Question about Lite On LiteOn LH-20A1P - Disk drive - DVD±RW (±R DL) / DVD-RAM - 20x/20x/12x - IDE - in Burner
I got a dvd writer as present. from my brother .
I got a dvd writer as present. from my brother . but i didn,t knoww how to run it or use
  • 78 Answers
Is internal or external
Posted on May 04, 2010
DVD Burner Not Found
male sure the laptop has teh burn dvd capability cause it can be just a cd writer and dvd rom ..and in this case it is explainable why its giving the error ..
If you are sure you have a dvd writer ...than be sure you select it in the options of the burning software you use..
and 3rd ... if your writer is corrupted ..try to go to device manager ..(click right on compuer select properties..and device manager..) in there look for dvd writer...click right on it ..and select update driver...If the disk is not present click right on computer ..and select scan for hardware changes...If the writer is deactivated this will bring it back ..Than update its driver and be sure it's not in yellow cause this means the driver is not the correct one ..
If no action will correct this ..and still makes the same ..than I suggest to reinstall the operation system ..and this way you will eliminate the possibility that a bug corrupted it ...and in case it still not working you have to consider replacing it ..but not before trying a operation system reinstall ..cause there are viruses that attack the disk drive's driver ..and this is the only fix .
Nov 29, 2011 | Sony VAIO VGN-CR220E/P Notebook
My LG dvd writer does not read cd or dvd
That's a lot of questions! Well, the speed at which a CD/DVD-Writer writes to a CD-RW depends not only on the media and the drive, but also on the table of media types that is built into the firmware of the writer. The drive tries to recognise the blank media inserted, and matches it with the list in its table to decide the speed. It also reads the speed certified by the media manufacturer, and if these don't match, the writer decides to use a safer, lower speed.
Another reason could be that the writer does not support the intermediate speed of 12x-for example, it may support lOx, with the next supported speed being 16x.
Your motherboard supports IDE as well as SATA hard drives of the highest capacities avail­able. You cannot add more RAM running at a different frequency, but you can certainly replace your present RAM with 533 MHz DDR2. It supports any Intel processor with the LGA775 socket interface barring dual-core processors.
Feb 27, 2011 | Computers & Internet
Hey brother my writer shuts down the computer when i put the cd plz help everytime its doing same thing
restart your system or otherwise eject the writer data cable and attach it again. or if the problem is continue then change your data cable of the writer
Jun 27, 2010 | Samsung SH-S202J 20x DVD?±RW DL IDE Drive ...
Replaced IDE DVD writer with a SATA DVD writer. Powered up XP Pro system, but no drive letter shows up. There is power to the DVD drive, but the OS does not see it. No BIOS updates available from EPoX.
Check your bios settings. If you already have two SATA hard disk drives in your system the bios should also list your SATA DVD writer as third in the list. Make sure the bios list the DVD writer. Remember all SATA drives including SATA DVD drives are all seen as Masters. Check your Boot order settings as well. If windows sill does not list a drive letter for your SATA DVD click, Start/Run and type: diskmgmt.msc in the run window. Assign a drive letter to the drive manually.
Cheers!
Mike
Oct 22, 2009 | EPoX EP-4PDA3I-3 Motherboard
Sh-s202 dvd writer recognises DVDs to play, but not to burn onto.
Try using a quality dvd lens cleaner. Run it a cycle or two of cleaning then retry the dvd. If it works it was just a dirty laser. If this doesn't correct the problem then it might be a dvd optics issue. Hope this helps.
Mar 17, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
Dvd writer
run filtercheck 4.6 or some tool to remove upper and lower filters.
Aug 18, 2008 | NEC ND-3550A DVD RW Dual Layer Burner
Compaq presario dvd writer light blinking, dvd not working
check if power jack working right. Try to change it with other jack. Sometimes the pins inside jack are loose. try to tight them.
May 12, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
Burning problem
well..you might start by looking to see if that dvd is present through control panel system device manager
Mar 22, 2008 | Acer Aspire 1640Z Notebook
Burning trouble
the lens of your dvd writer might not be working properly anymore, i strongly recommend that you replace your writer with a new one.
Sep 03, 2007 | Samsung (DXP47810JL) 5 Pack 8x DVD+R...
I am having a LG DVD writer GSA-4167B currently stops reading or writing disks after few runs
as with all writers eventually they fault at the lens and it gets out of line and cannot read discs, you can try the usual thing of checking LG for any firmware updates, but first:- Go to my computer>right click>hardware tab>device manager, then down list to cd/dvd drives and click '+' sign and highlight your writer, right click on it and select uninstall. Restart PC and it will be automatically re installed, try again and if no change you will need to replace the drive as they are cheaper nowadays.
Jun 19, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
Lite On LiteOn LH-20A1P - Disk drive - DVD±RW (±R DL) / DVD-RAM - 20x/20x/12x - IDE - in Burner Logo
65 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
