Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
Timer stops at on postion? transfomer works, have to do it by hand
I have the exact same problem with the Intermatic ML88T. No obstructions are present. The timer simply stops when the dial reaches the red or black pin and won"t go any further. As a result, the transformer is unable to turn lights on or off. However, if you turn the dial manually to the point where you cross the tripper with the red or black pin, the lights will be turned on or off.
Posted on Jul 16, 2010
Intermatic Malibu 300W Power Pack Transformer ML300RTW Problem :The timer stops at both the on and the off trip position and does not move any further. I have manually turned and reset the timer to the correct time but when it is time to trip the on switch, the wheel stops and never moves again. I have power and it doesn't trip a breaker, power is still present but the timer wheel does not move. I have lubricated the moving parts and they turn freely but continues to stop and not trip the circuit either on or off.
Posted on Jun 23, 2010
    Guru:
  • 351 Answers
If the timer is stopping, it could be a physical obstruction. Or it could be an electrical mis wiring so that the timer is turning itself off at that point, check the incoming wiring and see if it makes sense, and follow the diagram to see if the incoming power is definitely not on any switched terminals, they would maybe be marked with NO , NC,
Posted on May 04, 2010
Transfomer works, timer dosent
May 04, 2010 | Hardware & Accessories
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
The sound stopped working on rca projection TV
FBT flyback transfomer and hori output transistor
Jan 01, 2010 | RCA P46812BL 46" Rear Projection...
New Intermatic WH40 electric water heater timer for solar
make sure your line wire is on the correct connection seems to be connected to the off going contact. then the clockmotor runs only if timer is switched on. to be sur there is a diagram on electricsuppliesonline.com, search/shop by brand, intermatic. good luck
Dec 27, 2009 | Intermatic WH40 - Water Heater Time Switch...
The deforst timer didn't work and got ice
Does the timer move? If you can, try rotating the timer to the defrost postion when the frigorator turns off and see if the defrost emement starts to heat up. If it doesn't then you could have a bad thermostate. easy to replace.
Jul 15, 2009 | Whirlpool ED5FTGX Side by Side...
On/off switch
if the mixer is pretty old then the timer is bad.If its a newer unit the timer or the bowl height sensor is bad.
Jul 01, 2008 | Hobart A200 Stand Mixer
Re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. ashfaque.r@googlemail.com
May 18, 2008 | Seiko SNA553 Alarm Chronograph
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
702 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
