Question about LG Over-the-Range Microwave
Outer glass is loose
The outer glass on the outside of the door is loose. It is loose on the top of both corners. How can I fix this?
  • LG Master
  • 9,047 Answers
Normally you have to separate the door panels (as shown in the attached photo).
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Then you can see the screws you need to check and tighten, etc.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
We're happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
Posted on May 06, 2010
How can I remove the door glass?
You really don't want to undertake this task.
Feb 16, 2016 | In Microwave Ovens
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Trying to replace handle on GE microwave oven #JVM1631WB. Have already removed plastic cover that trims the glass on the inside of the door. This exposes two screws on the handle of which I have removed....
You order parts and find helpful exploded view diagrams here.
I'd recommend that your bookmark this link to your favorites.
Jan 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Condesation stains inside door
The door is not an airtight unit. Moisture can and does get between the panels. Nothing to do outside of disassembling the door and cleaning. Not so easy to do.
Eric
Oct 28, 2009 | Microwave Ovens
The glass on the microwave door on the outside has slipped down and there is no screws to take apart the door and fix the glass. Does this fall under the warranty? My 5 years is up on 12/01/09.
I would contact customer service (for Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here about the warranty and to find your nearest authorized servicer.
If not, it's pretty easy to fix this yourself.
There are probably broken tabs on the inner or outer door panel.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Sep 26, 2009 | Maytag MMV1153A Microwave Oven
Broken door on my Emerson microwave (MW8985W)
You can order the outer panel. Its available at searspartsdirect.com for about $41. Just type in your model number and look under the "Door Assy" heading. To replace, just follow these steps:
You have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and any screws that may be holding the outer panel in place. Some panels are simply snapped in place.
Remove the broken panel and install the new one. Re-install the door handle and re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you
Aug 27, 2009 | Emerson MW8985W Microwave Oven
My over the oven model 665.61629100 kenmore has cracked door
The outer door frame CAN be replaced if you like. You can view an exploded view diagram at searspartsdirect.com. Just type in your model number and locate item 10 under the "Door" parts listing. The part comes in various colors so make sure you select the correct one.
The door can be easily removed by opening it all the way and lifting straight up at the hinges. The door will come off the hinge pins and can be laid on a flat surface for easier access. Place a layer of towels under the door to prevent damage to the door.
You will need to remove the door handle to get the outer door frame off. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you may need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and and locate any screws that may be securing the outer door (front) frame in place. Once you install the new outer door frame, re-install the door handle and carefully re-insert the inner door panel. Gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
To answer your initial question, the microwave should continue to be safe to use as long as the inner door seal and door glass are intact. Make absolutely sure you reinstall the door components back together properly. Not doing so will render the oven unsafe to use. Refer to the web site I provided as a reference for how the door components go back together.
NOTE: This part is listed a bit cheaper at appliancepartspros.com. Use the part number from the first website I mentioned as your search criteria.
Jul 30, 2009 | Microwave Ovens
Need to replace the handle of a ge jvm1340, the top screw is easy, but the bottom screw seems unaccessible, can you help thanks, JG
There is a piece of trim on the inside of the door.
This trim is rectangular, about 1/2" wide, and goes around the outside of the glass. the trim has rounded corners. Take a knife and gently insert at a rounded corner, prying the trim out. Once you can put a finger behind the trim, you'll find it comes off easily, revealing the lower handle screw.
Jul 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loose glass in door
Silicone glue would be best since it has very good heat tolerance and, if the clear is used, there will be no problem with it absorbing energy but I wouldn't use any with colorant as it could have metallic pigments.
Dec 23, 2007 | Whirlpool GH7145XF Microwave Oven
GE JVM1650BB005
You can search under Repair Parts and enter your full model number JVM1650BB005 and get an exploded view diagram here: http://www.geappliances.com/shop/prts/ That diagram can be a great help. Also, I've attached below a door panel diagram from a Sharp model. Your GE disassembly may work the same way. If you haven't already taken the door off the microwave, I would recommend you don't unless you leave the hinge assembly attached to the door and remove the door from the hinges. It's critical to be sure you get (or keep) the door and hinged aligned exactly as they were to prevent leakage.
Dec 05, 2006 | GE JVM1650 1000 Watts Microwave Oven
LG Over-the-Range Microwave Logo
185 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
