Question about XM Radio (XMP6000)
What fm channels work best in 23456 zip code?
  • 86 Answers
How can i get the channel auto scan on my Hisense 55h6sg tv to find any channels.
If it is asking for zip code you have not told it to scan for over the air or antenna channels when it asks air or cable
Dec 12, 2016 | Hisense Televison & Video
Location close to zip code 34974 for repair of radio
Hi Lavana....I know your zip code is Okeechobee, Florida.
Your best bet is to call Insignia at 1 877 467 4289. They
should be able to direct you to a repair facility in your area.
Regards,
Dennis
Oct 25, 2014 | Insignia 12-Mile, 22-Channel 2-Way Radios...
How can I connect an mp3 player to a Buick Regal 2002
The easiest way would be to zip to a local walmart or similar store
pick up a FM Transmitter
then you just tune your radio channel to the same channel as the FM Transmitter,
plug it in your cig lighter... and the other wire goes into the earphone jack on the mp3
and should be working at this point
Jul 10, 2011 | Car Audio & Video
Trying to figure out what FM frequencies are avail for my portable XM in my car? 50595 is my zipcode.
KQWC 95.7 is the only FM station that is out of webster city which is the 50595 zip code.
Jan 27, 2010 | Delphi Roady XT XM Radio Receiver
Best Buy hooked up my sirius radio through the fm tuner.
Yes you can my brother bought one of those after market radios and you can run it on three different channels you need to find one that has nothing on it including hiss. look in the book and it will tell you the different channels. Also Be sure you have the reciever on the dash in the center at the top for best reception or lower it tothe middle to find the best reception you can get. it is important to get it in the right place for it to work.
Jul 17, 2009 | Directed SV1 SIRIUS Radio Receiver with...
Delphi skyfi won't connect to my fm radio automatically.
The audio plug overrides the FM frequency setting. That way if you use a tape adapter to run the music through it will use that source instead.
A lot of FM channels are getting crowded into a lot of markets out there. The best way to fix the problem is to use a direct FM module. This way your Sirius will override the FM channel whether it is used or not.
Here is a link for one:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1998401&catParentID=7872&scId=7872&oldParentID=7872
they are very easy to install.
Mar 17, 2009 | Delphi SKYFi XM Radio Receiver
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Fm tuning
For the best possible reception in FM mode, please ensure that the earphones are securely
plugged into the T.sonic.
In FM Menu
Scan for a Channel
Press the right (Next) or left (Previous) of Joypad once to step through selecting the
channel. Alternatively press and hold the right (Next) or left (Previous) of Joypad to
quickly auto-scan for the next channel.
Feb 17, 2008 | Transcend T.sonic 610 MP3 Player
Car Audio & Video Logo
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
Electro Med Services...
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
