My computer comes on for 30 seconds or so, then goes off. I've used the recovery manager, f11, and system setup, f10, and it will run while in recovery, or setup. But it will not load windows. The computer has Vista 32 bit OS.
  • 493 Answers
- Does it give any message in the beginning such as hard disk not detected etc. ?
But anyway, you may try to do this:
- Go to BIOS Setup,
- Change the Disk Controller setting to "IDE" or "compatibility mode"
- Then restart.
Hope this helps.
Waiting your comments.
Posted on May 05, 2010
My HP Pavilion is stuck on the blue screen
While your system is still booting from start, keep hitting F11 to get past that point then proceed with the system recovery.
Nov 12, 2013 | HP Pavilion a6110n PC Desktop
When i turn on computer resuming windows appears then it goes to setup is starting services repeatly and will not do anything else please help
restart the computer, hold the key f8 and go in the safe mode with network, pass the scanner disk, antivirus+antimalware. use the defragmentation disk too. try again. If this fail restart again and press the key f11 or f10 depending of your computer model, and go to recovery system, and use the system what do you want, recovery to the setup factory, or normal
God bless you
Apr 05, 2013 | Acer Aspire Computers & Internet
How to restore my compaq nc8000 to factory settings
Hi, When your system restarts displays message to enter in setup mode. Whatever it shows KEY to enter like F10 or F12 to enter setup, press the key and enter into setup then select Restore Factory Setting by selecting the option from the list.
Thanks,
Regards
Apr 05, 2013 | Computers & Internet
Hp pavilion dv7-1135nr will not start up....blank screen blinking cursor
Larry,
There are many circumstances that can create a blinking cursor.
First, check the laptop and make sure that there are no extra devices plugged into it, and that there are no CD/DVDs in the optical drive. Then, unplug the power cord and remove the battery. Then press and hold the power button for 30 seconds to drain any residual power in the laptop. After that, plug back in just the power cord (leave the battery out) and try to turn the system back on.
If it goes to the blinking cursor, power the system back off. You'll need to boot up into the BIOS now and reset the BIOS defaults. To get into the BIOS on that computer, you will need to start it up - and when you see the very first screen, there should be a message to press ESC to enter the setup. Press the ESC key a few times when you see that message and then at the menu press F10 to enter the BIOS Setup. Once you are in the setup, use your arrow keys to move to the option for Load Setup Defaults. (That option might be under the Exit area.) Then after you've loaded the defaults, make sure to save changes and exit. Try to boot up again. If it still brings you to a flashing cursor, then we need to try to run the diagnostics on the computer.
To get the computer to run diagnostics, try pressing the F2 key during the first screen when the computer turns on. If the diags run and the hard drive passes, then you'll need to look at running the F11 recovery at startup. The F11 recover will erase all of the files on the computer and restore it to the factory default - so be aware that this is a last effort solution.
If you need to have data recovered off of the computer, you will need to take it to a certified technician who can remove the hard drive from the laptop and pull the data off of the hard drive via a slave system.
If the hard drive fails the diagnostics, you will need to contact HP for a replacement disk. You can get that process started by calling HP at 866-234-1377.
Let me know how things turn out!
Nov 22, 2011 | HP Computers & Internet
My brothers stupid friend tried to fix his computer (Dell 6400 inspiron) had vista on it and instead of using the revcovery manager i believe he wiped the OS and reinstalled an unlicensed version of XP...
I believe that when you turn it on, you have to hold down the CTRL and either F10 or F11 (I've heard of both working) and that should get you into the recovery partition.
Aug 14, 2011 | Dell Inspiron 6400 Notebook
Need recovery disk for pc have none
By default your computer has a recovery partition, which can be accessed by hitting F11 key as soon as you start the computer, Keep tapping the F11 key and you will be able to access the Recovery manager, Select the option to do a system recovery and it will get restored to original factory condition.
Note: you can only access the recovery partition if you have not made any changes to the Original Operating system and the Hard Drive.
For any further assistance please feel free to leave your comments.
Thank you for choosing Fixya
Mar 03, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
Put wrong recovery disk into new computer.
have a look here
and more pertinent, the F11 option here. If you have the right disks, you should still be able to run them...you will just have to boot windows from the recovery disks...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 04, 2009 | Microsoft Compaq Presario C501nr Notebook
I need help
If you do not have a Restore CD to run...
Reboot your computer.
As soon as you see anything on the screen look for a message similiar to:
For Setup press F10, For Recovery press F11.
They can be any "F" key.
Press the one that says "Recovery" and follow the instructions. If you miss it the first time, try again. You only get a few seconds to make the choice.
Oct 29, 2008 | Computers & Internet
Hi, I just bought a laptop brand new 4 days ago, it is a Hp Compaq Presario V3000 a couple days in, I believe a virus went on it, and now whenever I On my Laptop it comes up with the screen Choose start...
Restore the PC to original condition with the HP Recovery Manager Follow the steps below to use HP Recovery Manager to return your notebook to its baseline factory condition, then allow the PC to run all the setup programs.
  1. Press the power button to turn on the PC, and press F11 on the keyboard immediately while the computer is starting up. The HP Backup and Recovery Manager window will appear.
  2. Click Advanced options , select the System recovery option, and then click Next .
  3. If the Recovery Manager can access the hard drive it displays a prompt to backup up user files before continuing the recovery. You may either backup your files, or skip the backup and recover the operating system.
  4. If the Recovery Manager cannot access the hard drive to fix the system errors, use the set of Recovery disks that you created to recover the hard drive to its original condition.
After the hard drive is returned to its original condition, restart the PC and allow the PC to run all the setup programs. if thias does not work then you should return it to supplier
Jul 06, 2008 | Computers & Internet
Computer keeps crashing on startup
I am not sure what OS you have. But what I would do is download a registry repair program on your other computer. Then force your problem computer to go into safe mode. Once in there download the registry repair program and run it at least 2 times. From the problems you are talking about sounds like a serious windows registry problem. Best way to force into safe mode is either hit F8 or F2 as soon as the bios screen comes up. When in there download your registry repair. Once you have it up and running. Run defrag hard drive and also use the scandisk feature to make sure there are no errors. This should get you up and running again. If not contact me and i will further instruct you.
Sep 23, 2007 | Acer Aspire E500 PC Desktop
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
