Question about Kenmore Elite 45986 Front Load Washer
My Kenmore ELite washing machine won't move from the wash cycle to the rinse cycle Sometimes after unplugging and restarting it will work ok but this has been going on for some weeks now
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
I have a Kenmore Elite He3. It won't complete any wash cycle without stopping and displaying HF. I can restart it but it continues restarts the wash cycle again. Therefore a Heavy Duty wash cycle of...
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 31, 2011 | Kenmore HE2 Plus Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washing machine, Just stopped, small load didn't make it to rinse cycle. Lid switch clicks when I open and close, but cannot restart. How do I take top off and do youthink it is a problem...
The lid switch is a possible problem.Annother possibility is if the machine was shaking for some reason the power cord might have gotten unplugged from the outlet.
May 07, 2009 | Kenmore 24032\24036 Top Load Washer
Problem with Kenmore Elite 45986 Front Load Washer
machine stops before rinse and spinig. and then H and F flasing
Feb 18, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite top load washer timer will not rotate by itself through the wash/rinse/spin cycles
Gkar06,
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, Each portion of the wash/rinse/spin cycle work correctly, but you have to manually move the timer to each cycle.
This tells us the timer is bad and needs service to replace it!
You will be fine, it is not a big job!
If you like you can try this first!
Like with an error code.
This can reset the system if it is electronic!
Unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breakerto cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know!
Please remember to enter a rating before you leave.
Thank You
Sep 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
