Question about HP LaserJet 4250 Printer
Hp 4250 laser jet vertical streak ghost image
Our hp laser jet 4250 is printing a vertical streak on every sheet. It seems to be a ghost image of whatever was about 3 inches above it.
So there must be a roller or something internal that is carrying over ink.
Replacing the ink cartridge/ drum had no effect.
Any thoughts?
  • HP Master
  • 1,684 Answers
The problem you are having is caused by the fuser. The fuser is the part in the printer that heats up and basically melts ( fuses) the toner to the page. The fuser has a heat roller that is coated with teflon, your fuser coating has worn off in spots so the toner is sticking to the roller and causing the ghost image. You will need to order a replacement fuser. You can do a search on Google to find a replacement, the parts number is RM1-1082.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on May 05, 2010
Testimonial: "Thank you! That was really clear and resolved the problem."
Veritcal streak on left side of paper. Streak is light gray
Vertical streaks are usually caused by a bad fuser. The fuser roller has a teflon caoting and when this coating gets scratched or worn it causes image defect to appear on the paper. The fuser for the 4250 is part number RM1-1082 and you can get them from Amazon.com or other online sites. Here is a link to an article that shows how the fusers can cause the vertical image defects like you have.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Feb 12, 2013 | HP 4250 Monochrome LaserJet Printer
How do you clean the print rollers? All my copies have a long vertical smudge/streak that runs entire length of the right side of the sheet (8.5x11 and 11x17).
It might not be the rollers but the image drum. A bad image drum will sometimes cause streaks on print outs. If you look at the right side of the image drum you will probably see a streak that matches what is being left on your paper. Be careful not to touch the image drum as it will cause fingerprint on your printouts! Of course if the image drum is bad it will need replacing and fingerprints won't matter.
Mar 01, 2011 | Ricoh Aficio AP610N Laser Printer
My samsung ML 2510 prints a black streak on each plus a watermark from previous page
If your paper setting are set corectly (normal paper) and you are getting a "ghost image" from the previous page, most likley the fuser is the problem. On rare occasions, the drum unit could be the culpret (Black lines) down the sides of the page as you indicated.
You may have 2 problems.
I would change the toner drum 1st. If the black lines go away ,yet the ghost image continues, then change the fuser as well.
Jan 16, 2011 | Samsung ML-2510 Laser Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Canon 3220 toner streaking/ghost image
It might be afixing problem, but did you try to replace ITB cleaning blade?Its hard to say without seeing a copy/ test sheet
Jan 13, 2010 | Canon Office Equipment & Supplies
I have streaks on my print outs from hp laser jet
check your toner cartridge, check your fuser rollers and check your transfer roller assembly.
Sep 23, 2009 | HP LaserJet 4 plus Printer
HP J5680 is printing and scanning vertical gray stripes
The fix is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=za&lc=en&dlc=en&product=3301296
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 16, 2009 | HP Officejet J5780 All-In-One InkJet...
HP LaserJet 4250 Printer Logo
1,213 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
