Question about Garden
My chainsaw pulls to one side when cutting wood. how can i stop this? i have tried sharpening more on one side than the other but i may be trying on the wrong side.
    President:
  • 2,220 Answers
All chain teeth need be of equal size and opposite angles else it will cut at an angle. There is a wealth of information publish by a company that has been dealing with chain for very long time. Please read anything that appears remtely related.
http://www.oregonchain.com/pro/service/faq.htm
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 06, 2010
    Brigadier General:
  • 4,088 Answers
Check the edges of the bar where the chain groove is. If the metal is worn so that it sticks out beyond the vertical face of the bar, it can catch on the kerf and deflect the cutting or stop it altogether. File the protruding edges off (at about 45 degrees) If the groove/chain is badly worn, you may need to replace both. Sharpening should be as symmetrical as possible--don't try to fix one problem by introducing another. Hope this helps!
Posted on May 05, 2010
What would cause a new chain saw not to cut
Maybe I'm reading this wrong, but it sounds like you are saying your chainsaw is newer and runs fine, but it just isn't cutting wood well?
If that is the case then it means the chain wasn't sharpened correctly. Lots of guys do it at home and don't file down the raker teeth in front of the cutter heads, so the teeth don't grab into the wood and just nibble at the wood and make fine sawdust. It is always best to get the chain sharpened at a saw shop first so you can get an idea of the correct angles and depth of the rakers etc. After that you can try to match the saw shop for a while with a round file to take off ragged edges unless you have a decent professional saw sharpening unit.
Nov 03, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have purchased Poulon pro 42cc 18 inch chainsaw. I am extremely satisfied with my chainsaw until now. I have only owned it for about two months. I only used it maybe 10 times for easy tasks. my chainsaw...
The chain needs sharpened or replaced. You can purchase the tools from any hardware store, and sharpen the chain yourself in about 15 minutes. Don't worry, your saw is just fine!
Sep 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw cuts at an angle.....Why
The most common reason for this is uneven sharpening of the chain. Closely examine the chain and look for one ise to be worn more than the other. Try sharpening the dull side If sharpening is not a possibility, install a new chain. If the new chain also cuts to one side than the bar needs to be repaced as the chain is not being held straight.
Keep us posted,
Dan
Dec 23, 2010 | McCulloch Garden
Hi, my 16" Ryobi seems to have suddenly gone
When you are cutting you want to keep the chain out of the dirt...dirt will dull a chain so fast it will make your head spin. sound like you need to have the chain sharpened..there are mini grinders available for about 20 bucks that will allow you to sharpen your own chain...if you don't want to go that route then you can take the chain to your local hardware store or possibly a tree cutting service to get it sharpened
Dec 16, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
My stihl chainsaw will only cut half way through a 14 inch ie branch and won't go any further chain still going but seems to heat up the chain as well tried new guide bar but still doing the same thing
This generally happens when the chain is sharpened more on one side than on the other. The saw cuts to one side rather than straight down. When the part of the chain that's on top of the bar gets into the cut it's being pushed against the side of the cut which causes it to heat up and stop cutting. The solution is to get the chain professionally sharpened at a tool hire/service centre. When you're getting it done tell them the problem so they know to correct it.
It happens to all saw operators and we all have to have the saws professionally sharpened every so often.
Nov 20, 2010 | Garden
My bosch ake 35s isn't cutting, what's wrong with it? chain turning as normal
Chain has dulled. Needs sharpening.
Hitting one little imbedded rock in the wood and the chain can be dulled to the point it only burns the wood.
Replace the chain or have it sharpened.
Apr 12, 2010 | Bosch Garden
Why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Mar 28, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
When cutting, as it progresses, the cut curves to the rught automatically.
Sharpening a chainsaw is an art. I wokred in the logging industry for 20 years before I was shown how to truly sharpen one well!
It appears that your problem has one of two causes.
1. Sorry, but you may not have filed the chain correctly, a common problem for newbies and some veterans. Ensure that all cutters are filed at the same angle (save your old chain and buy a new one for a quick solution). The file should be worked from the back of the tooth to the point ONLY. The file should be stroked at 90 degrees to the bar and parallel to the line that is inscribed on the tooth (if a line does in fact exist). Each raker should also be the same height - get a raker gauge from your chainsaw shop. If the rakers on one side of the chain are lower than the other side and/or the cutters are filed at significantly different angles on one side than the other the saw will cut in a curve.
If you look at the cutter from the side each one will show a quarter moon filing "circle" and both sides of the chain MUST be equal or close to equal. If one side has a moon and the other does not the saw will cut in a curve so severly it will bind in the cut.
2. A worn bar that is higher on one side of the chain groove than the other will also cause problems - a new bar is the only long term solution for this. The unequal height is caused by incorrect filing of the chain and long term use of the bar with this condition.
If the bar is in good condition and the rakers and cutters are filed properly you will not have to push on the saw to make it cut - it will pull itself through the wood. Indeed, before you buy a bigger saw to cut faster you should ensure correct filing - you may amaze yourself and your buddies!
I am a Certified Faller in the Province of British Columbia, Canada if you are wondering about my credentials.
Good Luck and Safe Cutting!
Doug Hough
Parson, B.C.
Jan 18, 2009 | Husqvarna Chain Saw 20" Bar
Ryobi 14 inch electric chainsaw won't cut with new chain
Hi Rossmac,
Both the smoke and it's lack of cutting ability are symptoms of the same problem. The Chain is dulled. Instead of cutting, it's just rubbing on the wood and heating up. It's also not a big deal to fix..
Your options are:
  • Replace the Chain
  • Have the Chain sharpened
  • Sharpen it yourself
To sharpen it yourself, you will need a narrow round file that will fit inside the Chain teeth. Each tooth has a two cutting edges, get the file a position that matches the tooths angle of attack. Don't over do, three to five swipes of the file should do it on each surface.
You will see they alternate directions. You may find it easier to do all the teeth in one direction (skipping every other tooth) then do the other direction. Up to you.
When you are done, check the level of your chain oil. Since it did get hot, you might manually oil the chain before trying out your handi-work.
Go cut some wood.
Mike
Dec 21, 2008 | Ryobi 18-inch Electric Chainsaw Chain Saws
Poulan Wood Shark Chainsaw - wood smoking. Is chain on backwards?
I cannot tell you about a picture, but for one: chain direction, the bottom of the bar is where the cutting takes place, and therefore, looking at the chain, you will see, on the bottom, the antikick back link is sort of curved, and then the next part is the straight tooth. The highest part of this straight tooth is the sharp edge, and this high part should face towards the motor. The chain, on the bottom side of the bar, is pulled in towards the motor by the clutch/gear. That is your direction of travel.
As to cleaning the air filter, Hopefully you have access to compressed air, as in simply blowing off the dirt. You do not want to use liquid cleaner. Simply blow off any dirt, after pulling the filter away from the carburetor, of course. Then place it back in place.
It may be that your chain is real dull. The top edge of the high part of the flat tooth needs to be sharp. And the outside corner needs to come to a nice point. Remember, there is two cutting surfaces on each tooth, the top is cutting down into the wood, and also that outside sharp corner is openning the cut for the bar to pass through. Proper sharpening, if new to it, can be hard to grasp. Any chainsaw manual should show how to do a good job.
Nov 16, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
920 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
