Question about SanDisk Sansa m250 MP3 Player
Problem with max. volume
Hi! I just bought a Sansa M250. Everything seems fine, but when I put the maximum volume, music starts to "jump", there are glitches while playing anything, i dont know why. i am working in a mac
  • 8,596 Answers
Not Mac compatible largely.
ALL Mp3 players have a disclaimer telling you not to play it at max volume. Get adjustable headphones to resolve problem
Posted on Jul 06, 2008
How to remove music from sansa m250 that is no longer on computer
ok, plug the mp3 into your computer, click on my computer, then where it says removable devices you should see your mp3 listed, double click it. browse the folders listed until you find the songs that you want to delete , when you find one you want gone RIGHT click it then click delete/ It should then remove the song from your mp3 and put it into your recycling bin.
Jun 23, 2009 | SanDisk Sansa m250 MP3 Player
Sandisk sansa m250 MP3
Select Recently Added, Artists, Albums, Songs, Genres, My
Top Rated, Playlists, Podcasts, Audiobooks, or Recordings (Voice). - to view songs by album, artist, etc.
Or remove the track lisitng from the ID3 tag completely.
Jul 05, 2008 | SanDisk Sansa m250 MP3 Player
Finalizing updat
Firmware upgrade needed to solve your problem
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Apr 25, 2008 | SanDisk Sansa m250 MP3 Player
Volume
Hmm... Maybe try removing the battery without turning the player off. I know it sounds crazy, but it resets the player to the default volume settings.
Mar 21, 2008 | SanDisk Sansa m250 MP3 Player
My music is not wanting work Mp3 m250 2.0GB
use winamp to sync with his player or just about nay other.
Mar 14, 2008 | SanDisk Sansa m250 MP3 Player
Sansa m250 won't finish "finalizing update"
Ummmmm.... What are you doing exactly if your trying to download the music, Download using limewire, bearshare,
Its not going to work on Itunes most of the time so just use Limewire or bearshare. Connect the Mp3 using the Usb thing and try to put it in front of the cpu or behind either 1 of them.
After you should probably get a pop up scroll down and go to view folders or whatever and open it and put the music you want in the mp3 and when yur done beside the clock look for a Safetly USB remover or whatever and disconnect it.
I hope it works
Give me some Credit
and click the Button XD
Mar 13, 2008 | SanDisk Sansa m250 MP3 Player
The pc doesn't recognize the m250
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
download the sansa connect recovery tool
download the manual and it will tell you how to reset your mp3
Feb 26, 2008 | SanDisk Sansa m250 MP3 Player
Loading ALI podcast
I am sorry to tell u but the sandisk sansa m250 model isn't suppose to hold podcasts of any kind. It is only suppose to play music, recordings and FM tuner.
Dec 23, 2007 | SanDisk Sansa m250 MP3 Player
Please wait rebuilding the library. Then the m250 shuts off.
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. This solution has worked for me.
I do not know if this will work on other Sansa m200 type .mp3 players.
Dec 19, 2007 | SanDisk Sansa m250 MP3 Player
Player Doesn't Show Downloaded Music On Computer
Firmware upgrade first - www.sandisk.com
-Tha Mp3 Doctor
May 26, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
89 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
