Nextar X3-08 Car GPS Receiver Logo
Posted on May 04, 2010
Screen is all white. How can I fix? Reset button not the answer
The screen is all white and can see only faint image. How can this be fixed or adjusted? The reset button does not do the trick.
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on May 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
2316
Points
15
If you unit has been sitting in the sun you may have burned out the screen or th overheated the ROM tha contains the Windows CE operating system. The only real solution to this problem is to send the unit to Nextar for either a repair by swapping out the ROM or get into their exchange program and get another unit with an updated map.
Windows CE Core 5 is the operating system for most portable CPU controlled units. GPS units included.
Sound but no image on Hitachi 42pd5000
Two things need to be checked. The ballast board and the T-con board. Shine a flashlight on the screen with the TV on...If you see a faint picture moving, then the T-Con board is OK. The ballast board for the white backlight is bad. If you don't see a faint picture, then the T-con board is bad. You can get parts here: www.shopjimmy.com TV Parts Universal TV Stands DLP Chips ShopJimmy
Optio E50 camera . after taking photo when I press to see what I have taken , the screen is mainly white with very faint images . I have reset camera to factory settings but with same result . Help !!
If the images look OK when downloaded to your computer, then the fault lies in the camera. If, however, they look the same, then you need to look at either your exposure or white balance settings.
Oct 22, 2016 • Cameras
1helpful
2answers
Why are all the lights on LCD screen on?
How to troubleshoot and fix video problems
Here are some tips and tricks for troubleshooting and fixing laptop video problems. Video issues are very common within portable computers and with the following tips you should be able to detect and eliminate basic laptop video problems.
Laptop LCD screen has a faint image.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the backlight stays off even when you open the LCD screen or turn on the laptop. The switch turns off the backlight when you close the LCD display to save the laptop battery power. Check the LCD lid close switch. Usually it is a small plastic pin located close to the LCD hinges. Try to tap on the switch a few times to turn on the backlight. If after tapping on the LCD lid close switch the backlight stays on, you fixed the problem.
It is also possible that after tapping on the LCD lid close switch the backlight works fine, you see a normal video on the screen for some time and then the backlight turns itself off again. In this case I would blame the FL inverter board. Try to reseat cables on both end of the FL inverter to make a better contact between the cables and the FL inverter board. If it doesn't help I would try to replace the FL inverter board.
Laptop LCD screen is solid white color.
http://www.laptoprepair101.com/wp-images/white-screen/1-laptop-white-screen.jpg
Most likely it is just a bad connection between the LCD display and the system board. I would try reseating the video cable connector on the back of the LCD screen first and check if it fixes the problem. After that I would try reseating the video cable connector on the system board. I would also try reseating cables if there is no video on the LCD screen at all.
http://www.laptoprepair101.com/wp-images/bad-laptop-video/washed-lcd-image-1.jpg
Try to connect the LCD screen to an external monitor. If the external video is fine, you have a problem with the LCD screen or the LCD video cable. You can try to fix the problem by reseating the video cable on the back of the LCD and on the system board.
If you see the same garbled video output on the external monitor most likely it is not the LCD screen problem. In this case the system board (with onboard video) is bad or the video card is bad.
REFERENCE: http://www.laptoprepair101.com/troubleshoot-fix-laptop-video-problems/
GOOD LUCK.
1helpful
My 2 year old viore led tv model led32vh30 has a grey screen with the image faint in the background. Any home fixes would be great. Thank You Kyle
unfortunately the faint image can not be fixed it is caused by the light burning it into the screen due to the image being static you need to replace it
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
White screen lcd display
Your LCD is starting to go out. Call their repairs dept to have it fixed. 1-800-706-2534 option 2. Tell them that you have already talked to tech support otherwise they will make you call a bunch of different phone numbers.
Blue image shadow on one side of the screen..Help!
Perfect! That is typically called "Ghosting" where there is a faint image shadow behind the image on your screen. I'm glad you were able to get it fixed!
Top Nextar GPS Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Nextar GPS Expert? Answer questions, earn points and help others
