Question about Kenmore 24032\24036 Top Load Washer
Washer trips breaker when it gets to spin cycle
Works fine from beginning through rinse. once it hits spin, it gets stuck, you can hear the sound of a motor stuck and then it trips the breaker.
  • Kenmore Master
  • 43,501 Answers
The motor has lost the ability to turn the one way. when it tries to turn in that direction it cannot and draws high amps which kicks the breaker...
washer mootrs go one way for the wash but the other way for the spin...
This tip will explain it in more detail...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on May 05, 2010
My Kenmore HE2t washer is stopping about 8 minutes into the cycle (any wash cycle)..completely turns off. I can run rinse and spin then and it completes the cycle. No error codes when it turns off. W
htc sensor isnt working i would recon
perhaps the element isnt getting power
did it trip your circuit breaker
some times the htc fails
all you get is machine stop because the heater is not detected
if it spins rinses and empties in a timely manner
then all thats left is the heater system
Jan 09, 2015 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
Will Only Rinse/Spin with little to no clothes in drum
sounds like unit is activating out of balance lever thats y it works with no load in it .possible faulty suspension rods making bowl move too much.out of balance lever is at back of inside bowl to the right. try adjusting back feet to make them about half an inch higher than the front feet .that will move the bowl away from lever giving more tolerence. see how u go please reply 4 more help
Mar 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer fills but trips breaker when trying to start wash cycle. Does the same with rinse and spin cycles and when plugged into another circuit
Hi there
OK thank for writing to fix ya. Sounds like your breaker can't support your washer so you need to replace you breaker where it can handle you washer. just go up another 30amps on your breaker and try that. let me know how that goes.
Best regards Richard
Dec 08, 2009 | Washing Machines
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
MAH3000AWW Trips 20Amp Breaker at rinse cycle
The motor is known to have bad windings. Do a search for "Neptune Washer will not start" Also just inside the control panel where the start/stop sw is should be a paper folded with the diagnostics test and schematic. It is tucked under the pressure sw attached to the back. If not there then search "Maytag Neptune motor phase test" There is also a Service Manual FREE at Goetlieh's site.
Sep 27, 2008 | Maytag Neptune Washer
Washing machine has high amp draw
yes sounds like your motor is breaking down
Jun 15, 2008 | Washing Machines
WASHER AGITATES WHEN SUPPOSE TO SPIN
Faulty spin windings on motor. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 24032\24036 Top Load Washer Logo
103 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
