Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
I continue to get Printer disconnected with vista. I can not no maatter what I try get it to connect.
  • Kodak Master
  • 5,382 Answers
Try a new USB cable and/or a different port. (If you are using a print server or USB hub, try a direct connection.) Make sure the USB ports aren't disabled for security or power savings. (Check the device manager from the Control Panel in Windows and the advanced settings from the Screen Saver settings.) Check if a known working device works in the USB port.
Some of these printers have monitoring software as part of their full-featured software, so check that this software is running.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/9104/9106&product=EKN033540&operatingSystem=windows_vista if you want to reinstall the software (uninstall the old version then disconnect the USB cable before reinstalling.)
The worst case scenario is to try the firmware update from the above link. Try everything else first, the firmware update can cause more problems.
I hope this helps.
Posted on May 04, 2010
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
Just hooked an old lexmark 3300 printer to my windows vista. When printing it says communication not available
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ffZS77. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X1270 All-In-One InkJet Printer
How to intall it on windows vista
1 Insert the installation CD into the drive.
2 Welcome... will appear. Click Install.
3 Accept the License Agreement, and click Continue.
4 Install Additional Software will appear. Make your selection and click Continue.
5 Setting Up a New Printer? will appear. Select Yes, I am setting up this printer for the first time, and click Continue.
NOTE: If the printer has previously been configured on another machine, select No, my printer is already set up. I am installing it on another computer. Skip to Step 7 below.
7 Connect Your Printer appears. Connect the USB cable between the PC and printer. Select Connect USB Cable now, and click Continue.
8 Accept the prompt to Print a Sample Page, and click Continue. Image
9 Product Registration appears. Select whether or not to Register the product and take part in the Lexmark Connect Program. Click Continue.
10 When Thank You appears, click Finish.
Apr 14, 2009 | Office Equipment & Supplies
Can't connect printer to Dell Studio 17 Windows Vista
Download the VISTA driver from the website. Disconnect the printer.uninstal it and reinstall it using the newer downloaded driver. Worth a try.
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?~ck=ln&c=us&l=en&lnki=1&s=gen
Feb 03, 2009 | Dell 924 All-in-One InkJet Printer
Cannot connect my printer to my computer
This came right off of the lexmart site
Attention Windows Vista Users: Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Nov 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
Hi there i have a windows vista basic laptop, bought in febuary 2009. i have a HP all in one printer which has been disconnected from my home PC as this PC no longer works. i am trying to load the CD...
try just connecting the printer to the laptop without the cd first. Vista has lots and lots of drivers to install this printer. It will pick it up once you have connected it to the laptop and then turned the printer on. The Cd was probably not made for vista.
Nov 14, 2008 | HP Office Equipment & Supplies
Unable to print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Sep 07, 2008 | Lexmark X73 All-In-One InkJet Printer
Searching drivers for sharp AR-5316 for windows Vista platform.
are you sure it is for a Vista or is it trying to load to a Windows based OS???
try this site
http://promosearch.sharpusa.com/search/?sp-q=ar%205316%20drivers&sp-a=sp10009e61&sp-k=
Personally I do not like their site it is not as user friendly as other sites. ( have to do a lot of research to find what you want)
Good luck
Aug 17, 2008 | Sharp AR-5316 Advanced Digital Imager...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
