Question about ASUS Eee PC 900HD Netbook
Cannot connect to wireless internet - ASUS Eee PC 900HD Netbook
    Guru:
  • 229 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Please follow this steps carefully
Turn on your internal wireless card?
If your wireless card is built in to your computer, there may be a switch on computer that turns the card off and on. When new from the store, these switches are often in the "off" position. They can also accidentally get switched off during use. Find the switch (often near a symbol that looks like a microphone or radio tower emitting radio signals), and turn it on. The card should now find wireless networks in the area and connect.
Find the scrldcolville network?
If your wireless device is properly installed, your computer should automatically start scanning for networks in the area and will inform you that there are wireless networks present. If not, you can scan for networks in the area manually.
*To bring up the Wireless Network Connections menu, go to the Start Menu (in the lower left-hand corner of your screen, choose "Settings," then chose "Network Connections," and finally, choose "Wireless Network Connection." Clicking on this option in the menu should bring up a window. In the upper left hand corner of the window under the heading of "Network Tasks" there should be an option that says "Refresh Network List." Click on this option to search for wireless connections. Choose scrldcolville, hit the "Connect" button in the lower right hand corner and enter the passkey to connect.
Enter the passkey correctly?
If the passkey is entered incorrectly, the computer will appear to connect to the internet, but will not actually connect. If you think you may have entered the passkey incorrectly, disconnect from the scrldcolville network (see steps above in #5) and then reconnect. Often, as you manually reconnect to the network, the computer will remember the passkey and a small window will pop up, showing the password as a line of dots. Re-enter the passkey correctly before connecting.
(#6, cont.): Sometimes, your computer will not allow you the option of re-entering the passkey when you reconnect to the network. If this happens, bring up the Wireless Network Connections menu. Click on the "Change advanced settings" option under the "Related Tasks" heading. Another window saying "Wireless Network Connection Properties" should pop up. Click on the "Wireless Networks" tab at the top of the window. Under the "Preferred Networks" heading, there is a box that lists all wireless connections your computer has ever used. Click on the scrldcolville network to select it. Now hit the "Remove" button just below the box, then hit the "Ok" button. This will make your computer forget the scrldcolville network and the bad passkey. Bring up the Wireless Network Connections menu again and connect to scrldcolville .Be sure to enter the passkey correctly.
Allow your computer to obtain an IP address automatically?
Be sure that your computer is set to obtain IP addresses automatically and that it does not have one assigned manually. To do this, bring up the Wireless Networks Connections menu .Click on the "Properties" button. Here, you will see a list under the heading "This connection uses the following items." Scroll down the list until you see an item named "Internet Protocol (TCP/IP)." Select this item and hit the "Properties" button just below the list. This will bring up a new window. In order to connect with the library's wireless device, you must have the option "Obtain an IP Address Automatically" selected (ditto for the DNS server address). If you are set with a manual IP address, you can click the button to obtain your IP address automatically (ditto for the DNS server address.) Be aware that this changes how your computer interacts with other networks. If you need a static IP address on other networks, you may have to reset your IP address again later. However, your computer cannot connect to the library's wireless network unless it obtains its IP address automatically from the library's wireless device.
Make the Windows wireless configuration your default configuration?
In many computers, Windows acts as the default wireless network configuration program. However, if you have an external wireless card, or if your computer has a secondary program enabling it to connect to the wireless network, you may discover Windows will not recognize your wireless connection program and visa versa. Sometimes, if you have a non-Windows program that runs your wireless card (for example, a Linksys driver for an external Linksys wireless card), the non-Windows program will connect to the wireless device, but Windows will not recognize that this secondary program has connected. You will need to allow Windows to control the wireless configuration in order for your computer to fully recognize the wireless connection. On way to solve this problem is to tell the secondary program to "stand down," as it were.
On some computers, an icon for your secondary wireless program will appear in the lower right-hand corner of the taskbar on your desktop. You can click on this icon to open the program options. Certain programs will give you the option to switch to Windows as the default manager of your wireless connection. This will allow you to use the Windows Wireless Network Connections menu to make changes to your wireless connection.
