In a residential system that presently has a 3/8 -5/8'' lineset 30 ft long on a R22 system, can a 2.5 ton 410A system work on that size lineset?
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    NOOOOO. The brazes will not hold up and you will be mixing the different oils. You are upgrading to a lot higher pressure unit, that needs to have its own set of lines ran and be brazed correctly to not break under the pressure
  • 674 Answers
Look at the manufacturer's instructions and it will tell you how much line set the factory charge is good for. Don't plan on using the same line set that was hooked to the R22 unit as R22 and R410a use different types of oil that are not compatible. Hope this helps.
Posted on May 05, 2010
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
I bought a new Goodman heat pump in jan 2010. It has a 2 1/2 ton compressor with a 3 ton A- coil. I was told by them this would work fine with an expansion valve.`I have had nothing but problem since...
The "A" coil will generally be larger than the outside coil as far as the tonnage goes. When a unit has an expansion valve the charge should be based on subcooling instead of superheat. The reason for this is that the expansion valve acts to maintain a constant level of superheat. The best solution may be to have all the refrigerant recovered, then weighed back into the system. The length of lineset should also be checked. Units come precharged with enough for 25' of lineset and the charge will need to be adjusted for more or less that 25'.
Dec 11, 2010 | Heating & Cooling
I have a Goodman GSC130361DE it is too small for a 2100sq ft home
Well you have a 3 ton system, it might be a tick small depending on windows and insulation in the house. Make sure you set it at one temp and leave it. Zoneing would also help.
Jul 17, 2010 | Goodman CLQ30AR32 Air Conditioner
Do you add freon to your indoor unit or your outdoor unit? I have A new 2 ton first co unit indoors unsure what I have outside. Where does the freon go?
I would highly recommend that you get a friend or hire a pro, to deal with this. You dont just add freon, is it -R22 or the new 410A type? You always charge a system from the outdoor unit! If this is a new outdoor condensor, it will be pre charged for the unit, indoor coil and roughly 15 to 25 foot of line set. But after the brazing is done,,, NEVER SOLDERING! You need to use a Vac-Pump and pull the indoor coil and lineset down to 500 microns, before you open the king valves.
If this outdoor unit was used, then does i match the indoor coil? In sizing and type of refrigerant? Need to reclaim the existig refrigerant, pull a deep vacummn on the whole system and then weigh the charge in, according to the tag on the outdoor unit. You should have a CFC license t work with any type of refrigerant, if someone turned you in, it starts with a $ 10,000.00 fine for a start, You need allof the right type of tools and knowlege, save time and money,,,, get a CFC licensed tech,he will know all of this.
Sincerely,
Paul
May 18, 2010 | Heating & Cooling
I have a 2.5 ton carrier a/c on a roof with a 15 ft drop and a 200ft lineset is 7/8 and 3/8 going to work for this app
Normally the maximum lineset that can be used with a residential air conditioning unit is 50 feet. If the lineset is longer than this, it must be sized accordingly and without the model and serial number I am unable to do this.
Nov 13, 2009 | Heating & Cooling
4 ton HVAC Unit for 2000 SQ FT Residential Bldg (Single Story)
One ton of cooling per 500 square feet of space assuming you have good insulation. Yes, 4 tons for 2000 feet would be accurate.
Jul 21, 2009 | Ruud UBHC Air Conditioner
The factory charge is 195 oz. seams kind of high for a residential heatpump to me. i'm used to a unit holding approx 5-6 lbs. this is a 410a system.
410a system is a higher efficiency unit that has a larger outdoor coil and inside evaporator coil.also the copper line coming from outside are larger one size in diameter. thats almost 12 lbs. sounds like you have a 5 ton system
May 23, 2009 | Heating & Cooling
Residential HVAC - Repair vs Replace? Heat Pump? Two Stage AC?
for 65 dollars i would replace the coil I do however love gas and heat pump combos it will cut your gas bill by about 75% only uses gas below 30 deg
you may want to try a honeywell 8000 stat it has random circulation fan comes on and just circulates the air also used for gas hp combo with an out door sensor and you don't need the fossil heat kit as for the copper if possible replace it due to don't trust any ones soldering as for units the are all about the same look for warranty some replace unit others have life time comp if only going to be in house for 10 yrs hard to recover cost give replacement allowance when sell
May 11, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
