Question about Skil 2566 02 120V 14.4V Cordless Drill Usa
Drill does not work; battery ? not charging?
Have a Skil 14.4 V Lithium drill. 1st few times used, worked OK. Then was "dead". Bought a new battery. Again worked a few times then "dead" again. Charger was bad -- bought a new one. Still no luck -- charger blinks a few times then green light steady indicating battery charged. but drill does not work. Did the bad charger damage the batteries???? MJ
  • 1214 Answers
SOURCE: how to change drill bit
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Posted on Jan 28, 2009
SOURCE: skil cordless drill model 2362 - won't charge
I have the same problem. The guys at Batterries Plus told me that 7.2 volt battereis are not easily replaced and definately not through them. If you left it charging for to long (ie over a week when you were gone like me) then the battery is never gonna charge again. You might as well find the same model of dril at skil's reconditioned site for around $40 or buy a brand new one for $60 or $70
Posted on May 09, 2009
  • 15 Answers
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
something is wrong. take it back if possible.
Posted on Oct 10, 2009
  • 2428 Answers
SOURCE: Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion
You are the thrid person in the last couple of days with this same problem and i check who was posting the problems all differant people all RYOBI 18V lithium-ion batterys and they all got them for christmas. SOMETHING is not right there is now warranty on the batterys but there is one on faulty workmenship there must be a problem with this type of battery good luck
Posted on Jan 16, 2011
SOURCE: Two brand new Hitachi BSL1815X
These batteries have big problems that Hitachi doesn't address very well. Unlike NiCad batteries, Lith-Ion ones must be periodically used and recharged to retain their battery functions, i.e. if they have been sitting on the shelf at a store for an extended period of time, chances are they will be dead when bought and will not accept a charge. If they go dead i.e. no little red light on the charger when you plug the battery unit in...it's basically junk.
If you can return them or exercise the warranty do so. If / when you get new ones DO NOT completely discharge them like you would NiCads. Lith-Ion batteries do not have the "battery memory" issues that NiCads have which means you don't lose running time if you don't fully discharge the battery unit prior to recharge. Completely discharging before recharge will ultimately kill them. Use the 1815X till almost dead and then charge it. It is also recommended Lith-Ion batteries not be stored fully charged i.e. charge the 1815X fully, drive a couple bolts or screws, remove the battery unit and then put it away. Do not leave battery unit plugged into the tool when you put the tool away. This will discharge and kill the battery unit.
There are non-Hitachi substitute batteries now on the market. I'm guessing the same precautions apply but I don't own one of the replacements so I don't truly know.
The actual batteries in the Hitachi BSL 1815X are Sanyo UR18650SAX lithium ion batteries. Lithium Ion cells aren't all that easy to get commercially because of handling & safety requirements. Not certain if you can take apart the 1815X and swap out the bad Sanyo cells.
Posted on May 26, 2011
I have a Skil Model 2363 drill. Used it about 3 times. Put it in the charger and it won't charge. I have it for about 1-1/2 years. Skil says I have to buy a new one. That the battery is no longer made....
Sometimes places like Batteries + and the Battery Barn (on line web sites) will have replacement batteries for popular models even after the manufactures quit producing them. That is where I found batteries for my Bosch drill.
Jun 24, 2011 | Skil 2362 02 7.2 Volt Lithium Ion...
Hi my makita 18v impact driver seems to be getting alot weaker throughout the years, still works but no enough torqe
Lithium batteries have a limited lifespan, typically 3 or 4 years, and their capacity between charges decreases over the years.
To extend the lifetime of a battery it should be run completely flat after every few charges rather than topping it up. New batteries need to be charged several times and run flat under normal use before they gain their full capacity.
Apr 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Drill is less than 6mo. old and won't charge
Take it back where you bought it and ask for exchange. There will not be a problem if it is that new.
Mar 08, 2011 | Skil 2362 02 7.2 Volt Lithium Ion...
Power Driver is charged - won't work
If you are sure that battery is fine, problem can be in the switch or brushes. I would check switch first - open the driver, take 2 wires and attach battery directly to motor contacts, in case it works, problem is most probably in the switch. Juraj
Jul 11, 2010 | Skil 2362-01 Factory-Reconditioned 7.2V...
18V Litiom Batteries (Skil)
I would return it and tell them that the battery wont work.
Mar 02, 2010 | Skil 18V Lithium Ion Drill/Driver Model #...
Charged it and it stopped working
Here is the link to Skil. http://www.skiltools.com/en/CustomerService/ServiceCenters/
Call them and see what they recommend that you do. They will want to keep you as a valued customer. Regards, Joe
Jan 25, 2010 | Skil 2362 02 7.2 Volt Lithium Ion...
My SKIL 2362 will not work
Try the link.It's a PDF file for the tool you have.It will explain what you should do to store the tool and take care of it.Most likely the battery is no good and you will need a new one
Jun 19, 2009 | Skil 2362 02 7.2 Volt Lithium Ion...
Skil charger & batteries won't charge
The only thing I suggest is taking your Skil driver to a Bosch service center (Skil is now owned by Bosch) and they will replace the charger under warranty if the driver is less than a yr old. If not those chargers are not that expensive. Either way you need a new charger because they are not repairable.
Jun 10, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
I have a Skil 2362 7.2v drill that goes dead when charged
Sounds like the trigger switch is bad. If you know the charger is good and it is charging the battery, then it must be the switch. I suggest you take the charged battery and test it with a multimeter for the 7.2V. If the battery is dead, then check the charger.
Take it back to Lowes and get a different brand.
Jan 19, 2009 | Bosch Skil Drill / Driver Kit
Skil 2566 02 120V 14.4V Cordless Drill Usa Logo
70 people viewed this question
Top Skil Drills Experts
epangan29
Are you a Skil Drill Expert? Answer questions, earn points and help others
