Clarke Power Products Clarke 130EN Mig 110 Volt Logo
Anonymous Posted on May 04, 2010
What are the symptoms of te welder being too far
What are the symptoms of the welder being too far away from the power source?
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on May 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
6323
Points
22
Irractic welding, hot leads, and voltage drops. You need to size your welding leads accordingly.
Testimonial: "Thanks very much, I have suffered all of the above & finally a clapped out welder!"
I have a Lincoln Ranger 250 gas welder it runs but it won't strike a arc where should I start looking for the problem?
If your Lincoln Ranger 250 gas welder is running but not striking an arc, there could be a few potential issues causing this problem. Here are some steps you can take to troubleshoot the issue:
1. Check the welding leads and connections: Ensure that the welding leads are securely connected to both the welder and the workpiece. Make sure the connections are tight and free from corrosion or damage.
2. Check the electrode/ground clamp connections: Inspect the electrode holder and ground clamp connections for any loose or damaged parts. Ensure that the electrode holder is securely gripping the welding electrode.
3. Check the welding electrode: Examine the welding electrode for any signs of damage or wear. Replace the electrode if it appears worn out, as it may not strike an arc effectively.
4. Check the power source: Verify that the power source to the welder is adequate. Ensure that the welder is receiving the correct voltage and that the power source is providing sufficient power.
5. Check the welding settings: Review the welding settings on the welder to ensure they are appropriate for the type and thickness of the metal you are working on. Adjust the settings if necessary.
6. Check the welding environment: Make sure you are operating in a clean and well-ventilated area. Remove any contaminants or debris from the workpiece and ensure good contact between the workpiece and the ground clamp.
7. Check the welder's internal components: If the above steps do not resolve the issue, it may be necessary to inspect the internal components of the welder. This requires expertise and should be performed by a qualified technician. Contact a professional repair service or the manufacturer for assistance.
Remember, safety is crucial when working with welding equipment. Always follow proper safety precautions and wear appropriate protective gear, such as welding gloves and a welding helmet, to protect yourself from potential hazards.
These might help
What size generator does it take to run an omnipro 220 multiprocess welding system
Best bet to check you buy a generator to run your welder safely is check the power rating on your welder. Welders need a good power source else they will not run properly.
I have a 1995 miller legand gas welder How do i clean Sliprings and where are the sliprings located on onan engine
To clean the slip rings on your 1995 Miller Legend gas welder, you will need to follow these steps:
  1. Locate the slip rings on the Onan engine. They are typically located near the rotor of the alternator, on the end opposite the drive shaft. They will look like small, cylindrical pieces of metal.
  2. Turn off the welder and disconnect the power source.
  3. Use a wire brush to clean the slip rings by gently brushing away any dirt, debris, or corrosion. Be sure to brush in the direction of the rings' rotation.
  4. Use a clean rag or compressed air to remove any remaining debris.
  5. Reinstall the brushes and check that they are making good contact with the slip rings.
  6. Turn on the welder and check that the machine is running smoothly.
It's important to use caution when cleaning the slip rings, as they are a critical component of the electrical system and can be easily damaged. It's important to check the manual of the welder for troubleshooting steps and also check the warranty of the welder and see if it's still covered by the manufacturer. It's best to take your welder to a qualified Miller Electric welder repair service center, they will be able to diagnose and fix the issue if needed.
2answers
Why would the welder on the miller trailblazer 250G 4000 watt generator welder quit working but the generator still works?
There could be a few different reasons why the welder on the Miller Trailblazer 250G 4000 watt generator welder would quit working but the generator still works. Here are a few things to check:
  1. Check the welding settings, make sure they are appropriate for the type of welding you are doing. Make sure the voltage and amperage are set correctly.
  2. Check the ground connection, make sure it's clean and tight. The ground connection must be secure for stable welding.
  3. Inspect the welding cables and make sure they are in good condition and that the connections are tight.
  4. Check the welding gun and make sure it's clean and in good condition.
  5. Check the main contactor and make sure it's engaging and disconnecting properly.
  6. Check the main circuit breaker and make sure it's not tripped.
  7. Check the power output of the generator and make sure it's within the correct range.
  8. Check the control circuit and make sure that it's not damaged or malfunctioning.
  9. Check the engine oil level and make sure it's not too low, low oil level can cause the engine to overheat and stop working.
  10. Check the air filter and make sure it's not clogged, if the air filter is dirty, it will cause the engine to run hot.
It's important to check the manual of the welder for troubleshoot steps and also check the warranty of the welder and see if it's still covered by the manufacturer. If you are not able to find the problem or if you are not familiar with welding equipment, it's best to take your welder to a qualified Miller Electric welder repair service center, they will be able to diagnose and fix the issue.
Miller 302 remote wont work
if u want to use grinding machine, take power from auxillary source, it should be in machine,single phase supply. remote and grinder power do not have anything with this problem.
Coming out of the breaker box going to the welder plug what size wire should i use to run a lincoln 225 welder
It depends on how far away you are going to be away from the breaker box, using a #2 wire should be fine for your welder.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
1helpful
Mig 195 TE gas comes through when trigger operated then stops a few seconds later
you may have a sticking solinoid valve or you are using far too much gas which is holding the valve closed. reduce the gas flow to 12-15 lpm.also check the potentiometer for the gas flow.
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
3helpful
2answers
Clarke MIG welder parts??
what model is your clarke? i have a 125en which is the exact same welder as a craftsman, you could probably get a new feed motor or other parts for the welder itself from sears, the gun is a tweco style gun same as lincolns, so if you need tips or anything you can get those just about anywhere welder stuff is sold. i hope i helped.
Top Clarke Power Products Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
