Question about Kenmore Elite 45986 Front Load Washer
Holes in clothes
The washer is making very small holes in my clothes. it has to be the washer because i put a brand new shirt in the washer but not in the dryer.
this has happened several times during the last 3 months are so.
    Genius:
  • 1,554 Answers
Run a old hosiery or cotton wad (like from holloween) around the inside of the drum. see where it snags,
the drum is warranted for a very long time. (don't know exact)
Posted on Mar 26, 2008
My bravos washer leaves holes in my clothes. Brand new shirts go in and come out with holes
You would have to feel around inside of tub for sharp areas on the tub. If and when you find these areas you will need to make a repair some how. Also check your agitator, it may have sharp edges, or may be cracked. Good Luck Friend.
Feb 17, 2018 | Washing Machines
Amana 7300 Tandem
Check the drum surface of your dryer for possible object that may be stucked in the drum holes that may cause damage to the clothes. You may do similar checks of the washer drum if your dryer drum checked negative.
Good hunting.
Aug 21, 2017 | Dryers
MY LG DIRECT DRIVE WASHING MACHINE WD15517 IS MAKING SOME SMALL HOLES (5 to 10 mm diameter) OR PERFORATIONS ON MY CLOTHES. AT LEAST 5 shirts have been damaged. We have been using the machine for about 12...
You need a new drum. Those holes are caused by the sharp edges of the baffles which cause the clothes to tumble.
If you can find the sharp edge you could put epoxy putty on it. However if it is 12 months old, it should be a warranty issue as you have only just found out what is causing it.
See the link
LG washing machine support number Google Search
Mar 01, 2018 | LG WM2688H Front Load Washer
Maytag puts holes in clothes
try to change the soap and the washing cycle to delicate,good luck
Sep 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer making holes in clothes
Feel the drum inside for any sharp object example a pin that is sticking sideways in a hole or the the drum spot-weld spots that came lose making a high spot.
I did find the same kind of a problem with a Defy front Loader machine. You can also check the gap between the door and the drum lip.
Hope this will solve your problem and save yourself from spending big bucks on new clothes.
Clive
Apr 17, 2009 | LG WM-2277HW Front Load Washer
Holes in Clothes
You'll need a drill with a wire brush attachment and take that to the front of the heating element. The heating element gets a lot of crud built up on it and yes it'll put holes on clothes.
Apr 02, 2009 | GE DWSR405EBWW Electric Dryer
Holes in clothes
Inspect the rubber seal, and steel drum to make sure there is no foreign object sticking out, which could be tearing holes in your clothes. Also check to see if any of the holes in the steel drum are dented in. or out or misshaped, as this could cause the tumbling action of the drum to tear clothes.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Tiny holes in clothes
We have the same problem. Look at the agitators inside the washer. We found strings and material there. Not sure what or if there is a fix bout I just saw the problem 2 days ago.
Aug 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
My machine makes pin size holes in thin t-shirts and not other clothes. It has ruined several new shirts-help!
It's a nasty twisty thing, my dear. It happens in just about every machine. The only thing you can do to be absolutely sure is to put those thin t-shirts in a pillow case, Strap it closed with one of those "what's those hand-cuffy things called" things? and pray you don't get small pin-sized holes in your pillow case.
Mar 04, 2008 | Washing Machines
GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
May 03, 2007 | GE Energy Star WCVH6260F Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
409 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
