Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Q8035 - 8038
· 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
Is there a way to purchase/order these and fix this?
  • 1 more comment
  • Anonymous Apr 09, 2008
    After turning on tv (kp-57wv600) the picture comes on for about 10 seconds then turns blue and shuts off. I tried to adjust the voltage adjustment for the blue but picture still goes out. Sound is ok. There is a small light that comes on which is located on the bottom of the blue tube. Not sure what that means. Is the blue tube in need of replacement?
  • MISTER 123 Apr 09, 2008
    i called sony orderd and replaced my spark gap (sg9202) on the cg board (no dice) my kp57wv600 still blinks 7 times Im now atempting to change q8035 and q8038 which look perfictly fine from what the eye can see
  • reehsj Jun 06, 2008
    Im having exactly the same problem. Any solutions yet?
For the guy witht he problem w/ the blue tube. It probably isn't your tube. When you take off the front panel, and the board behind it. you can see the bottom of the tubes. The light on the bottom of the tubes says that your heaters are good; thats a good thing. Below the tubes is the focus block, where you can make adjustments to the tube intensity and focus. If the tube won't adjust in then replace that focus block and you'll probably be fine. For the other guys, the transistors may or may not fix it, but your definitly going in the right direction.
Posted on Jul 05, 2008
SOURCE:
Tv turns off red light blinks 9 times
Sony tv led and blinking codes
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
I hope this will be of some help to you
Mar 22, 2012 | Sony Televison & Video
Television will not come on. The red light power button blinks three times and then nothing.
Not knowing your exact model, the following information may be a little off but will work all the same
I think you may have a few problems here. If you are comfortable with soldering, check the following parts first:
R7060 and R7066. These are .27 ohm resistors that feed the convergence ICs. They may be open. If they are open, the convergence ICs are probably bad and need to be replaced. These are STK390-110. These should be readily available on-line for about $20-$25 each.
Let me know if you need any further help and remember that working on a tv can be dangerous and can result in a large electrical shock.
Apr 08, 2008 | Televison & Video
My tv power led red blink 4times
Blinking codes are never good news
Please r5ate my help++++Thanks for using FIXYA
May 28, 2010 | Sony KDS-R60XBR2 Television
Sony KP-51WS500 turns red ,shuts off, led blinks 8 times
Here are the fault codes for your tv and what components are affected:
I have seen the tube divider pack cause this too, Take the front speaker grill off remove the 4 screws and the panel comes off. There is a pack with 2 red 2 green and 2 blue adjustments, Try turning the BOTTOM red one down 1/32 a turn and see if the symptoms change
Apr 03, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony kp65wv700 tv blinks 7 times - Horizontal deflection issue is what manual is telling me. My question is what transistor/chips I need to replace and if anyone has done that to fix this problem...
Feb 26, 2010 | Sony KP-51WS500 51" Rear Projection...
Turns on when cold and works fine for thirty seconds, then starts clicking in the back and picture goes out. Then tries to turn on and then just clicks off again. Continues to cycle like this, but never...
Pls check error code by counting the front LED flashes. Below is the list or error code and values;
0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted. 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode. 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped. 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small. 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture. 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board) 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board) 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Dec 26, 2009 | Sony KP-43HT20 43" Rear Projection...
TV wont turn on
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board)Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Apr 06, 2017 | RCA Scenium HD65W20 65" Rear Projection...
I HAVE 4 FLASHES
Sep 24, 2008 | Sony KP-53V85 53" Rear Projection...
TV auto shut off-power indicator light blinking-won't turn back on
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
If you are having some problems with your Sony Television, then this post is for you. Generally speaking, when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself. In some cases, you may be able to repair the television set yourself -- or in the worst case you may need to order parts, call a local repair shop to the have a repairman sent out, or even purchase a new television set.
First off, here are the list of codes and what they generally mean on my set (which applies to many recent model Sony Television sets. Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
* 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
* 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
* 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
* 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
* 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
* 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
* 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
* 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
* 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
However, be aware that there are voltages inside your TV set that can kill, even if unplugged.
Jul 08, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
SONY KDP 65WS550
are you sure it 10?
these are the codes i have
· 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
· 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
· 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
· 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
· 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
· 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
· 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
· 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Hopefully, the descriptions of the blinking lights and the symptoms and problems will point you in the right direction to tell the problem with you Sony Projection Screen Television. If it is not enough, do not worry -- in the coming few posts I will talk about entering the Diagnosis and Service modes for your television set!
Mar 13, 2008 | Televison & Video
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
779 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
