jackson Rrtmg Randy Rhoads Pro Electric...
My s5470 does not sustain well at all.also,the bridge pickup sounds ok but lacks ''attack'' in upper register.great guitar otherwise.i use a peavy 5150 60watt amp.
I personally use Seymour Duncan Humbucker pickups, and have never been disappointed. You might want to take your guitar up to a music shop and try it on different amps to see if your amp is your problem, or if it is your guitar's pickups or wiring. You could also try adjusting the height of the pickups until the sound you are looking for is achieved. I have also had guitar cables make a big difference in the sound. Make sure you have a good set of cables, and you may want to adjust the EQ settings of your amp to make up what the guitar lacks.
Apr 15, 2011 | Ibanez S5470 Prestige Electric Guitar
Can i fit EMG 81 and 85 into my Washburn PS600 without much hassle or soldering? They currently have Egnator humbucker pickups installed as stock.
EMGs have quick-connect wires now so that part shouldn't be much trouble. You will however have to carve out a cavity for a 9v battery and wire it to the pickups (you might be able to put it under the pickguard as well) . If you are worried about this I suggest you have it done professionally.
Mar 09, 2011 | Washburn PS600 Paul Stanley Electric...
I'm think about buying an alexi 200 guitar, but i want to replace the esp pick up for an emg 81. Is there a place for the battery the pickup will require?
There should be enough room inside for the battery. If there isn't you could do some routing to the body to make it fit. I personally don't have this guitar but more than likely you can position the 9v battery to fit. To keep it from moving around, you can put a piece of sponge in the cavity.
Jun 09, 2009 | ESP Ltd Alexi 200 Electric Guitar
Jackson Dk2m Dinky Electric Guitar Logo
366 people viewed this question
Top Jackson Music Experts
Michial Gueffroy
Torashi
Level 1 Expert
rhodesworks
Are you a Jackson Music Expert? Answer questions, earn points and help others
