Question about Kenmore 54501 Dehumidifier
Why is ice forming on the top of the dehumidifier ?
  • Kenmore Master
  • 43,501 Answers
Sometimes when they run extended periods of time the outter case can get very cold also...with no air moving over the outer case the condensation can freeze there....
This is a tip that I wrote that will help to understand it better...
Dehumidifier is Freezing up and not working http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Posted on May 05, 2010
  • 121 Answers
SOURCE: Ice on dehumidifier
A dehumidifier works by cooling the metal pipes on the back of the unit to create condensation (water vapor in the air). This then drips into the collector bucket. If the unit runs too long the cooling tubes can get too cold and freeze the condesing water vapor. Unplug the dehumidifier and let the ice melt, when u turn it back on, turn it down, it may be up too high. If you find this solution helpful please rate it.
Thanks - Tech101
Posted on Jun 24, 2008
  • 588 Answers
SOURCE: ice is forming on the coils - delonghi dehumidifier
Check your filter, indoor coil and blower wheel to see if they are dirty, if they are they need to be cleaned, if not then you are probably low on refrigerant or Blower speed to low. If the blower doesn’t run when you turn the switch to on then you need to check the blower out, especially the capacitor.
Posted on Aug 23, 2009
  • 5422 Answers
SOURCE: Ice forming on the to
Usually this happens for one of two reasons: 1) there is a problem with the refrigerant and/or compressor (like a little leak of refrigerant)
2) the room that the compressor is in is too cool (below the operating range of the dehumidifier)
If the unit is under warranty, call for service if you know the room is above the minimum operating temp. If it is a problem with the refrigerant, they will probably replace the unit.
I hope this helps.
(we have an LG dehumidifier and had to have it replaced when it was less than a year old - it was icing up in the summer. It still iced up in the winter (at times due to cold in the basement).)
Posted on May 01, 2010
Testimonial: "Thanks. That is what I was afraid of."
heatman101
  • 43501 Answers
SOURCE: ice forms on top of the dehumidifier . it looks li...
Here is a tip that I wrote about that problem...
Dehumidifier2_bing.gif is Freezing up and not working
heatman101
Posted on May 25, 2010
heatman101
  • 43501 Answers
SOURCE: my dehumidifier keeps getting condensation on top
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
heatman101
Posted on Jul 13, 2010
HI, OUR DEHUMIDIFIER SWEATS ON THE TOP (FORMS WATER BEADS) AND PARTIALLY FORMS ICE.
>check if the steam creating by the dehumidifier is enough or balance to neutralize the fresh air supply of the dehumidifier by not creating a too much moist or more tha 40% relative humidity so that water beads would not form from the top of the dehumidifier unit or from its supply of fresh air.
Jun 18, 2011 | LG LHD65EBL Dehumidifier
I've got ice forming on top of the humidifier along the joint where the faceplate attaches to the main box.
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
heatman101
May 24, 2011 | LG LHD45EL Dehumidifier
My dehumidifier keeps getting condensation on top then it forms ice, what is the problem
heatman101
Jun 27, 2010 | Goldstar DH504EL Dehumidifier
Ice started forming on top of unit and now it has shut off and won't restart. It hasn't been running efficiently for past few weeks. Can I fix it?
If the surrounding temperature is low enough the condensing elements of a dehumidifier ice up just like the cooling plates in a frig. Either reduce the power or raise the surrounding air temperature.
Jun 14, 2010 | LG LHD65EBL Dehumidifier
Ice is forming at the top of the bucket what can I do??
heatman101
May 07, 2010 | Danby DDR3009EE Dehumidifier
Ice forming on top front part of unit
usually, ice build up is caused by low refrigerant levels (a dehumidifier is essentially an air conditioner). depending on the unityou may or may not be able to service it. Some of these systems are sealed at the factory and a pierce valve is needed to add refrigerant to the system.
May 07, 2010 | Goldstar DH504EL Dehumidifier
I hope this helps.
May 01, 2010 | LG LHD45EL Dehumidifier
Bucket not filling - ice forming on lid.
You've developed a sealed system problem.
Apr 07, 2010 | LG LHD45EL Dehumidifier
Ice on dehumidifier
Thanks - Tech101
May 20, 2008 | LG DH404E Dehumidifier
Kenmore 54501 Dehumidifier Logo
394 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
