Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
I put pool on an timer after pool has been off for an hr will not get its prime back. I have alot of agiation in pump skimmer basket when running and alot of air and bubbles returning to pool I also think i may be losing water.
    President:
  • 1,902 Answers
You have a massive air leak either in the pump or going to the pump, that you will need to dig around and look for, A cheaper solution is to try to find a used pump, buy it and see if it make any difference. There is also a main seal in the that is sometimes bad or is not set right that can be replace or repaired REALLY easily
Posted on May 04, 2010
How do i prime this swimming pool pump?
The normal procedure would be to unscrew the top of the inlet basket and fill that with water until it flow out down the inlet pipe, then replace the top cover. Make sure the skimmer box basket is clean, the pool water level is high, or put a fast running hose in the skimmer box to make sure the primed pump does not have to pull the water up from too low at the inlet.
If it will not pull the pool water in when started, then -
- there is a leak or blockage somewhere on the inlet side
- the pump impeller is damaged
- the filter is clogged too much and causing back pressure
- the pump power and pipe sizing are mismatched
Oct 08, 2014 | Pool & Spa
Prime
Hi to prime your pump you fill the strainer basket with water and make sure all connections are tight with no leaks. Once you seal the lid turn on your pump and it should prime. If you have an issue you can force water through the suction line by putting a hose in the skimmer and force the water through your suction line. Time to Open the Swimming Pool
Jun 06, 2013 | Waterway 1 HP HiFlo Above Ground Pool Pump
Pool pump wont prime
if this is a inground try only the main drain if it works something is in the skimmer line
Jun 01, 2013 | Pentair Pinnacle High Performance 1 HP...
My pump isnt priming. I have put water in the area with the basket and it isnt filling up. We have replaced the seal and the tank doesnt seem to be filling back up therefore the water isnt filling up in...
Is there enough water in the pool 1/2 way up the skimmer flap to prime the lines, Are the skimmers clogged? Are all valves in their correct position? Have you checked the gasket on the top of the filter? Is the spring weak/broken, handle should have some tension, has the gasket rolled, torn or slid?
Sep 11, 2010 | Hayward SAND FILTER, PRO SERIES
My pool pump will run fine once I prime the system from the top of the pump basket. Then once the timer shuts the pump off, when it trips the switch to run again there is no water in the pump and it cannot...
If you are a long way above the surface of the pool and you have a leak on the filter it could be a check valve problem.
With it competly loosing the prime it sounds more like a suction leak. This will be in the plumbing and will need a re-plumb or it could be as simple as a lid "O" ring or cracked lid.
What happens is the air get's in the tank and air will compress when under pressure. Then when the pump shut's down the air can expand again. When it does it will rush back through the system and blow the prime right out of the pump. Quite often you will see water blow out of the skimmer or just blow the skimmer lid off. I hope this helps. Good luck.
Sep 09, 2010 | Tristar Hayward 15 Hp Inground Swimming...
Not self priming itself. when it turns off the water pushes back out of the skimmer and pushes the basket up. it loses water and the pump cant re-prime itself.
PRIME PUMP, OPEN AIR VALVE ON FILTER. OR TAKE THE LID OFF YOUR FILTER AND SEE IF IT STARTS TO PUMP... YOU DO HAVE IT PLUMBED RIGHT? THE PIPE COMING OUT OF THE PUMP GOES TO THE FILTER !! I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Aug 28, 2010 | Waterway Inground Pool Pump Champion No....
How do I vaccum the pool? I dont know if I turn the Veriflow to out and then where do I hook in the hose?..Its my girlfriends pool and she just expects me to know. Thanks
Oh then you DO need help. To vacuum you don't need to change the valve setting on the filter, but if there is a valve on the intake selecting main drain/skimmer you can select skimmer only, but I usually only do this after I have the hose primed. . You attach the hose to the skimmer inlet. Usually there will be a round plate attched to the hose that fits into the skimmer ( you may have to remove the basket) If you don't have that round plate on the hose, then you can insert the hose driectly into the bottom of the skimmer. Before you attach the hose, connect it to the skimmer head on the pole. Submerge the head and hose. Allow to settle to bottom. Put all the hose into the pool. Take the other end and hold over the discharge back into the pool to fill the hose with water (prime) until air bubbles stop coming from vacuum head. Then hold your hand over the hose (to keep from loosing prime) and quickly attach to skimmer. You may hear some air, and the pump may stop pumping fully mommentairly untill it is pumping full water again. Now you can select the valve to divert all the flow from the skimmer
Aug 13, 2010 | Hayward SAND FILTER, PRO SERIES
My pump is not drawing water from the pool, dissambeled pump and it is clean and free of obstructions. removed pump from motor and inpeller is spinning when plugged in and the defuser seems to be ok...
Ok I''m assuming the pump is mounted higher than the water level in the pool. This means it needs to be primed. If everything is air tight, it should be self priming. Check to be sure your piping is open from the skimmer to the pump and not clogged. You can put a garden hose into the suction line of the pump and feel for flow coming up out of the bottom of the skimmer. If that is ok, then fill the pump strainer basket with water. Be sure filter is selected to filter. Make sure that the basket cover is tight to the cover gasket. After filling basket with water, quickly close the cover and start pump. If it still doesn't work, fill the basket again with water and check for any leaks. If the mechanical seal is leaking, it will not self prime. I'm not sure what type of pump you have, but Hayward has complete manuals for their pumps on www.haywardnet.com. Most pumps work about the same. GOOD LUCK!
Aug 02, 2010 | Pool & Spa
How to prime my Pool?
Prime is the term we use to state that the air has been mostly purged from the pump and the pump is moving water. When you have lost the prime, your pump is no longer pumping water through it. Sometimes it can be very difficult to regain the prime on the pump. This will tell you how to get the prime back in these difficult situations
Aug 27, 2008 | Intex 2500 Gallon Sand N Sun Pool...
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
85 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
