Question about Uniden GMR648-2CK (22 Channels) 2-Way Radio
Batteries don't hold charge
My uniden 2 way radio doesn't hold charge even after sitting on cradle all night
    President:
  • 2,761 Answers
This is frequently caused by corrosion on the battery contacts and the contacts inside the radio. Remove the batteries and wipe all the contacts firmly with a clean dry cloth. Heavy corrosion may require cleaning with a fine wire brush, steel wool. or sandpaper. After the cleaning, make sure that there is no residue in the battery compartment, then replace the batteries and give them a good charge. If this does not work, it may be time for new batteries -- especially if yours are more than a year old.
Bill B
Posted on May 05, 2010
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
I have a GE model 25836CE-B cordless phone. My problem is this: when the phone is off the charger base, after a few minutes it will keep on beeping even if no one pressed the paging button at the charger...
Actually, you can't overcharge the battery. The base is designed to hold the handset indefinitely. Once the battery is charged it doesn't do any damage. You probably just don't have the battery charged enough to use the phone. Leave the handset on the base overnight, let the thing charge, and it should work properly.
Jul 12, 2011 | Uniden Cordless Phone
Where can I buy an A/C charger for my Uniden Atlantis handheld marine radio? I lost mine.
Your power cord and charging cradle are not listed as available accessories. I suggest you follow the link below and send a query directly to the Uniden customer service center.
http://www.mycusthelp.com/uniden/
Nov 03, 2009 | Atlantis Crystal Uniden Atlantis-250 VHF...
Battery life
I have the same problem. Replacing the battery solves it, but for about 6 months, then the new battery holds less and less charge.
Apr 20, 2009 | Uniden TRU8866 Cordless Phone
Binatone Cordless Phone (2nd set) loses charge quickly
The batteries that are in most cordless phones, and even cell phones, have a "memory". If the battery is constantly being fully discharged from a lack of charging, or if it's used to being on the charger all the time, it will reduce the life of the battery substantially. You'll need to get a new battery, and try to make sure that the phone is placed back on its charger every night before you go to bed. This should allow the battery to receive a full charge each night to prevent full discharge and lengthen the life of your battery. I went through about 2 or 3 batteries once before I found this out. I'm sure that you'll find this helpful and it should save you a few bucks in not having to replace your battery as often. Please rate me accordingly, if it's not too much of a bother. Thanks and have a nice morning!
James
Nov 24, 2008 | Uniden Cordless Phone
Dropped it in the water
Hello Penny2,
It does not appear (based on the manufactuer's website) that the charging cradle for the Uniden GMR638 is compatible with any other radio models.
You may not be able to purchase another GMR638 if you only want a single radio to replace the one that was dropped. The current trend is for manufacturers to bundle consumer two-way radios in packs of two, three or four since most users do not purchase single radios.
If you definitely want to get the exact same model you might have to either purchase another two-pack or contact the manufacturer directly to see if they have single units available. Otherwise, any 22 channel FRS/GMRS combo radio should be able to communicate with your Uniden radios.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 12, 2008 | Uniden GMR638-2CK (22 Channels) 2-Way...
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Uniden GMR648-2CK (22 Channels) 2-Way Radio Logo
135 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
