Question about Whirlpool 19.6 cu. ft. Commercial Freezer EV201NXM
Both lights are on on the outside of my freezer. Things are unthawing. I can't find my owners manual.
    President:
  • 949 Answers
The one light should be for power the other for alarm meaning the temperature has risen, which you already know.
In order to help you better I need to ask some questions about the freezer.
First off, is this an automatic defrost unit or manual defrost?
Does it have a fan inside the freezer? If so is it running
Do you see a frost build up on the back wall of the freezer closer to the bottom?
Do you hear the compressor running (the black pump behind the freezer on the bottom)? It will have a slight hum when running.
Is there frost build up anywhere else like the walls inside?
Posted on May 05, 2010
Testimonial: "I didn't even know it had an alarm. I couldn't find my manual. Should have read it when I got the freezer. Lesson learned. Yes, the motor is running and frost is starting to built. I am hoping that the problem was casued by my dear husband's not shutting the door completely. Many thanks. "
2 lights on bottom outside on food defrosting
5 Common Freezer Problems - APWagner Appliance Parts ...
https://apwagner.wordpress.com/2008/.../22/5-common-freezer-problem...
May 22, 2008 - Answer 2: The first thing to do is to set the thermostat to a colder setting. ... The compressor is at the back of the freezer near the bottom. ... You can manually defrost your freezer by turning it off for 24-48 hours and turn it back on to see if it begins to work ... Verify that the door light switch is working properly.
Why is my freezer suddenly frosting over? - Askville
askville.amazon.com/freezer-suddenly-frosting/AnswerViewer.do?...
May 30, 2009 - For the last 2 months my freezer has had a layer of frost over ...Normally when frost build up occurs its because warmer outside air is getting into thefreezer and the ... Or you may have an issue with the defrost heater, thermostat or timer. ... If there is no light you may not have a frost free freezer which means ...
Why is my upright freezer freezing at the bottom but warm on ...
www.shopyourway.com > Patricia Delugas > Questions
Food in the drawers is still frozen, but above this level is room temperature to the touch. ... the lower inside pane to remove ice from around the fan and evaporator (mostly refrozen fluids from thawing foods on the upper shelves). ... 2 Answers from these members: ... Outside is not warm (as usual). Yellow light remains on. 2 ...
[PDF]All about the of your Freezer - AJ Madison
Jan 20, 2016 | Freezers
The heating cables have failed under the floor of a freezer and i need to know how to unthaw the conduit to replace cables?
Can you figure out a way to circulate a warm anti freeze solution inside your conduit??? If so, I can help you out with details.
Aug 25, 2014 | Freezers
Stand up magic cheef freezer unthawing and hot to touch
A freezer can't "unthaw". It can freeze or thaw. I assume your freezer is not cooling properly and is hot to the touch. First try defrosting the interior. Ice buildup will cause the problems you described. Also check the rear of the freezer and clean the cooling coils so they transfer heat to the outside air.
If neither of these things helps, have a professional check your Freon coolant level. You may have a leak.
Oct 15, 2013 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Is it normal for the freezer to go off periodically? It just seems to stop running and later it will start running again. I've had this freezer for 5 years and don't ever remeber this happening before.
By stop running do you mean become quiet or do you mean quit cooling and unthaw all the food?
If you mean turn off and still be cold then that is normal.
If you mean turn off and warm up that is not normal
Apr 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer just stopped working
  1. You need to unthaw the freezer, and it should start working.
Sep 11, 2009 | Freezers
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Chest freezer not freezing
home refrigeration units are not designed to work in low temperature areas. where temps will drop below 45f so that is your problem. this is listed in your owners manual if you want to verify. thx peyton
Jan 30, 2009 | Frigidaire 15 cu. ft. / 425 liter Chest...
Layer of water on bottom of freezer,causing problem opening bottom drawer, having to use hair dryer to thaw.
If it is a frostless your drain tube is plugged. The water cannot go through the whole to the drip pan so it flows over into the freezer. Unplug the freezer and leave the door open all day to thaw. Or take the back wall out of the freezer and unthaw the drain tube with hot water and a hair dryer.
Nov 17, 2008 | Freezers
Whirlpool 19.6 cu. ft. Commercial Freezer EV201NXM Logo
216 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
