Question about Behringer Ct100 Cable Tester
Beringher CT100.. X Pattern on LED grid when testing an xlr cable
Hey all, Im using a Beringher CT100 cable tester and I'm a little confused with a reading im getting from acouple of cables,
Im getting an X pattern on the LED grid when testing some xlr cables...
What does this mean?
The cable is being used for microphones and is a standard two core plus sheild balanced cable,
Ive re-solderd both ends twice to be sure the wires are solderd to the correct pins and I'm still getting the same reading..
I know this reading is correct for a mono unbalanced cable or xlr-jack cable but the manual staes that I should be getting a diagonal reading on the testers LED grid...
Can anybody help??
  • leopolddrumm May 06, 2010
    Hey fredy2, Thanks for the reply mate,
    Haha i thought myself I had misread the numbering at one end too, Hence the resoldering of the same two ends twice!
    Uncapping both connectors is exactly wht I do when soldering so I can be 100% sure of the connectors being lined up properly,
    I even have various printouts of xlr wiring diagrams so I'm 100% sure the way I have wired them is ok,
    Could it be a break in the wire somwhere or even a faulty xlr connector?
    Yea Ive downloaded the ebtech swiss army version manual and I have the diagrams but the info is very minamal,
    Thing is I do 3 different test tests on all my cables for shorts and intermiitance etc, On one cable in particular on the first test I got the right reading (The Diagonal) The second test was ok too but the third test..Where i was testing for Intermittent shorts between the OUT parts of the cable, I got faults.. So i did the standard XLR test again and I got this X reading???
    What this is telling me is that the connector may be faulty, Or even as this X reading (that is the right reading for mono cable) maybe is not really a problem!
    Whats buggung me is that I used this cable the night before at a gig and it was fine no problems, Then i test it an this happens
    Maybe I'm asking stupid questions to some people but Im always very careful with my leads and I'm safety concious when it comes to gigs..
    Im not really all that new to fixing XLR cables so Its not my wiring or lack of checking the pin line up is correct,
    But I am new to this cable tester and the manual is pretty crap! :)
    Again please help!
    Thanks in advance,
    John.
  • Behringer Master
  • 5,603 Answers
This site has diagrams... not the best but clear enough.
PLEASE note that the pin numbering is kind of goofy... The pins of both the male and female tie to identical pin numbers.
You PROBABLY have misread the numbering at one end.
A KEY thing is to get the shield on pin 1 at both ends.
I recommend that you uncap BOTH connectors, mate them, and verify the same color goes straight across as you solder the wires..
Note: I had some brand new cables delivered that the shield had been connected to pin 3 (middle one) and I had hum ! Note that this defect would NOT be caught by your cable tester as there was conituity between corresponding pin numbers.
Posted on May 05, 2010
  • Fred Yearian May 07, 2010
    Very strange... Possibly someone has stepped on the cable and caused a short.
    At this point the best thing is to use an ohmmeter and test it for continuity between like numbered pins. If those are all OK check for shorts between any two pins on the same connector.
    NEXT use the ohmeter to look for high resistance shorts. Set meter to high resistance and test between any pair of pins.
    LASTLY check if one of the connector shells MIGHT be shorted to one of the pins.
    I HAVE seen an XLR cable that had gotten "stretched" that severe breakage had occurred throughout the length of the cable.
    I had XLR cables delivered bran new that the shield was swapped at both ends. The weird numbering of the pins apparently confused the assembler.
Every cable I test shows a pin 1 & Pin 3 crosswire even though I know it is wired correctly. Is there a way to reset the tester?
That would be a very odd situation. My question would be has it always done this, or is this something new? Is in in all cable formats, or just xlr? You could open the unit and make sure a stray wire strand isn't across wire terminals, but that would be the limit of user servicable things for this. Other than that, contact the manufacturer.
Jul 30, 2015 | Whirlwind DCT9 Cable Tester
Behringer CT100...X Pattern on LED grid when testing a mono instrument cable
Yes, a display of "X" means the cable is good. This guy does a good job with laying it all out. There's other modes to check the cable.
http://guitarkitbuilder.com/content/gear-review-behringer-ct100-cable-tester
Jan 20, 2013 | Behringer Ct100 Cable Tester
After we switch from the auto to another manual mixing board the volume on one of the mics is decreased dramatically. all other mics are not effected. both boards are linked and we have a toggle switch to...
Check the cables. If one lead of an XLR-XLR cable is shorted to ground, 6 DB gain is lost. You haven't really supplied enough information regarding cables and model of the manual mixer for us to help much. Do check that ALL of your audio interconnections are BALANCED lines either XLR to XLR or TRS cables. Grounding one side of a balanced line reduces gain 6 DB. Try swapping mic cables and channels to test where the problem is in the system.
Aug 31, 2011 | Shure Distribution Shure SCM810 8 Channel...
Have an A&H 32 chan , gl2400. when testing with the mic, i get a loud hum when boosting the master very up. Not happening with line source.
