Question about Coleman Heating & Cooling
Where is the capacitor located on a coleman heatpump
My heatpump's fan does not turn anymore. I was told it was the capacitor.Where is the capacitor located on a coleman heatpump and how to replace it.
Tks. Antoinette
  • 1 more comment
  • agrignano May 05, 2010
    Thank you for your response. It is an outside unit. Once you push the fan it will work slowly, but when it stops it will not start again on its own. Do you beleive its the capacitor???
    tks again
    I have already requested for the peice from a local colman dist. My husband shall attempt to install the pice with the next few days. Thank you very much for your help. I will let you know of outcome.
    my husband changed the piece. but the fan still needs to be pushed to start and spins slower then usual. any suggestions?? tks
  • 674 Answers
If you're talking about the outside fan, look where the wire goes into the outside unit. The capacitor will be somewhere near the circuit board and will be round or oval and metal or plastic. If you're talking about the inside unit it will be with the electrical control in the air handler. Write down where the wires go. The terminals on the capacitor will be marked and for the outside unit you will either have 1 that runs both the fan and compressor or a seperate one for each. If you have 1 that runs both the wires must be reconnected to the right terminals. They will be marked COM, FAN, HERM(stands for compressor). Take the old one with you to get a new one. Let me know what you find.
Posted on May 04, 2010
Testimonial: "Thank you so much for your help. It makes me feel better ordering the piece now that you gave me the re-assurance. Tks again Antoinette "
  • 1 more comment
  • Brian Niten May 05, 2010
    That sounds like the capacitor. Its no problem to remove. Just a few wire to disconnect from it but make sure you make a note of where they go. Let me know if need anymore help.
    Make sure you turn the power to the outside unit off before replacing the part. And please give me a vote for the solution. Thanks.
    It's possible one of the windings is burned out in the fan. If your husband has a multi-meter he can check the resistance of the fan windings pretty easily. What he would need to do is disconnect the fan and connect one lead of the meter to the common wire (it's usually black) then connect the other lead to the run wire(usually red) and read the resistance, then connect the lead to start wire(usually brown and goes to the capacitor) and read the resistance. If he reads an open line on either one you need a new fan motor. This is all assuming the fan motor only has 3 wires. If yours has more let me know what you have and I will tell you how to check it. Sorry the capacitor wasn't it. Let me know what you find out.
When my heat comes on , the blower doesn't blow it just mummes. I can turn the fan by hand and it is free. the out side unit is working . Can it be the coil on top of the fan? It a Model EB17B Coleman
It certainly could be the motor capacitor; the oval metal can located on the blower housing.
8fzzjawtltskcaaaaasuvork5cyii=
These are fairly simple to test with a digital meter that measures capacitance. Also, if it is bulged or has a hole blown in it, you know it is bad. These are available at almost any appliance parts store locally or at Grainger.com
It also could be the motor relay (#12 in the manual)
57v4aaaaasuvork5cyii=
You can download the furnace install manual and wiring diagram here:
EB17B
Grainger Industrial Supply MRO Products Equipment Tools
Jan 26, 2015 | Coleman Heating & Cooling
Coleman Mach III RV AC
Sounds like possible fan capacitor failure. If your not familiar with capacitors, please find someone who is, as they can give a fatal electrical jolt if not handled properly.
Jan 26, 2013 | Coleman Mach III Air Conditioner
Makes a noise, but the fan does not turn, it spins
I was told to change the capacitor on the blower motor and that solved my problem.
Jul 21, 2010 | Tools & Hardware - Others
RV ac fan runs backwards (blows out air on top of RV.) Runs correctly sometimes but after it satisfies and clicks off when it kicks back on, it runs backwards. The only thing that will turn it back around...
Hi, this is strange as I have never heard of this either!!! The capacitor is located by the motor and sometimes clamped to the motor. They can be the shape of a very small can, oval 3" tall with 2 leads on top with wires coming off the terminals. It could be chrome in color, or made of hard plastic. It may have 3 terminals on top, with several spade connectors on it.When you find it, mark all wires and draw a picture or you will not remember how it hooked up.Try and get the same one. Keep me posted and I can help if you need more. Strange thing going on here??
Shastalaker7
Dec 22, 2009 | Coleman Mach III Air Conditioner
Coleman AC compreser work but fan dont
If the selector switch is broken, you need to replace that first. This will cause the fan not to come on if there is an open in it. After replacing the switch, if you still have to fan operation, it is possible that you have a bad fan capacitor, part# 1499-5461, or a bad fan motor, part# 14683099. Replace the capacitor first before spending the money on a motor. An easy way to check is to see if you can start the fan motor by hand while turning it on a the selector switch. If the motor starts this way, replace the capacitor.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic 57915531 Air Conditioner
Looking for a replacement thermalmite for a coleman drhq0301bd heatpump. Not sure of the name, but it is the ceramic component that is cylindrical, has a yellow wire attached on one end, yellow and brown...
You should be able to find this part through Source 1 HVAC supply. Here is their web link. You can put in your zip code and find a local dealer to help you identify and purchase the part you need.
http://www.source1parts.com/
Jun 30, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
185 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
