Question about Goldstar MV-1501 Microwave Oven
Started making noise
Using it the otherday it started making a humming noise & smells like something is burning (electrical smell). Tried taking apart a little, the smell is coming from where the blower pushes out the air. Thanks for any help on this issue!!!
  • Goldstar Master
  • 9,098 Answers
It's probably the magnetron or high voltage transformer, but it may also be a failing high voltage diode.
Depending on the age of the unit, the magnetron may still be under a part warranty, but taking it apart would likely void that warranty.
If you think it might be under warranty, you should contact LG. For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
If you decide to check it further yourself, we have a similar model's service manual on our site:
http://www.microwavedisplay.com/mv1555st_sm.pdf
Bear in mind that the part numbers will not be the same for yours - you will have to call LG to get proper part numbers.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
MIcrowave emits an electrical smell while cooking. It still cooks, but has started emitting an odor recently when in use.
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
Cheers!
Jun 25, 2011 | Sharp KB-6024MS Stainless Steel 1000 Watts...
Spacemaker XL1800 (JVM1850CF001) This microwave stopped heating and started making a humming noise while trying to cook. I read some possible parts that will fix the problem. How difficult would a megatron...
look behind front control panel. there is a tech sheet. you can trouble shoot this problem, but you may need a voltmeter and an amp meter. it sounds to me like the high voltage transformer is bad or not working. it helps power the magatron. the hum is the mag trying to work, but it doe'nt have the high voltage it needs. this unit new sells for appr. $350.00.
Feb 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our Sharp microwave oven turns on, makes a loud humming noise, starts to smell like something is burning, but doesn't heat. Well, actually, we don't think it heats, we're too scared to let it run because...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} This can be caused by grease etc. inside the oven and on the wave guide which is the paper like thing in the oven. If you can remove it look for burnt areas which may can be scraped off or you may need to replace it. An appliance parts store usually has the material you can cut to fit you own.
Dec 10, 2009 | Sharp R-530ES Microwave Oven
Hey Thanks!! I tried to warm food in the microwave and the microwave started to make a strong humming noise, didn't warm the food and has an strong electrical burnt smell. -What's wrong?
The unit had a meltdown. Anytime you smell something thats not normal its alway an internal failure. You could send it out to be looked at but at the price to replace it your better of getting a new one.
Nov 27, 2009 | Microwave Ovens
We have white
there is a component called a spatter gard inside the oven at the point where the microwaves enter......if food or other foreign substance gets stuck there, then it will start to burn ...the smell and popping noise is coming from the spatter gard.....to fix it you must remove the spatter gard..replace it if it's burnt and /or sand paper the spot clean and then paint the area with a high temperature paint called mr. touch up......to protect the bare metal from the microwaves.....hope that helps
Nov 27, 2009 | Kenmore 80412 Microwave Oven
Not heating and making a loud humming noise.
you have done well out of the oven . it sounds that certain components are well worn and probably no able to get parts best advice it time to buy a new one
Dec 21, 2017 | Kenmore Microwave Ovens
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
Goldstar MV-1501 Microwave Oven Logo
108 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
