Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
How do i defrost a fridge?
Its a whirlpool model; 3xart731gb01 and the type is:art731 and the serial number is: sl0325196
    Scholar:
  • 105 Answers
To defrost a fridge, you simply move all of the food to somewhere it can stay cold and unplug the fridge. That's it!
The purpose of defrosting a fridge/freezer is to melt the ice that has accumulated around the condenser to restore it to maximum efficiency. Once it has melted (using a hairdryer can speed it up) you can plug it back in and put food back.
Posted on Mar 29, 2008
Whirlpool gold french door bottom freezer ices up and causes fridge to run warm. I have taken it apart and defrosted several times. Fan works, drain is not clogged. What could be the cause of this?
The self defrost function is not working. Depending on the age and model you have a heater, bi-metal defrost thermostat.....and either an electronic control or defrost timer. One of these parts has failed. Need a model number to tell you more.
Apr 30, 2017 | Whirlpool Refrigerators
I have a 2002 whirlpool fridge and a 2006 whirpool fridge, are the defrost controllers inter changeable?
Defrost controls are always being updated and I don't recommend using one from an older model. I really don't know if they will work and would be affraid to try if it were me. Thanks Sea Breeze
What are the model numbers?
Dec 21, 2012 | Refrigerators
3xart731gb/01 wiring diagram
YOU HAVE A TIMER IN YOUR MACHINE PART NUMBER 2188379,WITH A SCREW DRIVER TURN IT SLOWLY TILL YOU HEAR A CLICK,YOU MANUALLY PUT IT INTO DEFROST,WITH THE BACK INSIDE WALL OF THE FREEZER REMOVED THE HEATER SHOULD COME ON,IF IT DOESN'T MOST LIKELY CAUSE WILL BE THE DEFROST THERMOSTAT LOCATED ON TOP OF THE EVAP COIL,IF YOU HAVE A METER YOU CAN CHECK IT BUT WHEN YOU HAVE A DEFROST PROBLEM IT'S A GOOD IDEA TO CHANGE OUT THE T-STAT ANYWAY,YOU CAN UNPLUG THE MACHINE,CUT THE TWO WIRES CLOSE TO THE T-STAT AND CONNECT THEM TOGETHER,PLUG IT BACK IN AND TURN THE TIMER INTO DEFROST,IF THE HEATER COMES ON YOU KNOW YOU HAVE A BAD T-STAT PART NUMBER 2321799 AND IT'S AROUND 27 DOLLARS,YOU HAVE A CALROD HEATER IN YOUR MACHINE AND THEY HARDLY GO PART 2313330 AND IT'S AROUND 25 DOLLARS.THE TIMER IS LOCATED IN THE FRESH FOOD SECTION ON THE RIGHT WHERE THE CONTROLS AREhttp://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-3XART731GB01/1198/0165000/W0212020/00009?blt=06&prst=&shdMod=
Jul 06, 2012 | Refrigerators
Model et18pkxfno1 serial eg4024334 type c18tfa97\r\nwater drips into refrigerator compartment somewhere from freezer (inside). Occurs daily. Tried to adjust temp in both refrigerator and freezer but...
The problem is that your fridge's drain line (which is located in the freezer) is iced over. So water can't drain out of the freezer when your fridge enters it's defrost cycle. The freezer and drain line needs to be defrosted by hand. Or you can unplug the fridge and open the doors for a 2-3 hours. Eventully, if no action is taken, the ice build up in the freezer will block the cold air flow to the refrigerator compartment .
Feb 19, 2011 | Whirlpool Refrigerators
What year was Whirlpool Fridge Serial nummber
To determine thage of your appliance you need to have the serial number also.
Check out this tip from another expert and compare your serial number to find the age of your fridge.
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
Heatman101
Jan 08, 2010 | Whirlpool Refrigerators
Hi I have a whirlpool fridge the buttom don't stay cold an
This is most likely the defrost timer or Adaptive defrost system. I will need your model number to be able to tell you what your model has. The places to locate the model numbers are in the photo be.if a Sears model the numbers will look like this for example 512.3645897
Thanks, and let me know, Sea Breeze
Or just click
HERE
and enter your model number.
Aug 06, 2009 | Refrigerators
No Defrost
Take back panel off freezer and ohm out the heater and defrost themostate.... Need type and model # for more help
Sep 18, 2007 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
55 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