Make sure your mic cables are XLR to XLR and not cheesy Karaoke type cables with 1/4 inch mon plugs on the end. Please note that I have found some mic cables with wiring errors. They had the shield and one of the signal lines reversed. please verify that your XLR mic cables are wired with:
Go to thiis site and verify your cables:
http://www.toffer.com/wp/2008/08/07/3-pin-xlr-wiring-diagram/
Please note the pin numbers as they may not be what you expect. Ground is actually the shield or braid and the red and black are twisted pair signal lines.
Aug 24, 2011 | Allen & Heath Gl240032 4 Bus 32 Input Live...
I need owners manual
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa
Jun 18, 2011 | Behringer Ct100 Cable Tester
Brand new ag30 when I plug my mic sm58 into it all I get is static no sound as in singing comes through it I'm using a XLR to quarter brand new lead.. Have tried everything when I hit the tip of mic sound...
You should be using XLR to XLR cable, NOT a 1/4 inch cable. There is a problem of the 1/4 inch being the unbalanced version and is not compatible with this unit's input.
Use the XLR to XLR mic cable and it will work fine.
The cable you have would work for one of those cheap Karaoke machines...
Mar 25, 2011 | AMP Acoustic Ag30 30w 1x8 Acoustic Guitar...
I have a Behringer 1202fx and I'm going to use it with a pair of Harbinger APS15. The line inputs on the APS15 are unballanced R&L RCA and XLR. The Behringer 1202fx mains are 1/4" unballanced...
Personally I would run the RCA outputs to the RCA in on the APS.
If you insist on using XLR from the APS to the board (like through a snake etc) I would higly recommend using XLR to 1/4" adapters. These things have wonderful little transformers in them (yes, wire wound transformers) that do the 1/4" to XLR conversion really nicely so that you can run your signal through the snake or just so that you don't get the hum and distortion that can be associated with unbalanced signal transfer.
You want a HI-Z unbalanced to LO-Z balanced adapter.
Not always easy to find, but if you absolutely cannot locate any, I have a couple in stock.
I suggest you look around though, because mine aren't cheap!
Feb 27, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
My mic output is very weak. Music comes out great. I have to set the levels all the way up to get any mic sound and usually there is a lot of clipping. You need to almost scream to get any sound with a...
Thiis amp has plenty of gain for mics. Make sure your mic has a good XLR to XLR cable (balanced) and connects to the XLR input connectors. If you have 1/4 inch jack cables that aren't TRS balanced on the mics, get rid of them and get XLR's.
Then push the PFL button down (LED will light red) for a single channel with a mic and adjust the trim (top knob for the channel) so that the level peaks without clipping on the main LED display when highest input to the mic is being generated. You should not get clipping then during operation.
After that you use the slider tio adjust the level for the mic. The MAIN slider should be at least up around -10 to zero during operation. If your main slider is way down, then you haven't balanced your channels properly. Do the same for each channel as the instructions for the mic above. If the gains of the other inputs are too high and the MAIN slider too low, this is what is causing your problem.
Typically the trims for mics like Shure 58 are about 3 o'clock.
High level guitars may have trims anywhere from 9 to 3 o'clock.
Ideally you will want your channel sliders to be between -10 and zero.
Sep 11, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
How can i check cable on ct100
These are a simple DC continuity/short tester.
You just plug both ends of the cable in and there are indicators showing condition.
HOWEVER: I recently found 6 brand new cables that resulted in HUM from mics. These cables had a pair of wires reversed at BOTH ends and contiuity was fine, but the shield was on the wrong pins of the XLR.
If this is your problem, you will find that the shield of the XLR is connected to pin 3 instead of pin 1. The numbering of the pins are weird on XLR connectors with pin 3 at the APEX of the triangle.
Cables MADE IN CHINA... I changed all the connections on site of the gig as I had soldering equipment. I informed the vendor... they had 13000 of these in stock and many must be in the field. They were going to check them,,, I am sure my 6 cables wern't the only bad ones.
Moral of the story: there is more to electrical cables than just continuity!
Jul 03, 2010 | Behringer Ct100 Cable Tester
I have a crate cpb150 amp i want to connect it to my digitech gsp2101 via livewire stp-202 cable what is the correct way?
I can understand your confusion... and a lot depends how you are going to use this. There are some caveats regarding the connections,
If you use the 1/4 outputs on the GSP, there is a speaker modeling like function that is NOT available, that IS available IF you use the XLR outputs.
The STP is an "Insert Snake" which is not really what you want as it is intended to send and receive (audio going both directions in the cable.
If you want that speaker function, then you should get two XLR to 1/4 TRS cables and go from the XLR's on the GSP to the Left and Right inputs on the back of the Crate. Your audio or guitar then is connected to the GSP guitar input.
If you connect the guitar to the crate and then use the STP, Plug the TRS single connector into the Left/Mono/send/rtn on the Crate. The Send cable of the Y should go to the Send jack on the back of the GSP and the return should go to the left return jack of the GSP. This connection I would NOT recommend as it will be noisier and you will lose the stereo effect capabiltiy since the effect is inserted as a mono.
I believe you would be happier with using the XLR's to carry left and right to the Crate and run your inout to the GSP. In short, you have the wrong cable to do the best job.
Jan 30, 2010 | Crate Music
Behringer Ct100 Cable Tester Logo
533 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
