Question about Honeywell 510477 Oil Filled 7-Fin Radiator Heater
Do I need to ever add oil to my heater?? - Honeywell 510477 Oil Filled 7-Fin Radiator Heater
  • 1,476 Answers
No. It comes correctly filled from the factory and usless it would develope a leak should never need oil. Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 05, 2010
Pelonis oiled filled heater ho-0218 won't heat up
burnt thermo fuse or element. be sure to connect any wires tightly if you replace thermo fuse. test it with a mulimeter should show less than 1 ohm. no you do not need to add oil, if the unit leaks throw it out.
Mar 24, 2014 | Pelonis Heating & Cooling
Do i have to add more water or any thing to it after it has been in use
The heater is oil filled as stated in the description. You don't add anything to it for its operating life
Feb 10, 2013 | DeLonghi TRD0715T Oil Filled Radiator...
WHERE DO YOU ADD OIL TO THE HEATER AND WHAT KING D OF OIL DOES IT USE?
As far as I know you never add oil ... it's a sealed unit. The only way it would ever need oil is if it leaked. Then it would probably cost more to fix than replace
Feb 22, 2011 | Pelonis WM-HO202C Oil Filled Radiator...
Do i need to add oil
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman101
Jan 12, 2011 | DeLonghi EW0507 Oil Filled Radiator Heater
How do I add oil to help heater warm better??
they are a sealed heater you can't add oil to get more heat, if you can must be a new type i haven't seen, but if not hot enough throw away and buy a heater that works they work on the principal that an element heats the oil and runds on an internal thermostat to control temperature of oil, your element may be starting to deteriate the same as hot water you only notice with hot water as it starts to not heat the water as much and you feel this in a shower or bath but you won't notice the same in oil heater it won't heat as it has and it may also be the thermostat, inside heater i wouldn't even bother trying to repair waste of time and money i would buy a proper working heater prefrably one that could be fixed to go better after its starts to deteriate a lttle
Nov 29, 2010 | Lakewood 2727 Heater
Do you ever have to add oil if so where is the fill cap
Those units are sealed, this traps the oil inside and provides a maintenance free heating system.
There is no need to and therefore no provision made to add oil to the heater.
heatman101
Nov 05, 2010 | Lakewood (5500) Oil Filled Radiator Heater
Where do you refill the oil at
Oil heaters are not meant to be refilled. The oil is inside the heater already. If you need to add oil, the heater is defective. Do not use it.
Dec 16, 2008 | Lakewood Oil-Filled Electric Radiator...
Diesel
well, somebody once told me that if you add a quart of oil to 5 gal of kero, it makes a good diesel substitute. So, in theory, I would add a little ethinal (corn gas) to the kero.
Feb 20, 2008 | Corona 23-DK Compact Heater
Honeywell 510477 Oil Filled 7-Fin Radiator Heater Logo
117 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