Posted on May 04, 2010
My lap top isnt set up for wireless connection to internet
Connecting laptop/computer to wireless router
If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jun 16, 2012 | Samsung Computers & Internet
Setting up wireless conection to my wii
  • 1Before you connect Nintendo Wii to wireless Internet, set up your Wii console according to the manufacturer's directions.
  • 2Turn on the Nintendo Wii and wait for the main menu to appear.
  • 3Using the Wii remote, point and click on the small Wii button in the bottom left corner.
  • 4Select Wii settings.
  • 5In the bottom right corner click the black square with the number 2 in it or use the right directional arrow to go to the next page. When you come to "Internet" click it.
  • 6To connect Wii to the Internet select "Connection Settings."
  • 7On the next screen select the first connection that says "none."
  • 8On the following page, when given the option for wired connection or wireless Internet, select "wireless."
  • 9Now it's time for your Wii to search for a wireless connection. To do this choose "search for an access point."
  • 10Press "okay" and find the name of your wireless Internet. If it's not on the first page, arrow down until you find it. If you need a password to access the Internet, you will be asked to enter it. Click okay.
  • 11Click save and okay so the Wii remembers the wireless Internet connection options for the future.
  • 12Finalize the Wii Internet connection process by testing the wireless connection.
  • 13When Wii's wireless Internet test finishes successfully, you're ready to play Wii online.
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6AZS48m
    Nov 26, 2011 | NetGear WGR614 Wireless Router
    Cant connect to my router netgear
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6B48YnB
    Connected wireless to router, excellent signal, but unable to connect to internet.
    connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
    Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
    good luck!!
    Oct 07, 2011 | Linksys Wireless-G WRT54G Router
    I would like to know when it say laptop with built in wireless. Does that mine i already got internet service on it. Or i have to buy USB modem.
    Hello Blac,
    All the laptops available in market have built in wireless 802.11 b/g/n or 802.11 b/g/n Bluetooth® wireless networking. It means that you can access the internet via Wi-Fi or through Wi-Fi hotspots. In wireless connectivity you do not require the wired connection to access the internet. In home you can connect the laptop via wireless connection using the home networking router available in market. The advantage of wireless connection is that you can use the internet in your home anywhere with in 100 meters of range with proper wireless signals. You will require to get the internet connection from the ISP(Internet Service Provider).
    Please visit the link provided below for Home Networking Wireless Router :
    http://www.netgear.com/home/products/wirelessrouters/
    Jun 29, 2011 | Computers & Internet
    The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
    Try turning off the router for 30 secs, then power it up again.
    Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
    If you can connect to the Internet then -
    With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
    Also install the latest wireless card driver.
    Then test the wireless and Internet connection. If this doesn't work -
    Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
    If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
    If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
    Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
    Wireless internet on compaq presario 6425 tu
    Do you know for sure there is a wireless connection in the area you trying to connect, Wireless internet isn't accessible every were and when it is available it could be protected by a security pass phrase. The only way to really get full use out of your wireless internet is to go to a company that sells the wireless internet cards
    Jun 17, 2009 | Compaq Presario Notebook
    Unable to connect to wireless internet. wireless connection shows disabled.
    check whether wireless drivers are installed.
    check wireless is enabled.
    check in network connections whether u can c wirelass lan connection.
    Apr 21, 2009 | Computers & Internet
    My lap top connects to the network but I cannot get on the internet
    u need a wireless key to connect to the internet, log in to the router page and wireless settings - copy the wireless key to get connected wirelessely
    Nov 04, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
    Wireless and internet
    1. Make sure that wireless settings are properly synchronized.
    >> ssid/security key.
    2. Check your computers wireless connection status
    > Make sure that it is set to "obtain ip address automatically)
    3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
    > You need to know your router's ip address and dns
    4. Disable firewall on wireless pc.
    Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
    ASUS Eee PC 900HD Netbook Logo
    564 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
