Question about HP Compaq Evo Notebook N800c PC Notebook
No volumes found
When computer says "No volumes found"? When a computer says "No volumes found" what exactly does that mean? No partitions made??? This happens when I try to get my laptop started and it goes straight to the black screen instead of opening windows. I still can hit f10 and get into my bios if I want to alter something so this would be a good sing then that I can still access my bios right? This laptop came from my fathers work as a employee freebee which was once used for the business. Im sure they had to erase everything but I think my dad said windows xp was still on it. Any help would be greatly appreciated. ;} Sorry, Im not too computer smart. ;} It is a HP Compaq Evo n800c THNX!!
    President:
  • 2,666 Answers
Thre is no OS recognised as being installed probibly due to the company erasing everything before releasing the laptop. You need to reinstall XP or the system of your choice making sure that the laptop is compatable.
I would start with XP and upgrade as necessary.
Posted on May 04, 2010
I recently found some awesome altec lansing speakers with a huge sub too. but ... i can't find the volume control knob and without that, i can't make it work !! T___T any solutions? i tried looking for...
Hi there, by saying you found, do you mean that is a complete set, I have the same speaker set, and the volume control knob is on one of the satellite speaker. If you are missing that speaker I doubt that you can do anything with it because you will most likely find them for sale as a set and not separate. Thanks hope this helps.
Mar 09, 2011 | Altec Lansing ATP 3W Computer Speakers
Very low volume output even with the volume turn all the way up. I connected the system to different computers and came up with the same problem. The volume on the computer is also turn all the way up and...
I had the same problem and found the root cause to be the RF speaker connector at the back of the subwoofer. The male and female connectors are OK. It is the 5 male pins inside the connector and the way they connect to the female holes that is the problem. Wiggle the RF speker connector as you move it in and out until you get 100% of audio voilume back. Once you get it back, do not move the connector. Have not found a permanent solution to date beyond this.
Jan 08, 2010 | Dell ADA745 Computer Speakers
It won't turn on
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 31, 2009 | Philips GOGEAR SA6045 MP3 Player
I am geting a distorted song in my computer speakers
What do you mean more exactly by "sound like if the computer freeze"? If you set wave or master volume on your PC too high, the sound card or the speakers may get overdriven, which results in distorted sound. So you could try lovering the voume in your PC, and set it higher on the speakers. (On the contary, if you set volume in your PC very low, and very high on the speakers, sound will get noisy.)
Mar 19, 2009 | Audio Players & Recorders
Not comeing up on my computer
Reset the player
If that fails:
Download the newst version of the Philips Device Manager:
Instal lthe new Device Manager
If still nothing:
-Tha Mp3 Doctor
Feb 19, 2009 | Philips SA3125\02 MP3 Player
Not Charging
Make sure the lock is not engaged first.
I would go ahead and do the firmware upgrade for your exact model #:
http://support.rcaaudiovideo.com/downloads.aspx?product=187
If the PC won't recognize the device,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 23, 2008 | RCA OPAL M4001 MP3 Player
Your rca
will probably have your answer
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 23, 2008 | RCA H100 MP3 Player
Portable device will not open model YP_K3
Go to the following page on Samsung's website and select your EXACT model number - the part that comes after the YP-K3 - if they still have the software, you will find it there:
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=audiovideo&group_cd=&type=mp3players&type_cd=&subtype=flashmemory&subtype_cd=&model_nm=YP-Z5ZP%2FXAA&dType=D&vType=L&mType=&model_cd=&menu=&prd_ia_cd=&acc_ia_fl=&disp_nm=YP-K5&isEqualsY=
May 30, 2008 | Audio Players & Recorders
Mp3
May 22, 2008 | iLO (2 GB) MP3 Player
HP Compaq Evo Notebook N800c PC Notebook Logo
50 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
