Question about Hardware & Accessories
Transfomer works, timer dosent
Timer rolls around right up to the on postion and stops?
Seems to weak to power past the on ''toggle to turn on'' 3 years old
Have to go out and turn it by hand
Can anyone help?
    Guru:
  • 351 Answers
If the timer is stopping, it could be a physical obstruction. Or it could be an electrical mis wiring so that the timer is turning itself off at that point, check the incoming wiring and see if it makes sense, and follow the diagram to see if the incoming power is definitely not on any switched terminals, they would maybe be marked with NO , NC,
Posted on May 04, 2010
Testimonial: "thanks will do"
Describe your Malibu 600W Power Pack Transformer Problem When it is time for the low voltage lights to come on the timer can not get past the pin to turn it on, however when I turn the timer dial it...
When dial gets stuck at tripper, then clock motor has gotten weak.
1) Some people report taking apart the clock motor, cleaning gears, and adding vaseline to gears.
-Some people write and ask how to put gears back together after taking timer apart.
-Some people find the gears are stripped.
-There are no replacement clock motors or timer modules for Malibu/Intermatic timers.
2) Easiest solution might be to buy cheap plug in timer, set power pack to override, then plug power pack into cheap timer.
3) Power packs come with a warranty, but warranty requires sales receipt.
-Open following link for resources including warranty.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 08, 2011 | Intermatic Malibu 300W Power Pack...
Timer rotates but whenever it reaches the tripper to turn the lights on it gets stuck there. It's like there isn't enough power to rotat the switch to turn the lights on. Have checked the switch...
The clock motor gets weak and sticks on the tripper and then stops working.
Possible solution: Some people report they disassembled clock motor, cleaned the gears and added a bit of vaseline or white grease to gears because they get dirty.
Then afterward, you might try duct tape to seal unit from dust
Others report they got the clock motor apart and didn't mark parts and take photos along the way, and forgot how tiny gears went back.
My experience with clock motors, and motors in general, is when they slow down, they overheat and don't last much longer.
There are no replacement clock motors for ML series power packs, which is shortcoming since Intermatic makes replacement clock motors and modules for many of their products.
Work-around: Set timer to override, then plug power pack into cheap wall timer.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Jun 26, 2011 | Intermatic Malibu 300W Power Pack...
The timer works but gets "stuck" when it comes to the ON time. it will continue this cycle if i force it to click past the ON time; but when it comes around the next day it sticks again.
You posted under malibu power pack.
When clock motor gets weak, it can no longer push timer dial past the trip point switch.
Right now the clock motor is overheating and will stop functioning.
This timer does not have replacement clock motor, but comes with 5-year limited warranty.
Buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
For complete troubleshoot, trippers, manuals and warranty information:
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Apr 14, 2011 | Malibu ML900TW 900 watt Power Pack Timer...
THIS IS THE SECOND TIME THAT I HAVE COME ACCROS THIS PROBLEM..........TIMER SEEMS TO WORK BUT WHEN THE TRIP GETS TO THE SETTING IT DOSEN'T SEEM TO HAVE ENOUGH POWER TO OVERCOME THE TENSION OF THE CONTACT...
The clock motor has gotten weak, and is overheating and will stop working.
Buy cheap plug-in timer, set power pack to override, then plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Aug 19, 2010 | Malibu ML88TL 88Watt Low Voltage Power...
Timer stops at on postion? transfomer works, have to do it by hand
May 04, 2010 | Intermatic Malibu 300W Power Pack...
New Intermatic WH40 electric water heater timer for solar
make sure your line wire is on the correct connection seems to be connected to the off going contact. then the clockmotor runs only if timer is switched on. to be sur there is a diagram on electricsuppliesonline.com, search/shop by brand, intermatic. good luck
Dec 27, 2009 | Intermatic WH40 - Water Heater Time Switch...
Just as someone else wrote, I too have the Malibu light timer and have the blue & red pegs set to turn on (red peg) at 7pm and off (black peg) at 11pm. The lights will not automatically turn on...I...
The clock motor has gotten weak and is now overheating, and will soon stop turning. There are no replacement clock motors for ML series power packs.
Open following for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
Upvote the help.
Nov 09, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Hardware & Accessories Logo
110 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
