Question about Plumbing
Emerson E10 1/4 hp disposal seems to have approx 1/2'' dia rock ??! w/rough edges jammed about 1.5'' away from blade deck, preventing any movement. Tried ss knife & screwdriver to move it, no work. VERY frustrating, & no $ for repair/replace due to unemployment - suggestions?
  • 349 Answers
Check out Disposal and you should be able to take it appart under neath sink you have 3 to 4 bolts run up against sink bottom to hold it in place disconect it and you possibly can take the top part off to try to remove the rock jammed in it.
It not to bad to take off you may be able to get to it better with it out.
Posted on May 05, 2010
My craftsman lt1000 makes a terrible noise when I engage the blades. Why? Please h
you could have a bearing on your deck going bad. The tension pully could be bad on deck, or missing big spring, sometimes they break, and make everything a lil sloppy. Good luck...
May 03, 2015 | Craftsman Garden
Grinding noise in mowing deck when engaged
the bearings in one of the blade houseing r going out
Jul 01, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Tractor shuts off when clutch is engaged craftman 22 hp 50" mower
I had the same problem. My problem was something was preventing the blades from spinning, so the 1st thing you can do is check to make sure your blades turn, and test this while the mower is off.
While it is a pain, you can also take the deck out and check to see if this help and you are able to freely turn the blades. If everything is working properly, you should be able to turn the blades by hand.
In my case, I has a stick jammed into the belts and pulley, so when I would engage the blade, it would cause my mower to stall when it tried to engage the belt.
Hope this helps.
Dave
May 29, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Blades won't enGage motor dies
First unplug the plug wires, take key out of switch, then check to make sure that the blades will move by hand. there could be a dirt mound or rock jammed in there
Apr 22, 2014 | Craftsman 26 Hp 54" Deck Yard Tractor
Bogs when blade is engaged
for this to happen you must have a bearing problem either in the gear box or cutter deck that has seized from rust or failed bearings. disconnect the cutter belts and see it t moves forward freely If so then turn each cutter spindle by hand and find which one won't turn or is rough in the movement.
Jun 09, 2013 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garbage Disposal Ace 2000 model 47982.... The water won't drain out of it and the sink is backed up and hasn't gone down for a whole day now. It seems like the blades are turning. I've been...
Hi David,
Are the blades actually turning or is just the motor running?
First, turn off the power to the disposal at the circuit breaker. Do not put your hand in until you do this.
If you hear the motor running, but not the blades, then the blades are jammed. On most disposers you can put an allen wrench in an opening under the unit and move the blades. If the blades move freely, then your drain line is probably plugged.
If the motor runs, but the blades don't and they will move freely by hand, then the disposal needs repair.
If the blades are jammed with food, you can clear the jam with your hand and the allen wrench trick from underneath.
Once the disposer is freed up, run cold water down the drain for a few minutes to harden any grease build up inside. Then running the disposer should get rid of the hardened grease.
By the way, most disposers have a reset button on the bottom of the motor should your disposer jam and turn off or trip your breaker.
Orange peels, etc. will not harm your disposer. A good way to keep it clear is to put egg shells down it periodically. The shell action will scrape junk off the inside of the disposer.
You can also keep the disposer clean of grease buildup by pouring some baking soda in the disposer followed by a mix of hot water and vinegar.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 06, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My cub cadet zero radius mower will die when I engage the blades. it seems that the blade is jammed but I do not see anything jamming it.
flip the mower up on its back, supporting it properly so it doesn't fall on you. you should be able to turn the blade(s) manually, if not then something is preventing it from turning. if there is nothing in the blade box jammed, it may be in the belt drive assembly, perhaps a stick or rock flew up in there and got caught, it happens quite often. the only other thing might be bearing on the shaft have locked up, but you would have heard this happening long before they actaully froze, good luck
Mar 23, 2011 | Garden
Badger 1/2 hp in sink erator (garbage disposal) steady stream leaks from the bottom near the reset button. It appears to be coming from a drain outlet (a small hole, dia. approx size of smallest screw ),...
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
Disposal will need to be replaced at some point.
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket.
How to: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Nov 26, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How to replace the two blades on my 42" Craftsman 20 hp ? Mike
The easiest way that I have found is to remove the deck from under the tractor and turn it over where you can see the blades.
Get a short piece of 2 x 4 to keep the blade from turning and put it inside the edge of the deck where the blade will contact it and unscrew the bolt that holds the blade on. You can also use a C-Clamp if you have one available or just about anything else that will prevent the blade from turning while you are loosening or tightening it.
Put the new blade back on the same way, making sure that you have it lined up on the "star" (Most blades are stamped "grass side" so you should be able to read this when putting the blade on since the deck is upside down)
You can replace them without removing the deck using the same basic procedure but you have to raise the tractor up high enough to get to the bolts and be able to see to get the blades properly aligned when installing them.
I have personally found that the extra few minutes removing the deck is well worth the effort as it gives you the opportunity to inspect it for any other problems and to clean any built up grass clippings if necessary
Oct 06, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
BADGER GARBAGE DISPOSAL just humms. does not work.
It sounds like the disposer has something jamming it. Try using the breaker wrench supplied with the disposer (or a suitable-size hex wrench) fitted into the socket on the bottom. Rock the wrench back and forth to see if you can loosen the jam. Another trick is to use a wooden rod (end of a broom handle, for example) to push on the blade to try dislodging the jam. Look inside with a flashlight to see if there is something that is easily missed. (I have found drink can tabs, coins and a shelf clip that way.)
It's also possible the motor starting capacitor inside the disposer or the motor itself is bad, in which case you would probably spend less on a new disposer than on repairing this one. But a jam is more likely.
Jan 28, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Plumbing Logo
196 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
