Question about 2wire (1000-400108-001) Router
Hard reset for 2 wire router 1020
2 wire router 1020. is there a hard reset button ? Reason is, my mates router blew. gave him my spare but has my details and I cant remember passwords..... please can you help
  • 59 Answers
If you do a hard reset on that sort of router, any information on the router will be lost, and the router will return to factory defaults.
Do you mean that you want to do a hard reset on your FRIEND'S router, so that you can go back to using the OTHER router that you lent him?
look for a small, recessed button on the back, near where the power cord plugs in.  you'll probably need a pen or sharp pencil in order to press it.
if you can find that recessed button, hold it down until the lights on your router blink
simultanously, then release it.   I know that works on SOME models of 2Wire routers, I'm not certain whether or not this model has the option or not.
Posted on Mar 26, 2008
SOURCE:
Hi i have foggoten my pass word to my router and need to change the security settings to stop some one having access thanks Chris
If some one is accessing the router it's probably because there is NO PASSWORD, on the other hand if you had a password and gave it to that persone and can't remeber it you need to RESET the router to factory default (according to manual) than re-configure the device... (with a good password that you will remember)...
Sep 15, 2011 | Belkin F5D7234-4 Router
Hello, I have a Belkin router, Model FSD7234-4v1. I have had this router or several years now and have never had a problem with it. The computer that was originally the administrator has long since been...
hi mate, i would just hard reset the router and then you can use the default password that comes with it , below is the link to the belkin hard reset proceed, and i diagram of your router, just hold a paperclip in the reset button for 15 seconds (fig. 10) after its reset you can use the default password the router came with,
sf8132-003-en_v3-ray0hjyhdiz4pf0utlyrskko-2-0.png here is the hard reset procedure
Resetting the Belkin router to factory default settings using the Reset...
the default password should be on the router on a sticker somewhere
Apr 19, 2017 | Belkin F5D9630-4A Wireless Router
Hi I have a problem with my phone i-mate jaq. the problem is that I blocked, and now I can not remember the password. help me please. thanks
You need to reset your device to factory installed settings, to use your cellphone, there are two type of reset you can apply, 1. Soft reset 2. Hard Reset
1. To perform a soft reset
Remove the battery cover and using the stylus, press on the small
button to the left of the battery. Otherwise simply remove the battery,
wait a few seconds and then insert the battery again.
2. To perform a Hard Reset
Hard reset by pressing device buttons:
1. Turn off your device.
2. Hold down the Send button, End button and Camera button.
3. Do not release Send, End and Camera, press the Power button.
4. After on-screen indication, release all the buttons.
Caution, Hard reset will delete all your data from the Phone memory, including contacts, messages, or pictures you have in phone memory
If you require more assistance, feel free to reply to this post
Regards-BA
Jan 14, 2011 | i-mate JAQ Pocket PC
How to remove align screen
Hi..
Problem can com from your touchscreen panel.
you need to replace it manually. only then this will be solved.
or you can try with soft reset or hard reset.
please find explanation at below :
i-Mate JAQ3 soft reset
Resetting Your Pocket PC Phone
Occasionally you may need to reset your Pocket PC Phone. A normal
(or soft) reset of your device clears all active program memory and
shuts down all active programs. This can be useful when the device is
running slower than normal, or a program is not performing properly.
A soft reset is also necessary after the installation of some programs.
If a soft reset is performed when programs are running, unsaved work
will be lost.
You can also perform a hard reset (also known as a full reset). A hard
reset should be performed only if a normal reset does not solve a
system problem. After a hard reset, the device is restored to its default
settings - the way it was when you first purchased it. Any programs
you installed, data you entered, and settings you customized on the
device will be lost. Only Windows Mobile software and other preinstalled
programs will remain.
i-Mate JAQ3 hard resetHard reset using Master Clear
1. Tap Start > Settings > System tab > Master Clear
2. On the System tab, select the Master Clear (!) icon
3. Proceed to enter the confirmation code: 1234 and push reset button,
system will auto reboot to complete the operation.
hope this kind information will be help you to solved
regard,
adhiwahyudy
Dec 24, 2010 | i-mate JAQ3 Smartphone
My i mate jama101 is not switching on .but when i put on charge blue screen apeares . How to solve this.
HARD RESET
1) Start->Settings->System tab->Master Clear->1234->ok
2)Press soft-reset for 15sec.
3)Remove the battery, Simultaneously hold volume(-) button and red hangup button, while still holding those keys, insert the battery and wait for the led to go out, release keys and device will hard reset
3rd option really worked for me
Jun 27, 2010 | i-mate Jama 101 Smartphone
Not able to unlock i mate 101 ?
HARD RESET
try option 2
Jun 24, 2010 | i-mate Jama 101 Smartphone
How to do factory reset of i-mate JAQ
will be lost.
settings — the way it was when you first purchased it. Any programs
i-Mate JAQ3 hard reset Hard reset using Master Clear
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 02, 2009 | i-mate JAQ3 Smartphone
How do I hard reset my i-mate k-jam do it faster
To perform a hard reset
1.
Press and hold the Comm Manager button and Voice Command
button on the device.
2. Keep the two buttons pressed, and at the same time, use the
stylus to lightly press and hold the RESET button.
Dec 22, 2008 | i-mate K-JAM Cellular Phone
My netgear dg834 wired router ceased to get an ADSL connection for no apparent reason? The ADSL connection, filter and cabling all work (as I've tried with a modem). Hmmm?
I'd try a hard reset by unplugging the router, holding in the reset button for 30 seconds, while you plug the router in and see if you can get it going again. If not its time for a new one.
Nov 06, 2008 | Computers & Internet
I mate jama
hard rest your pda usnig camara+recording button+power button and reset it with stylus....but you will loose your data stored on phone.....bet data on storage card will be saved........
Feb 15, 2008 | i-mate JAM Pocket PC
2wire (1000-400108-001) Router Logo
2,326 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
