Question about Sony Computers & Internet
Change the hard disk of my vaio PCG-7Y1M
How can i change/remove the hard disk of my vaio PCG-7Y1M?
thanks.
How to remove a hard drive from a sony vaio pcg-6n1l
Turn laptop over and remove screws from HDD compartment door.. Remove screws holding HDD in place and remove.
Nov 22, 2013 | Sony VAIO PCG-6N1L, PCG-6N2L, PCG-6N3L...
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Hello, I am contacting you on behalf of my cousin whose computer crashed. She has a system restore disk and I instructed her to reset the order of start up in the BIOS by moving the CD/DVD drive to the...
One of the function keys should get you into the boot menu, F9-F12, to manually select the CD/DVD drive. Pressing Esc or Tab on VAIO logo may display the right information to show which key to press.
Have you tried booting a standard Windows setup disc and checked if the hard disk is working ok?
Aug 24, 2011 | Sony VAIO PCG-K33P Notebook
Hi, I am unable to use recovery wizard. I tried to re-install xp using win nt 32 manually,but could not do it, Now I can't shut down and I do not have back up cd. Could you please advice me how to...
If you have not removed all the partitions then you can boot with any OS disk and clear the c partition.After that take out the disk and press the recovery option.It should autometicaly partition the disk and reload the OS.
If you made any changes in the partition table then recovery could be done with the OS disk only.
Thanks.
Nov 25, 2009 | Sony VAIO PCG-K23 Notebook
Sony vaio laptop cannot boot
hi and hello their..last year i have the same problem like your`re with my client..my 1st see the problem about that error is memory i suggest my client to make replace the memory..i think this is way the best you do 1st.the processor of laptop cannot advice to replace only memory and Hard drive..Thanks and Good Luck..^_^..>GOD Bless you...
May 09, 2009 | Sony VAIO PCG-K33P Notebook
I need to remove the keyboard to fit a new power jack socket.
This should help
http://www.tcm.phy.cam.ac.uk/~mr349/sony/
May 09, 2009 | Computers & Internet
No boot
check the cd rom again make sure its plugged in ok, ,
with the hard drive you usually can hear it spinning or ticking
before buyin a new hard drive i would try to reinstall windows
Apr 02, 2009 | Sony VAIO Notebook
Hard disk crashed
I think it maybe mounted through to top of your laptop under the keyboard, for instructions on how to remove keyboard and sometimes the HDD is held in a carrier. click below http://www.vaio-link.com/tutorials/memory/memory.asp?l=en&category=0&serie=PCG-Z1&m=1165
Nov 01, 2006 | Sony VAIO PCG-Z1WAMP1 Notebook
Computers & Internet Logo
1,839 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
