Compressor keeps trying to start for 5 secs then shuts off
My condenser fan is running, but the compressor keeps trying to start for about 5 secs. and then cuts off. I looked at the name plate on the condenser and it says: Snyder General, Model AE024GA, Serial H901813273. Can you tell me what this sounds like and do you know where I can get/see a wiring diagram and/or manual? I don't see that name anywhere on the web except to refer to furnaces. Also, can you tell from the model or serial what size btu's it is? I have an old 1100 sq ft ranch with same size basement and it does not keep the house cool hardly at all. Thanks in advance.
  • 2,418 Answers
This sounds like the unit is low on freon. From the model plate you have a 24,000 btu unit. This is the minimum needed for 1100 sq ft not accounting for windows and doors. Other factors have to be looked at for a good cooling AC, where is the unit located? In the basement is good. in the attic is bad. look at all the duct work is it all metal and insulated (good) is it plastic tubing (bad). The more insulation on the duct and the better it is sealed the better. You could use more btu's but you would have to replaced the whole system inside and out. You might look for a good 12,000 btu window unit or 2 - 3 8000 btus in different rooms. Now back to the problem I think you unit is low on freon. Should be using R22, unless you have a brother-in-law in the HVAC business you will have to call a local AC company to check out and add freon. Repost if you find other problems.
Posted on May 05, 2010
Testimonial: "Thanks for the help and I will definitely look at getting a window unit. The furnace is in the basement and the duct work is all metal and mostly covered in insulation so I will double check for leaks at the inside unit."
Rangemaster sxs cream . Why is my fridge and freezer the same temp ???? If anybody could give me an answer or solution.
Jason,
MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem.
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Refrigerators
The fan is running but the condenser keeps shutting off and on
its not the condenser thats turning on and off thats the compressor thats cycling due to a bad ptc overload/relay on the compressor that aids in start up and running of the compressor
Dec 25, 2012 | Jenn-Air JCD2389G Side by Side...
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
Jan 14, 2012 | True Refrigerators
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
My ac central air is blowing air but not cold
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device known as a "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning compressor. Another good device is called a "5-2-1" kit.
Jun 22, 2011 | Goodman CKL36AR36 Air Conditioner
The symptoms: fan starts and so does buzzing. buzzes for about 5 seconds then stops, compressor does not start. 1 minute passes fan still running buzzes for 5 sec then stops compressor does not start...
freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Sep 10, 2010 | Maytag MSD2756GES Side by Side...
Compressor shut down very quick then it turn on again after 3-5 sec it's off.., what is the solution?
MY HAVE A LOOSE SPADE CONNECTION AT MAIN THERMOSTAT RELAY. MOST OF THESE UNITS DONT HAVE HIGH OR LOW FREON PRESURE SWITCHES BUT YOU NEVER KNOW ON NEW UNITS CARRIER MAY HAVE THEM WHICH MY MEAN LOW FREON OR CLOGGED CONDENSER COIL  THE OUTSIDE COIL LAYERS IN DIRT,BUT THATS NOT A QUICK ON OFF .BURNT WIRES ON COMPRESSOR OR BLOWN RUN CAPACAROR CAN CAUSE QUICK ON OFF. WE HAVE INSTALLED A START CAPACATOR WHEN COMPRESSOR DOES NOT START AT ALL. CHECK FOR LOOSE WIRES ON TERMINALS THEY MUST BE PULLED TO CHECK THEM,THEY CAN SEEM CONNECTED BUT THEY ARE LOOSE. OTHER CAUSES MAY BE THE PROBE IN FRONT OF EVAP COIL WHICH IS TSTAT BULB. STICK IT IN HOT WATER AND IT SHOULD KEEP STAT CALLING FOR COOL.
Apr 20, 2010 | Samsung AW1203B Air Conditioner
Small frig stopped
are you sure the compressor is running or is it just humming trying to start then clicking out on the overload, if so you have a 50\50 shot of the relay being bad, otherwise the compressor is shot
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
A/C FAN MOTOR SHUT OFF, BUT CONDENSER KEEP ON RUNNING
The condenser fan might be going out. It'll start when cool but shuts off as soon as it starts to warm up.
Jun 28, 2009 | Heating & Cooling
Walkin cooler
Most Likely Low on Freon. Low Pressure switch shuts That Compressor Off.
Dec 29, 2007 | Refrigerators
Heating & Cooling Logo
174 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
