Question about Toshiba 56HM195 56" Projection HDTV
Toshiba 56hm 195 dlp. when turn on it is fine for 15 minutes then starts to flicker colorful ghosting around the screen. flicker will ramp up in speed then the color will fade out til it is black and white only for the most part. this happens over about fifteen to twenty minutes. then i will turn off tv and wait for blinking orange light to stop (about five to ten minutes) then turn back on and all is fine for another 15 minutes. this process repeats without fail everytime. (by the way if i try to turn tv back on before the blinking light has stoped it will still be messed up, i must wait for the orange light to go off.) what , where, how do i fix myself? thanks
  • thebocks007 May 05, 2010
    I think the previous tech misunderstood my problem. Once it reaches a black and white state, I myself choose to turn it off, because once the blinking orange light goes out and i restart tv, all is fine.(although i still only get about 15 minutes til it starts flickering and losing color again...) the previous tech thought i meant that the tv turns itself off. it does not. it actually never will, i could just watch it black and white all day, but resetting it makes it ok for a short time. thanks.
  • 10,515 Answers
There were 3 Reasons mentioned for the same for this Model and seen Frequently :-
1. Color Wheel - This is a Major Reason for the same. More often, whenever you would ON the TV, you would see Hear Humming or Ticking Sound.
2. This could be die to Power Supply Board. When the Part gets Hot, it could start to Fail and these Symptoms are Common. There are Certain IC's and Fuses, if Failed ( By Heat ) could Cause Flickering of Color or Loss of Color. You need to Check for Failed IC's.
3. Screen Panel is BAD. This is the Unfortunate Loss of Screen Panel. But, this is Very Rarely Seen on this Model.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 05, 2010
  • Toshiba Master
  • 12,061 Answers
Www.tacp.toshiba.com/tacpassets.../56hm195/docs/56hm195_spec.pdf
http://www.scribd.com/doc/22235534/Hitachi-Training-Manual-Projection-Television-DLP-1
Above is a service and training manual, this is what i use to teach engineers to service and repair these items... Your fault, is one, whereby, a component(s), is close to catastrophic failure, and the set is sensing, this increased current draw, and is shutting down, the Switchmode power Supply, to avoid, a fire, and explosion, or both, after it shuts down, the part cools, whatever, the "Fault" "Clears" and the set will startup up again, over and over, until eventual complete failure of the component(s), concerned fail. IF you wish to try to fix it yourself, and I do not recommend it. FIRST, you Must get a service manual, then you need, equipment, an Oscilloscope is a MUST HAVE. (It may be possible to do without?) Also a Multimeter, and soldering iron, a DE-soldering station, an anti-static wrist strap, (Any TV is extremely static sensitive). Now FIRST you must make sure the Power supply is 100% as if this is NOT then nothing else can be. Also there are safety considerations, any unit that can cause a Fire or Explosion, or both, needs to be attended to with the utmost care. As if it isn't done correctly, a catastrophe is indeed possible, Faulty sets can cause a fire, and a fire in the middle of the night, I believe is not good. And any person that has attended that set, will be held to account. Now with that understanding, I guess proceed if you wish. Troubleshooting say if it is shutting down, after a certain amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. Now just replacing boards will most likely just end up with more faulty, boards, as related you MUST ensure that you have the cause of the event, before we change anything. I have seen so called, "Techs" replace every board, and virtually every component, and that STILL didn't fix it, because the "Fault, or Cause" lay elsewhere, and had not be repaired FIRST, you see that FIRST STEP, like everything in life, is, CRITICAL.
Now if you feel that it you do not want to do it. It is my professional advice is to get you set looked at by a Toshiba Authorised Service Centre, and ask for free "Quote", this way, you will be able to make an informed judgment, as to repair or replace. As these days seemingly insignificant SYMPTOMS, often cost as much to repair as it may cost to buy.
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
Toshiba 56hm ic repair
The model listed here 56hm195 is a dlp and has no ic's for this issue.
Double check the model number on the rear of the set and let me know--if convergence the set will have a way in the menu to attempt to adjust--if it has that the model indicated is wrong.
Apr 01, 2012 | Toshiba 56HM195 56" Projection HDTV
I have a toshiba 56Hm 195 only half has picture
a PROBLEM likely to be either in the optical light engine or a separate digital board in the set---engine is more likely and a very expensive part not to mention labor.
Mar 18, 2012 | Toshiba 56HM195 56" Projection HDTV
I have a problem with a samsung model hln5065w 50"
it is due to more heat generation in ur board .i will cause serious accidents so repair it fast.
Nov 22, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a 46' viore ipt46dl30 and when it turns on all the screen is really flickery. and most the colours come up purple, but this goes away for about 5 ten minutes and the flickery purple screen comes...
Viore ipt46dl30
Same problem, cleaned color wheel, put a few drops of wd40 on bearings, worked good for two months.
Started flickering again, need to replace color wheel.
Feb 03, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Toshiba 56HM195 56" Projection HDTV Logo
185 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
