Question about Fisher and Paykel WL37T26D Top Load Washer
Water pumping in very slowly and uneven flow
The water sounds like it's flowing into the machine very slowly and unevenly to the point that sometimes the machine stops and I have to restart it. It took 3 hours to get through a small load. Pumping water out is perfectly fine and also washing motion and spinning perfectly normal. The only problem is getting the water into the machine. I switched it off at the wall power point and back on but that did not rectify the problem. Can you help me please?
  • Fisher and P... Master
  • 43,501 Answers
The washer filling so slowly can get very irritating and frustrating..most of the time the fix is very simple. The hoses have a screen in them to catch any dirt that may come in the water and this screen plugs up.
Simply unhook the hoses at the washer and clean the screens.
This tip will explain this in more detail for you..
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
Posted on May 05, 2010
Coffee won't come out of the machine, tried cleaning out the tubes but that just made it worse
You need to advise the model .. but assuming its the CVA 40XX series ... the frist thing to check is the dispenser which has the two pipes comming out of the bottom. This can get coffee residue build up which usually causes 1 or both pipes to have reduced coffee flow. Indication that this is at fault are if the flow is uneven between the pipes or if coffee flows down the outside of dispenser. You can chck this pipework for blocages by openeing door and blowing air though the pipe extending on inside of door. The the dispenser is blocked you need to remove from rear of door and then clean out thoroughly in running water. If this pipework is not and
You need to advise the model .. but assuming its the CVA 40XX series ... here is what I would do;
1. First check is the coffee dispenser on front which has the two pipes coming out of the bottom. This can get coffee residue build up which usually causes one or both pipes to have reduced coffee flow. The indication that this is at fault is if the coffee flow is uneven between the pipes or if coffee flows down the outside of dispenser. You can also check the dispenser for blockages by opening door and blowing air though the pipe extending on inside of the door. The air should flow through easily. If the dispenser is blocked you need to remove from rear of door and then clean out thoroughly in running water.
2. Next check the pump and water path. The pump for the coffee is also used for producing hot water. So if the hot water is working normally then you can rule out the pump. If you not getting hot water then its likely to be the pump or a blockage in the flow through water heater.
3. If above OK then it's a fault with Brew Unit. Follow procedure to remove the brew unit, clean unit and test the air path through both pipes by blowing. Note: When you take out brew unit it not possible to access one of the pipes because its protected by a plastic shield. There is a manual procedure to manipulate the brew unit to expose this pipe so you can blow through it. However the likely cause is not a blockage in these two pipes but the stainless steel filter that the coffee must pass through. You will need an Allen key to remove the bolt holding this in place. Once removed you need to check all holes are free of blockage by inserting a very small wire in each hole. Alternately you can replace this part. If the filter is clogged then you should consider using a different type of coffee as some types coffees cause this problem and others do not.
I hope this helps. regards
Mar 24, 2014 | Miele Coffee System
I have a Rancilio Classe 10 Espresso Machine and the water is flowing unevenly between groups. The difference between shots is 11 seconds to 27 seconds. I have backflushed each group and replaced both...
It could be the metering jets in the grouphead and or flowmeters. Try pressing both buttons at the same time to see if they give you the same volume and time.
Sep 21, 2011 | Rancilio Classe 10 Espresso Machine
How do you bleed the coolant lines of air after water pump replacement
some cars have a bleeder at the highest point you open and fill car slowly until you see water or coland flowing from bleeder .sometimes can take a whil e to get all the air out be patient with it
Sep 08, 2011 | 2000 Toyota Camry
Why does my washer start with a forcful stream and then cut doyn to minimum flow ?
Check for kinked or clogged water supply hoses(s). Be sure to make sure that if there is a screen-like filter in the supply hoses or at the inlet on the wash machine, that it is clear.
Shut the water supply off. Start the washer to fill on warm wash / rinse to relieve the water pressure in the hose. Shut off the washer. Unscrew the hose connection from the washer and direct both hoses into the washer tub (or other container). Turn the water supply on. Both hoses should discharge water evenly and forcefully, then shut the water off. If the flow was uneven, slow or poor - clear obstructions in / or replace the hose(s). Next, inspect the water inlet on the washer. Clear any obstructions, dirt, etc. Reconnect the hoses and try again. If flow is still lacking, there may be obstructions in water lines or valves INSIDE the machine.
I hope this helps - please rate my reply. Thanks.
May 06, 2011 | Craftsman Garden
My Rinnai is only 3 years old and just recently it is running out of hot water. It has been taking about 10 to 15 minutes for hot water to return. We have well water and we are unsure what the problem is....
The Rinnai relys on good water flow to fire it up. In saying that it runs out of water; thats actually not possible. The Rinnai just heats up water as it goes. Usually fault for installs on bore or well water is a problem with water flow. Causes are blockeed filters or you water pump from the bore starting to fail. I would expect you to have a large filter somewhere on the water line from the well. Try and find it and clean it our. The Rinnai also has a filter. It,s like a plastic round shaped nut just under the heater on the miidle connection. Turn the water off first, it should almost unscrew by hand, take it out and clean it (make sure you don't drop the O ring on it. Also some tapware has water filter right in the end of the spout, check these too. After you tried all this focus on the pump. Make sure no ther water id flowing, try the hot tap and see if it works. Do the same but slowly turn on a cold tap, slowly increasing the flow. Have someone out by the heater and see if the heater shuts down at any point. If it does it could be the water pump at fault. From what you have told me and am certain water flow is the culprit here. Really focus on anything that might lessen the flow before you start messing with the heater. Best of luck.
Aug 30, 2010 | Heating & Cooling
Problems with water flowing out of the shower heads
Check the diffuser and screen, try swapping them around to make sure that is the problem. If that is not he problem then the tubes from the exchangers need to be descaled.
Jul 01, 2010 | Rancilio Classe 6 E 2 gr Espresso Machine
Simpson Esprit 700 Top Loader washer will not pump the water out
You situation could be caused by various problems. The easiest would be to check that no hoses on the drain side are kinked or plugged. This includes the tub to pump hose or the pump itself. Sometimes socks and other items can get stuck in the tub hose. Sometimes objects left in pockets can seize or hinder the pump ejection. Its sounds like if the unit is spinning and water is not ejected the above solutions should be checked first.
Feb 14, 2010 | Washing Machines
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
My Magtag Performa washer has been shaking in the spin cycle very violently lately. The floor has not changed, so I can't blame an uneven floor. I'm assuming the belt may need to be tighten or replaced. ...
first I would check your drain pump.. you may have something blocking the water flow... this will cause the water not to fully drain and your machine will have a out of balance load...a loose belt will just slip and make noise,,,
there is a panel in the back you can remove to check the drain pump...let me know if this is helpful...
Sep 13, 2008 | Maytag Washing Machines
Fisher and Paykel WL37T26D Top Load Washer Logo
185 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
